Old 07-11-2006, 01:05 AM   #1
brokenarrow
Member#: 119767
2006 wrx
Default what is this LEAN talk???
What is this lean talk??
I have read on here ..in a few places that 12.0 IS LEAN???
LOl.....please flame or correct me but Thats RICH right?
14.0 is In the middle and 15 is lean and 12 is where you WANT to be...when your at WOT..and then 14 when you are just putting around....????..
Is this not correct???
thanks ..and i am just wondering this cuz its what i have always thought and tuned for ..
brokenarrow is offline   Reply With Quote
Old 07-11-2006, 01:09 AM   #2
slidez
Member#: 112185
2005 WRX STi
Yeah I've also heard that when you tune a motor you want to be as close to 12.0 as possible from a guy that builds motors in England. Im not sure if they take into account the crappy quality of fuel from the USA though. But take it with a grain of salt since I don't know anything about tuning.
slidez is offline   Reply With Quote
Old 07-11-2006, 01:25 AM   #3
hotrod
Member#: 14141
2002 Impreza WRX
Rich of what or with respect to what?
Depends on what engine your talking about, and the context. There is no absolute "correct" fuel air mixture without knowing the application and conditions.
Acceptable mixtures vary depending on the engines compression ratio load, and if it is NA or boosted, and the intent of the tuner. What is a "correct" mixture for emissions is terribly lean for power and detonation protection at high engine load.
Max power on gasoline fuel in an engine that is not working at max potential, occurs between about 12.0 and 13.0 AFRs. Most folks accept that the safe max power mixture for such an engine is about 12.5:1. Now that is based on a NA, water cooled engine that is not knock limited (ie does not have so much compression that it is at risk of detonation) with fuel of proper octane, reasonable intake air temperatures,and sensible ignition advance. When the engine is under moderate load the "correct" or ideal mixture from a power or performance point of view is about 12.5:1.
Most turbocharged engines cannot run under high load at mixtures that lean, and are run much richer than that to prevent detonation and to cool combustion temperatures. For them the "correct" mixture for high power is from about 10.5:1 -to- about 11.5:1. In a specific turbocharged engine 11.5:1 might be too lean to prevent detonation. In another engine 12.2:1 might be possible under the same load and boost conditions.
14.7:1 is a stoichiometric mixture (ie exactly enough fuel as necessary to burn all the available air). This is the "correct" or ideal mixture only in the context of chemistry. At any significant engine load it is very very lean for most engines.
Fuel air mixtures are load and condition dependent you cannot define a mixture as lean or rich without defining the tuners intent or condtions.
Larry
hotrod is offline   Reply With Quote
Old 07-11-2006, 02:11 AM   #4
brokenarrow
Member#: 119767
2006 wrx
This is very very helpfull.
thanks you very much!
So for are cars ( wrx or sti) we should be running from 11 to 10 ?
i am understanding what you have said about the tuner intent or condtions ... and then also what does Cobb run a stage 3 at on are cars ...??
thanks ALOT again
AND what you have just posted Should be a sticky that is very good info..for some one that might be wondering what to tune his a/f's to.
Old 07-11-2006, 02:28 AM   #5
hotrod
Member#: 14141
2002 Impreza WRX
Not exactly, but those are common ratios folks see on the stock ECU under certain conditions. You don't tune an engine to a single air fuel ratio with EFI, like you did with a carburator. On carburated engines you picked jets that gave a good average mixture for most of the engine rpm range and just lived with what you ended up with at other places in the power band.
On EFI the tuner tunes each specific load cell independently. At a single RPM there might be a dozen different possible fuel air ratios and ignition advance settings depending on boost and engine load for example.
In a "general sense" folks talk of attempting to hit a certain "target" AFR under heavy engine load, but there is no certainty that they will be at that exact AFR under all condtions.
To answer your intended question ---
Yes the stock WRX and STi frequently hits AFR's in the mid 10 - 11:1 AFR range under load. Most performance tuners try to lean the mixture out to get as close as they can to the ideal 12.5:1 for max safe power, but in most cases they can get no closer than 11.5 - 11.8:1 depending on boost, ignition timing and the specific setup on the car.
Also some tuners are more agressive than others and will (if they trust the customer) tune to the ragged bleeding edge for performance while in other cases they will use a more conservative tune to protect the customer.
Larry
Old 07-12-2006, 12:04 AM   #6
theicewall
Member#: 70532
2004 WRX
^^yup, that's why a tune needs to be on 3 axes of space. Often RPM vs Load vs A:F and then I guess a 4th axis would be target boost for a given tps at a given load but that needs its own graph.
theicewall is offline   Reply With Quote
what is this part called? what is it's part number? OUScooby Private 'Wanted' Classifieds 8 04-21-2010 04:08 PM
Whats all this football talk about? tommy2hotty Off-Topic 10 03-01-2006 02:55 PM
What is this girl talking about? automatic1977 Off-Topic 19 11-09-2005 05:26 PM
what the hell is this n00b talking about? Handsdown Off-Topic 26 07-30-2005 11:20 PM
('93-'01) what is this and what does it do? shimstock Impreza Forum 4 04-10-2001 09:53 AM
