Old 07-12-2006, 12:21 PM   #1
ianliam
Member#: 72632
2002 Impreza WRX
Rally Blue
Default Removing CAI and BOV ...Do I Reset?
I am stage two with a BOV and K&N Typhoon CAI. I'm removing both. I understand that these items will "work" with the AP, so my theory is that I will not have to reset the ECU and reload once the items are removed, as these are not significant modifications. Correct assumption?
Thanks
ianliam is offline   Reply With Quote
Old 08-05-2006, 05:01 PM   #2
rexworx
Member#: 103232
GTX 3071R'd 11WRX
PPG,4.44,LSD,E85,6spdx2
Yes you need to reset the ecu.
You will have to reflash back to stage 2
rexworx is offline   Reply With Quote
Old 08-05-2006, 09:12 PM   #3
jmanrex
Member#: 15288
2004 wrb sti
a good rule of thumb is you should reset no matter what you do--it doesn't hurt
jmanrex is offline   Reply With Quote
Old 08-06-2006, 02:41 PM   #4
02WHITEDUB
Member#: 96793
02 ProTuned TD04
Now with more clunks!
Why would you reflash the stage 2 map? It's not lost in a reset...
And to the OP, no, you shouldn't use a CAI or BOV with COBB maps, and I have no idea where you got the idea that it was OK.
02WHITEDUB is offline   Reply With Quote
Old 08-06-2006, 03:41 PM   #5
ShawDizzle
Member#: 118902
08 WRX Premium Sdn
Ya, reset because making changes and not resetting the ECU map will cause unseen long term damage. Too lean/ too rich.
ShawDizzle is offline   Reply With Quote
Old 08-06-2006, 03:45 PM   #6
ShawDizzle
Member#: 118902
08 WRX Premium Sdn
True, the Cobb shelf maps off the site say use with a TBE and UP and specify what turbo. the old maps use to have a map for Injen. that was dropped and now it says to use only the stock intake. But you can use a CAI and BOV with the Cobb AP as long as you get a map made up from road or dyno tuning it.
Old 08-06-2006, 04:46 PM   #7
02WHITEDUB
Member#: 96793
02 ProTuned TD04
^^There you go^^
COBB also states that a full TBE is required, but they don't say that about an UP.
UP is HIGHLY recommended for any reflashed pre-06 WRX but not 'required' by COBB. Conversely, everyone here (that knows anything) knows it's less risky to run just a DP and stage 2 than to go full TBE and keep the UP cat.
Old 08-06-2006, 05:37 PM   #8
-Kevlar-
Member#: 82378
O RLY?
-Kevlar- is offline   Reply With Quote
WTB APS CAI and BOV etirums Private 'Wanted' Classifieds 2 02-25-2007 03:26 PM
WTB: APS CAI and BOV wrxwhip Private 'Wanted' Classifieds 0 09-19-2006 11:04 AM
CAI and BOV ? HELP! wrxwhip Newbies & FAQs 61 03-01-2005 03:40 PM
Newb Question! Cai And Bov scooby-custer Newbies & FAQs 17 10-14-2004 08:38 PM
Removing MBC: Low boost. Do I reset ECU? Spool_up Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 03-27-2004 12:59 PM
