Welcome to the North American Subaru Impreza Owners Club Wednesday June 1, 2016
Old 07-12-2006, 11:59 PM   #1
GD6Noob
Member#: 119979
2006 Impreza 2.5i
Default supercharger kit for the subarus?
im a new impreza owner, just got a 2006 2.5i standard.
i know that if i want a fast car i should get the wrx or the sti, but cant afford.. and dnt plan to do much in the near future but just got a question...
the supercharger and the turbo needs diff compresion ratio, right..
the STi runs at 8:2:something and the 2.5i is at 10:0:1
would a supercharger work or is there such a kit for our imprezas?
thanx for the help
GD6Noob is offline   Reply With Quote
Old 07-13-2006, 12:08 AM   #2
reddevil
Member#: 64673
1990 Legacy wagon
goes 12.387 @ 116.5
there is no kit. period.
Old 07-13-2006, 12:37 AM   #3
si12j12
Member#: 99697
04 wrx [wrb]
ni stage-ah san!
no kit that i know off ---maybe this.............
si12j12 is offline   Reply With Quote
Old 07-13-2006, 01:13 AM   #4
semaj
I'm sorry for apologizing
Moderatour
Member#: 113533
2006 Pathfinder
Off Road
That looks like a twin-charger (turbo and supercharger) setup to me!
semaj is offline   Reply With Quote
Old 07-13-2006, 01:27 AM   #5
GD6Noob
Member#: 119979
2006 Impreza 2.5i
i thought that turbos and superchargers cant be used together coz of the compression ratio..
and if there isnt a supercharger kit, how would it be on there with the turbo?
so the only route to gain big power is turbo, with a swap first..
or are the new 2.5i able to hold boost?
Old 07-13-2006, 01:42 AM   #6
reddevil
Member#: 64673
1990 Legacy wagon
goes 12.387 @ 116.5
That kit is $9k or so. And you really really really wouldnt want to put it on an RS.
ANY kit you buy, supercharger or turbocharger, installed, is going to run you at LEAST $3K.
And void your warrenty.
Old 07-13-2006, 01:51 AM   #7
vwown3d
Member#: 69991
Leh Keen Approved
'68 Volvo Amazon
theres a guy who supercharged his na soobie. its around here somewhere, think he used a benz stock charger and made all the rest of the stuff himself.
vwown3d is offline   Reply With Quote
Old 07-13-2006, 01:53 AM   #8
reddevil
Member#: 64673
1990 Legacy wagon
goes 12.387 @ 116.5
Yeah, thats me.
$2000-2500
12 psi.
12 psi on your motor = boom
Your motor period = warrenty void.
And that $2000-2500 is for parts alone. Labour would be another $2-3k
Old 07-13-2006, 03:10 AM   #9
DadaAnd1
Member#: 119127
2011 2.5i
Spark Silver
People make custom ones but the are small and run at low psi's i'm selling one if you are interested for 1200 with complete exhaust n ecu
DadaAnd1 is offline   Reply With Quote
Old 07-13-2006, 03:16 AM   #10
J-Chow
Member#: 104722
2006 2.5i - SOLD
Gray
damn, that's a sexy b*tchin engine !
J-Chow is offline   Reply With Quote
Old 07-13-2006, 03:26 AM   #11
Paulsblackrs
Member#: 119732
05 rs
black
Oh yes they can.
THere is a kit somewhere for the sti. It uses the supercharger to get good low end, then a big turbo take over from there. It uses the same thought as a sequental twin turbo, which uses a small turbo that spools quickly and a larger turbo to create large boost at the high end.
Paulsblackrs is offline   Reply With Quote
Old 07-13-2006, 03:43 AM   #12
Handsdown
Member#: 29355
just to correct you, the STI runs something around 8:1... 8:2 would be the same thing as 4:1, which is ridiculously low and the air fuel mixture would have a hard time making any power at that pressure.
and basically you'll have to do internals to run any more than 5psi reliably, and even at 5psi if anything goes wrong you'll have bad consequences.
the crank and crank cradle are weak on our blocks. the redesigned heads might be better or worse, no one really knows because no one's done it on an 06 SOHC yet.
it's just not a good idea, when you can easily cheaply and reliably do a swap and make more power with a turbo engine.
Handsdown is offline   Reply With Quote
Old 07-13-2006, 09:24 AM   #13
deuce.five
Member#: 43800
NWR-SCCA Champ STS #22
8.2 compression ratio does not reduce down or simplify into 4:1.
That's what a compression ratio is, compressing 8.2 parts of a said volume down to 1 at top-dead-center.
I am still wondering what happened to Hamfist's supercharger set-up, it looked very nice and sounded very close to being a "kit".
deuce.five is offline   Reply With Quote
Old 07-13-2006, 09:58 AM   #14
03wagonlse
Member#: 91374
2003 Legacy Wagon
Timberline Green
If you look at the original post and what Handsdown wrote, it was 8:2 NOT 8.2
03wagonlse is offline   Reply With Quote
Old 07-13-2006, 10:56 AM   #15
Skidd
Member#: 1853
GC6 Supercharged
STM
There might never be an end to this "project", but there is a guy working on a SC kit for the 2.5NA. But.. he's been working on it for a hellofa long time. I'm wondering if it's ever gonna finish. Or if it even really exists.
http://www.rs25.com/forums/showthread.php?t=18187
Skidd is offline   Reply With Quote
Old 07-13-2006, 11:14 AM   #16
Jack
Add Lightness
Member#: 13699
2004 45k mile Outbac
(From General)
You can find an old Rimmer one, perhaps. I'll warn you about scams, however. I was considering one from a guy in Venezuela. I offered to meet him in Aruba and all of a sudden he can't get the time off or something like that.
MadMax in Connecticut has a supercharged RS. Check the NESIC forums for him to ask about it.
jack
Old 07-13-2006, 12:18 PM   #17
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
That's Gary, who goes by Hamfist here, and that kit will eventually come to market. He's working with Rimmer on it. I have one of Rimmer's old kits, that will be in my car "shortly". Anyways, head over to the correct forum and you can easily find both Reddevil's thread and Hamfist's thread on their respective projects...
Old 07-13-2006, 03:43 PM   #18
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
Whaddya mean "correct forum", Matt? Are you trying to say that there's an Aftermarket Forced Induction forum in which people could raise questions about adding an aftermarket supercharger (which is, of course, a form of forced induction) to their N/A cars? I call bull****!
Old 07-13-2006, 04:08 PM   #19
Skidd
Member#: 1853
GC6 Supercharged
STM
Surley such a place dosn't exist :P
And don't call me Shurley
Old 07-13-2006, 05:49 PM   #20
Matt Monson
Member#: 832
99 2.5RS, '85 911
Like how I subtly throw that in there while being informative. I try to avoid the "do a search, noob" and the "wrong forum, noob" approach. It nevers makes noobs feel very welcome...
Old 07-14-2006, 11:45 AM   #21
opious
Member#: 57718
99 Impreza OBS WGN
Silver now w/ 20mm rear!P
gotta love the leslie nielsen throw back, skidd!
opious is offline   Reply With Quote
Old 07-14-2006, 12:13 PM   #22
JoshP
Member#: 94350
the AVO turbo kit is a great setup IMO for $3500.
JoshP is offline   Reply With Quote
Old 07-14-2006, 02:01 PM   #23
Rally_wgn
Member#: 62629
1996 OBS in Green
2.5 N/A w/ full exhaust
To continue the wandering topic path, isnt VW using a twin charging setup in one of there cars. The twin charger setup looks like http://www.forcedairtech.com/ . Its like $10,000 for their stage 5 kit.
I'll wait til i do my Sti swap (in 2013 ).
Rally_wgn is offline   Reply With Quote
Old 07-14-2006, 03:51 PM   #24
powerlabs
Member#: 45790
2006 Corvette C6 Z51
SUPERCHARGED
If you wanted a forced induction Subaru you should have bought a WRX. Honestly; you have the heaviest, least horsepower Impreza Subaru makes right now. Also the ugliest. I can't stand the 2006 alfa romeo / kia nose, but that's just my personal opinion. If you bought a year or two older car, you could have bought the WRX.
I'm not saying this to flame you. My point is this: You will not boost your car for less money than it would have cost to buy a WRX. It just won't happen. And when you throw labor and tuning in there, then it really won't happen. Then you look at the reliability you'll get out of boosting an engine designed to be N/A and you'll see why so few people are doing it.
The only exception, in my opinion, is boosting older body style cars. But there again it turns out to be cheaper to swap in a turbo engine than to boost the N/A engine. I have an engine swap and it is definitely fast, but it cost me more than a 2002 WRX would have cost and it has all the issues of an older car. Actually it is a lot faster than an STI even. But it doesn't have an STI 6 speed, STI brakes, STI interior, etc etc... And if it did... It would probably have cost as much as an STI.
Moral of the story... Sell your car, buy a 2004 WRX.
powerlabs is offline   Reply With Quote
Old 07-14-2006, 03:58 PM   #25
josh04
Member#: 89288
2002 Rex
Their actually is a supercharger kit. It's made in australia, and it cost a little over 4k. But it only pushs 7-9 pounds. I can't remember were I found it but I was searching yahoo almost a year ago when i found it. Was looking for them, for a subaru outback.
josh04 is offline   Reply With Quote
Supercharger Kit For Sale - Complete Joncas Private 'For Sale' Classifieds 72 02-28-2004 07:49 PM
Supercharger kit for EJ25 engine Cajual Legacy Forum 7 03-05-2002 03:35 PM
Supercharger kit for EJ25 engine Suebee2 Forester Forum 3 03-04-2002 12:49 AM
Is there a turbo/supercharger kit for the 2.2? KaZ General Forum Archive 7 02-23-2001 12:41 AM
Guess who's making a Supercharger kit for Civics now (Subaru related content)...... MPREZYA General Forum Archive 5 11-23-2000 06:42 AM
