Old 07-11-2006, 04:26 PM   #1
06rexwagon
Member#: 114730
2006 WRX Limited Wag
[email protected]
Default Cobb stage 2 running lean.
I recently got my street tuner up and running and have started logging. I have a LC-1 wideband and my actual A/F ratios are considerably leaner than what is targeted in the tables. At times it is greater than 1.0 afr leaner than target. I have had zero knock with this setup, but it really makes it hard to tune without knowing that you can hit your AFR targets. I am beginning to adjust my offsets for intake calibration based on MAF voltage to see if I can get my AFR closer to target. Have any other users seen this? BTW, I have an '06 with Cobb catted TBE running stage 2 91 octane map.
06rexwagon is offline   Reply With Quote
Old 07-11-2006, 06:44 PM   #2
boundy3
Member#: 54598
2004 WRX Sedan
WR Blue Pearl #68 STX
Whats your IDC like?
Are your running lean all the time or just when your heavy into the throttle?
Where is your wideband located, in the downpipe?
boundy3 is offline   Reply With Quote
Old 07-12-2006, 12:04 AM   #3
06rexwagon
Member#: 114730
[email protected]
IDC is really low (it's an '06). They are usually under 60%. I think I found the answer today. In the manual for my LC-1 it mentions that cars with smog pumps will read leaner than they are actually running because the smog pump adds air to the exhaust. The '06 has a smog pump instead of a catted Up pipe.
Cobb Stage 2 Lean rhurley13 AccessPort 6 04-22-2010 07:32 PM
Cobb Stage 2 Running Safely? bmw50021 AccessPort 3 11-22-2006 08:20 PM
STi Cobb stage 2 running rich or lean? SubaruBen Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 8 10-14-2005 12:48 PM
my cobb stage 2 running lean!!! swol3 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 17 09-18-2004 07:55 AM
Cobb Stage 2 running very lean grozgon Engine Management & Tuning 33 06-15-2004 11:01 AM
