Old 07-10-2006, 11:16 PM   #1
2slofouru
Member#: 90539
95 L with ej257k
powa, Raven R6
Default rear crossmember swap questions:
I will be swapping my awd rear crossmember into my fwd 95L in a couple of days hopefully, if the weather is ok. I have a couple of questions since it seems I will have to do the entire swap at one time, and I don't know if I can do it in my short time off from work:
-can I just swap the gas tank and rear crossmember and keep the normal non awd rear hubs for now so I can put the diff and axles in later?
-are the lateral links in the same place on the awd and non awd rear crossmember
I could just put the awd rear hubs on at the same time as the gas tank and crossmember, but I would need a set of outer cv links without the rest of the axle, to keep water and debris out of the hub bearing.
-Or would it be ok to just install all awd components minus the 5speed transmission and driveshaft? Would it hurt to have the differential spinning freely being turned by the rear shafts? I asked that question before, but just want to be sure. Thanks for any help, as usual
2slofouru is offline   Reply With Quote
Old 07-11-2006, 01:00 PM   #2
Legacy777
Member#: 4800
1990 Legacy & 97 OBS
AWD 6MT EJ22T AWIC Swap
If you want to only install the gas tank & crossmember you will need to use the AWD lateral links. The FWD lateral links are a little different in their size. The location of their mounting should be the same.
Personally, I'd just mount up the entire rear suspension & drivetrain, and then hook up the trans & rear driveline when you get to it. As long as there is oil in the diff, there's no problem with it spinning, and being along for the ride.
I've got some pics from my swap if you're interested. There's pictures of the different crossmembers and such.
www.surrealmirage.com/subaru/swap
Josh
Legacy777 is offline   Reply With Quote
Old 07-11-2006, 01:13 PM   #3
2slofouru
Member#: 90539
95 L with ej257k
powa, Raven R6
Thanks for the help. The only thing I was wondering about if I actually put the rear diff in is if it would be making the whining sound like when you are in reverse, since it will be putting the wear on the opposite sides of the ring and pinion.
Old 07-11-2006, 02:33 PM   #4
Legacy777
Member#: 4800
The whining sound you hear in reverse is the reverse gear in the transmission since it is straight cut. The gears in the rear diff are helical, so you won't hear anything.
As for the wear thing on the opposite side.....that's not an issue.
Old 07-11-2006, 04:30 PM   #5
2slofouru
Member#: 90539
95 L with ej257k
powa, Raven R6
This is gooth... berry berry gooth.. Nothing to worry about then
WTB: '02 WRX rear crossmember and front crossmember plate Hank3 Private 'Wanted' Classifieds 2 01-09-2006 08:15 AM
GC8 AWD rear crossmember and T-crossmember moss Private 'For Sale' Classifieds 1 12-25-2005 05:34 PM
Crossmember swap I_smoke_hondas Transmission (AT/MT) & Driveline 11 02-08-2004 02:34 AM
Turbo crossmember swap ?'s serious Legacy Forum 4 01-08-2003 01:10 AM
Engine Crossmember Swap (NA->Turbo) stimpy Normally Aspirated Powertrain 3 02-07-2001 05:46 PM
