Old 07-11-2006, 12:53 PM   #1
meajas12
Member#: 118514
2004 04 STi/04 Cobra
WRB/Black
Default Which springs with Koni inserts on Sti?
I just got a set of 05 wrx struts. I am planning on gutting them and putting koni inserts in them and putting them on my 04 Sti. The question is should I use the stock 04 Sti springs or get 04 Prodrive Sti springs or 04 Prodrive Wrx springs? I searched and didn't find what I was looking for. For those who have done this, do the koni's come with bumpstops? Which bumpstops should I use? Thanks again.
meajas12 is offline   Reply With Quote
Old 07-11-2006, 03:26 PM   #2
leecea
Member#: 37359
2003 WRX
I don't remember getting bumpstops. I used my stock ones.
IIRC, conventional wisdom is that Konis will be OK with any spring up to mid-300 ft/lbs without revalving.
leecea is offline   Reply With Quote
Old 07-11-2006, 03:43 PM   #3
flyboymike
Member#: 83765
2005 WRX wagon
WR Blue
That's what I've heard as well. Look through BIGSKYWRX's posts to be sure. I think he's the guy I heard it from.
flyboymike is offline   Reply With Quote
Old 07-11-2006, 07:32 PM   #4
peterex
Member#: 27021
2015 WRX
I would recommend using springs at least as stiff as your stock STi springs - if not stiffer. The Konis ride well enough that you need not sacrifice performance by stepping down to a softer spring (i.e. WRX Prodrives). I'm running springs that are roughly equivalent to JDM STi pinks on my Konis, and the car rides great IMO.
peterex is offline   Reply With Quote
Old 07-11-2006, 08:45 PM   #5
RUrunning
Member#: 68758
15 STi
LE
to the op, are you doing this b/c your stock struts went out or because the konis will perform/ride better?
RUrunning is offline   Reply With Quote
Old 07-11-2006, 10:04 PM   #6
meajas12
Member#: 118514
WRB/Black
the car is a daily driver, pa roads suck, and looking for a better ride-less bobble head
Old 07-12-2006, 12:43 AM   #7
flyboymike
Member#: 83765
2005 WRX wagon
WR Blue
To avoid bobble-head, make sure you pair up whatever springs you get with some Group N strut tops. You could also go for the Tarmac springs and camber plates from RaceComp Engineering plus group N rears. It's a pretty stiff spring, but Myles spent a lot of time developing it specifically to find both comfort and performance.
RCE Wagon Springs with Koni Inserts . . .? Nicky B. North West Impreza Club Forum -- NWIC 13 05-18-2008 03:11 AM
Spring choice for Koni Inserts on 02 RS pondomoto Brakes, Steering & Suspension 2 06-25-2007 10:09 AM
Bouncy ride with Koni inserts and Tanabe springs DerekMD07 Brakes, Steering & Suspension 16 03-09-2007 01:07 PM
STi RA springs and Koni inserts installed- impressions TheMirror Brakes, Steering & Suspension 24 12-19-2003 10:00 PM
Best Springs with Koni Inserts Shankster Brakes, Steering & Suspension 8 06-19-2003 07:09 AM
