Old 07-13-2006, 01:34 AM   #1
ImprezaRSfan!
Member#: 13520
99rs ej207 spec-c
its for sale
Default high-reving built 2.0L
Anyone out there have a built 2.0L wrx or ej207 reving to 9k with a gt35r or such turbo? Does the oil system become a problem at a certain rpm? Ive thought a couple of times of putting in 272 avcs cams and springs/retainers in my ej207 and revving to 9k with my gt35r but im sure theres more variables than simple putting those parts in. Anyone have any ideas, thoughts, or usefull info ?
ImprezaRSfan! is offline   Reply With Quote
Old 07-13-2006, 02:13 AM   #2
senortighto
Member#: 51873
2006 purty blue STi
in my driveway
jun oil pump for oiling
senortighto is offline   Reply With Quote
Old 07-13-2006, 10:27 AM   #3
vlady
Member#: 77997
dirty blue
A dry sump system would work great for that application. As long as the rest of the motor was up to it (not just the valvetrain).
vlady is offline   Reply With Quote
Old 07-13-2006, 10:35 AM   #4
SubyDuz
Member#: 80432
69 IchhateinAudi
Blutrot
cosworth oil pump for oiling. Thats what I had to install in order to do it safely, and I use 264/272 cams, I have upgraded valve train and my goal is to rev to 9k
SubyDuz is offline   Reply With Quote
Old 07-13-2006, 11:07 AM   #5
InfamousDX
Member#: 25413
With an ej207... doesn't seem like much has to be done since it can rev over 8k regularly anyway. For oil pumps, cosworth or jun would be easy but having someone like Axis shim the pump is the same thing, and probably cheaper. Nice insurance would be to have the bottom end rebalanced and of course an upgraded valvetrain.
Old 07-13-2006, 12:07 PM   #6
ImprezaRSfan!
Member#: 13520
99rs ej207 spec-c
its for sale
interesting. So who makes spring/retainers for the ej207? I bet the jun and cosworth oil pump are expensive.
i wonder how high we could rev with just an upgraded oil pump on stock ej207 valvetrain. I remember reading ppl would go up to 8500 or so.
Old 07-13-2006, 12:09 PM   #7
wrxfactor
Member#: 49978
2002 WRX w/ JDM STi
6spd, EJ255, VF39 & EWG
I believe the JUN pump was like $800 or something like that.
wrxfactor is offline   Reply With Quote
Old 07-13-2006, 12:34 PM   #8
TheMadScientist
Member#: 23717
2005 Big red
Holy **** $800 for a shimmed oil pump.
Why not just use an EJ22T oil pump and reshim it?
Is that Jun one made of gold?
TMS
TheMadScientist is offline   Reply With Quote
Old 07-13-2006, 12:45 PM   #9
petawabit
Member#: 18978
96 brighton
05 AP2 ,09 GE8
I think the cosworth one is a reworked OEM one that flows more where the jun actually increases pressure(I think I read by 25%?). supertech makes a valvetrain kit for out cars as well as dpr and crower
petawabit is offline   Reply With Quote
Old 07-13-2006, 12:46 PM   #10
petawabit
Member#: 18978
96 brighton
05 AP2 ,09 GE8
anyone have a decently affordable dry sump that doesn't cost the price of a complete jdm v7+ motor?
Old 07-13-2006, 12:47 PM   #11
TheMadScientist
Member#: 23717
2005 Big red
The EJ22T oil pump flow more than the other EJ pumps as it has the oil squirters. By reshimming the pump you increase the pressure.
TMS
Old 07-13-2006, 12:50 PM   #12
petawabit
Member#: 18978
96 brighton
05 AP2 ,09 GE8
How many shims should one be using?
Old 07-13-2006, 12:52 PM   #13
TheMadScientist
Member#: 23717
2005 Big red
The person to really ask would be Ron over at axis.
I just installed one of his modified EJ22 pumps. I think people are adding 1 more shim to it.
TMS
Old 07-13-2006, 01:14 PM   #14
InfamousDX
Member#: 25413
Like I said, simple solution is buying the Cosworth for $240. It's just reshimmed already if you want no downtime.
Old 07-13-2006, 01:15 PM   #15
InfamousDX
Member#: 25413
I know 1 person locally that has taken it to 8600 on several occassions, basically beats the piss out of the car. Motor is still running, compression and leakdown are good. Obviously it's not recommended but this is a bone stock v7 ra-c.
Old 07-13-2006, 04:31 PM   #16
otaku_wrx2
Member#: 113574
2004 STI
kinda of a dumb question but would you rather drop in a ej207, usdm ej25, or a ej22t? thinking about swapping and making some decent power, just looking for a strong block to start with.
otaku_wrx2 is offline   Reply With Quote
Old 07-13-2006, 10:08 PM   #17
Soon2Bgreat
Member#: 2258
1999 gc8 ver7 6mt
GT35R 504.7whp;)
The thought had crossed my mind as well but i didn't for a couple reasons.
-Even with cams i think you'd need headwork to fully realize the gains
-I was skeptical about opening the motor up...there is alot to be said about OEM reliability and build quality imo.
As far as i saw it, the costs to do what i'd like to do right, made it not worthwhile anymore. If the motor was blown or had some spare heads to work on i'd have given it more consideration. The main downside to me was that for anything that wasn't a dedicated track car it wasn't worth it to me. Doesn't mean it won't be to you, just some food for thought.
IMO if you're going to build a motor, build it as a race motor all the way and treat it as such. Although i'm a proponent of adding forged pistons to an ej257 whilst leaving the rest of the longblock untouched.
Hope this helps.
Soon2Bgreat is offline   Reply With Quote
Old 07-14-2006, 12:14 AM   #18
InfamousDX
Member#: 25413
If I did it all over, I'd learn from people on nasioc and get an ej207 (ra spec c) and be done with it. OEM fit and finish are TOUGH to beat.
Old 07-14-2006, 10:01 PM   #19
otaku_wrx2
Member#: 113574
2004 STI
how hard is it to get one of those to work in a 02 wrx with avcs?
Old 07-15-2006, 02:38 AM   #20
senortighto
Member#: 51873
2006 purty blue STi
in my driveway
for the record, the jun pump isn't a shimmed oem pump, it is a new piece that flows 20% more than stock, and not just higher oil pressure. definitely a step above the cosworth pump which is just ported and polished a bit.
Old 07-16-2006, 12:57 AM   #21
wrxfactor
Member#: 49978
2002 WRX w/ JDM STi
The only way I'd throw out the $800 or so for the JUN pump was if I didn't give a **** because I was rich, or if I was building a motor to redline at 10k.
Built 2.0L to a 2.5L, what might be needed shemp321 Built Motor Discussion 3 02-28-2009 07:00 PM
Red or similar turbo on built 2.0l? japslapr Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 16 07-13-2007 03:42 PM
Fully built 2.0L or 2.5 Sti short block? jifnjelly05 Built Motor Discussion 11 01-18-2007 11:06 AM
charlottesville install: v6 STi heads / built 2.0L Lennon Mid Atlantic Impreza Club -- MAIC 26 05-03-2006 11:51 PM
Built 2.0L on stock block? Timdog1650 Proven Power Bragging 18 07-10-2004 08:59 AM
