Old 07-12-2006, 12:19 AM   #1
gozway
Member#: 47462
05 STi
CGM
Default Wierd idle with a freshly reflashed base map
Just reflashed my 93 vf34 map on my 04 wrx 2 days ago and now it will sit at its normal idle spot but the vacuum will surge toward positive just alittle causeing the idle to be rough. the rpms don't change on the tach, just curious because before with the exact same map it didn't do this and i haven't touched anything under the hood?
gozway is offline   Reply With Quote
Unable to reflash base map BenWeavdog AccessPort 13 03-31-2013 05:21 PM
Reflashed base map, need to reset ECU? SWRX AccessPort 1 09-27-2006 08:55 PM
wierd utec logs plus maxing out injectors on stage 1 base map NITROS Engine Management & Tuning 4 01-04-2005 08:04 PM
Anyone run a P&P'd VF34 with the COBB VF34 base map & a TMI? The Modaholic Engine Management & Tuning 10 04-14-2004 07:19 PM
Any bad exp. with ECU reflash base maps? ChrisF Engine Management & Tuning 4 05-03-2003 04:14 AM
