South East Region Club
Go Back   NASIOC > NASIOC Regional Areas > South East Region Forum
Old 07-12-2006, 11:09 AM   #1
compton
Member#: 10646
02 sti bugeye
still filthy
Question Cam seal - Oil leak - tips?
Helllo all,
I have an oil leak issue that showed up last night on my 02 wrx and have narrowed it down to the drivers side timing cover. It does not appear to be comming from the center or passenger side of the timing cover. So... it looks like I have another job on my hands. I am curious if any members here have had the wonderfull experience of replacing the cam seals and crank seals themselves. If so any tips on the removal/installation of the sprockets and seals would be greatly appreciated. I also have a couple particular questions...
Is it necessary to pull the valve cover to remove the cam seals or can I carefully remove them with a tool/awl/somthing else?
Will I need to use a bonding agent on the installation of the cam seals? crank seal?
Is there any tips/tools out there for keeping the cams in place so the when I re-install the sprockets and belt I do not screw my timing up?
Is there anyone in the brevard area that has done this and may want to join me for a beer...lol it would be nice to have an experienced hand nearby incase I have a question or two.
Thanks in advance,
-Noah
compton is offline   Reply With Quote
Old 07-12-2006, 11:37 AM   #2
dropmech
Member#: 41477
2006 Tahoe that
will pull your bumper off
You can try PMing Pacobeagle1. He's our local Suby mechanic down here in south florida. You can take it too his shop to in North Palm Beach. Japtrix.com
dropmech is offline   Reply With Quote
Old 07-12-2006, 02:46 PM   #3
compton
Member#: 10646
02 sti bugeye
still filthy
Thanks dropmech! I have noticed some of his posts here in the regional forum and he sounds very knowledgable. I will give him a pm if I don't get much feedback here first. I would really like to do this job at my house since I would have to ride my bike back from westpalm if we did not finish the job down there in a day or two. That was the case with my clutch a couple weeks ago... I got a bad part from the subaru dealer and had to ride my bike to work untill Igot a new one and put it back together. My legs sure felt that.
Old 07-12-2006, 03:25 PM   #4
bl_easy
Member#: 91407
Ver. 2 WRX STi wagon
BRetty green
If you're noticing oil coming from the bottom of the timing belt cover, then my guess is that the cam and/or crank seals are just worn and need replacing. You'll need a new timing belt, too, if oil has gotten all over that.
This happened with my car in February... and I drove like that 'til early April. But I can't really help you out, as I took it somewhere when this happened.
But as for my contribution... call Jose at Japtrix.
bl_easy is offline   Reply With Quote
Old 07-13-2006, 08:45 AM   #5
compton
Member#: 10646
02 sti bugeye
still filthy
bl_easy - Yeah, I am planning on replacing all the seals and the belt while I am there.
Bump^ for ANY firsthand experience... i do not want to tear this thing down this weekend if I do not have a good idea of any potential issues I may run into.
Old 07-13-2006, 08:51 AM   #6
Porter
Member#: 486
2004 Forester XT
bug spattered
How many miles on the car? The water pump might be worthwhile to replace while you're in there, and the oil pump O ring.
It really depends on the mileage, though.
Porter is offline   Reply With Quote
Old 07-13-2006, 09:39 AM   #7
compton
Member#: 10646
02 sti bugeye
still filthy
It is appox 95k... I think I will go ahead and do it if it is easier at that time. I also have a new set of Cusco motor mounts and a Blitz intercooler I plan on installing at the same time, so it will be pretty well disasembled at that time.
HELP!! cam seals broken? oil leak. s204life Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 11 02-16-2010 07:59 AM
FS: ej25 water pump/cam seals/oil pump seals/timing belt cover gaskets sti charles Engine/Power/Exhaust 24 11-02-2008 02:10 PM
2.2 rear cam plate oil leak 95subaru Normally Aspirated Powertrain 1 08-17-2006 12:25 PM
Cam seal - Oil leak - tips? compton Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 07-15-2006 05:37 PM
Cam seal leaking oil. Again! b0dh1 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 12-02-2005 03:51 PM
