Old 07-13-2006, 08:47 AM   #1
BNastyer
Member#: 116897
'07 328xi
Jet Black
Impreza WRX Accessport + SPT= Good or Bad?
Hey guys, just put the SPT intake in and yeah it's pretty sweet. I posted a thread about it under 2.5L turbo if you want to read it.
1)My question for the accessport guys is......how will stage 1 work out?
Just got a used accessport for my 06 (and yes it's been completely unmarried) but i'm wondering if i should remove the SPT and revert back to stock until cobb officially releases there statement on the compatibility or if i should just say f*%^ it and flash to stage 1.
2)I noticed a thread where a stage 2 guy posted ecu readings with his SPT. How do i do this (the accessport is coming in next week so haven't used the software yet) so i can post my readings to show you guys to make sure my 93 mapping will run ok?
BNastyer is offline   Reply With Quote
Old 07-13-2006, 10:18 AM   #2
Master2192
RIP 10/12/83 to 02/10/08
Member#: 83254
98 2.5 RS
04 WRX
Cobb does not recommend running intakes on their maps. They are testing the SPT intake but as far as I know they haven't told us anything yet. I would go back to stock while you are flashed stage 1, if you really want to use the intake you could get it protuned but I don't know if that'll really help.
for number 2, the Accessport doesn't allow you to take logs or read readings from the ECU. He most likely had a laptop and some other software to do this.
Old 07-13-2006, 10:22 AM   #3
BNastyer
Member#: 116897
'07 328xi
Jet Black
good info, thanks man
Old 07-13-2006, 10:25 AM   #4
Make7upyours728
Member#: 87652
2006 Toyota X-Runner
Radiant Red
i have spt intake on with stage 1, seems to be fine, but 4th and 5th gear sound really weird... like loud loud sucking when not a WOT...if that makes sence
Make7upyours728 is offline   Reply With Quote
Old 07-13-2006, 11:10 AM   #5
theicewall
Member#: 70532
2004 WRX
Cobb is currently doing "testing" to see if it will work on not. Do a search and you will see quite a few hreads discussing this before this one. In short, people have done so and the logs seem to be alright. Why don't you download openecu and do some logs for us if you are so concerned and we can check them out for you and then draw more generalized conclusions for the masses.
make7upyours728- of course that makes sense, you pulled out the resonator and put a short ram on. You are hearing the turbo, and since there is a long application of high boost under load you are hearing your turbo... be excited, that's what you bought the intake for since there isn't any hp gain without some custom tuning and a good heat shield.
theicewall is offline   Reply With Quote
Old 07-13-2006, 11:12 AM   #6
Make7upyours728
Member#: 87652
Radiant Red
now i thought only the high pitch scretching type sound (sim to a whistle) was boost. or is all the weird belching sounds turbo noises too?
Old 07-13-2006, 11:20 AM   #7
BNastyer
Member#: 116897
'07 328xi
Jet Black
i'm still waiting for the accessport in the mail but when it comes in i will log some data, thanks for the help
Old 07-13-2006, 11:51 AM   #8
theicewall
Member#: 70532
2004 WRX
Generalized suction noises are from the turbo.... you should hear a regular sucking sound, plus a high pitched whistle. There are resonance frequencies that cause constructive interference that were cancelled out by the factory intake box. Im not sure exactly what you mean by belching, but if it happens upon releasing the throttle its your recirculating bypass valve which should sound like a pressure release of sorts. On partial throttle there should be a fluttering sound that you will hear much more so if you have an up or downpipe... but its basically a real quick ffthhhh ftthhh fffthh fftthh (10x fast) which is your wastegate flapper of the turbo.
Old 07-16-2006, 10:11 AM   #9
doylfish
Member#: 88099
2004 Audi S4
2003 Suzuki SV1000S
i've been trying to figure out and answer the question of the SPT Intake on Cobb Stage 2 myself.
doylfish is offline   Reply With Quote
Old 07-16-2006, 11:40 AM   #10
-Kevlar-
Member#: 82378
i have stg2 w/ the spt intake and all is well... ive done some datalogs and have a seperate thread in this section.... also check product reviews for more satisfied people....
the Cobb intake is "approved".... how convenient...
and that was probably my thread the OP was talking about... there is a free datalogger available for download in this forum in the stickies... download it to a laptop and plug in the AP cable to the laptop and start logging.
-Kevlar- is offline   Reply With Quote
Old 07-16-2006, 11:17 PM   #11
doylfish
Member#: 88099
2004 Audi S4
2003 Suzuki SV1000S
anyone know if the APS pod air intake is compatible with Cobb Stage 2 and have the numbers/sheets to prove it?
Old 07-16-2006, 11:26 PM   #12
theicewall
Member#: 70532
2004 WRX
I dont believe the APS is. I have read numerous posts about how difficult it was to get a good protune with the APS intake, but it can be done. So my best guess is that you would definitely want a protune in order to run that.
Old 07-18-2006, 09:38 PM   #13
BNastyer
Member#: 116897
'07 328xi
Jet Black
Well, Stage 1 is up and running with the SPT.....throttle response is immediate and the car boosts sooner as well. I can notice a difference particularly in third (it pulls as hard as 2nd did before the flash!) so i would say it is all worth it. SPT sounds great still too.......i spoke with a few people in the business of tuning and they reccomend i run a Stage 1 91 octane mapping so my car doesn't run too lean with the aftermarket intake. I have a base 91 map and switch 93 realtime on when its go time. To help prevent any knock at all i run 93 octane through the car at all times. I swear it improves my gas mileage and performance enough to justify spending the extra couple of cents per gallon.
Old 07-18-2006, 09:55 PM   #14
Steveee
Member#: 103940
Yes, the intake will help because it will be protuned for it. Shelf maps are tuned for specific parts. Stage 1 and 2 are not for intakes. None of the shelf maps are. I've seen good protuners pull nice numbers with just an intake and dp so yes, I believe intakes can help. I do not recommend a shelf map with an intake though. Just hold off for the tune.
Steveee is offline   Reply With Quote
Old 07-19-2006, 02:34 AM   #15
-Kevlar-
Member#: 82378
what about the cobb intake...
Yokohama A520 good or bad tires? STi - IMPREZA Brakes, Steering & Suspension 16 06-05-2001 09:27 AM
42 offset, KONIG toxin's....good or bad?? SuBaRu-ImPrEzA_RS Brakes, Steering & Suspension 13 05-20-2001 02:17 PM
Speed Bleeders - good or bad? aowRS Brakes, Steering & Suspension 18 05-14-2001 09:07 PM
('93-'01) Hood deflector...looks good or bad?... Hoomsy Impreza Forum 20 04-23-2001 12:01 AM
UR pulley? good or bad?? IMPREZA GUY New England Impreza Club Forum -- NESIC 3 03-23-2001 11:29 AM
Message Board Statistics All times are GMT -4. The time now is 06:26 AM.
