Old 07-13-2006, 11:19 AM   #1
subbieroo
Member#: 120034
Default More EJ25 problems
So bought a RS with 2.5L EJ25. I was aware of the head gasket problems before hand and I actually bought it cheap with the blown driver side gasket since they didn't want to have it fixed and I knew I could do it myself. So, stripped the motor down, replaced the gaskets put everything back together. Everything is torqued right, no parts left over no bolts left over, wiring harness connections are all made. Go to turn it over last night and it just cranks. Will not fire up. Fuel Pump is connected i can here it turn on. Turned the key on and off a few times to prime the lines still won't start. Any ideas? I know its getting gas, I haven't checked to see if the pack is getting a spark down the wire yet though. Anything weird about this motor I should know that needs to been done after reinstalling everything that could be keeping it from starting? This is the first subaru I've owned so any help or tips would be great. Thanks.
Sam
subbieroo is offline   Reply With Quote
Old 07-13-2006, 12:01 PM   #2
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
I am going to guess that you reversed the location of the fuel lines from the filter to the rails. That's the easiest thing to mix up...
Old 07-13-2006, 12:03 PM   #3
subbieroo
Member#: 120034
Anyone got a pic I use for reference where these are hooked up in the correct order?
Old 07-13-2006, 12:03 PM   #4
Hayes
Member#: 11808
Ignition is triggered by a sensor on one of the camshafts. Is it connected?
Hayes is offline   Reply With Quote
Old 07-13-2006, 12:08 PM   #5
subbieroo
Member#: 120034
yea driver side, its connected i checked that and the crank sensor right off
Old 07-13-2006, 04:06 PM   #6
subbieroo
Member#: 120034
got it. return line and the other were mixed thanks guys!
Old 07-14-2006, 02:48 AM   #7
Storm
Member#: 5218
96L Most Over-
Developed Beater
I love the easy fixes.....Congrats on a good cheap(er) car!!!
You'll love it even more if it snows where you are!
Jay
What are typical ej25 problems? NapaBavarian Subaru Conversions 3 01-08-2010 03:11 AM
newby with strange ej25 problem porscharu Legacy Forum 5 07-01-2005 07:58 PM
98 RS Phase1 EJ25 problems?? ImprezaRSfan! Newbies & FAQs 1 11-10-2002 08:45 PM
more turbo problems kastle Normally Aspirated Powertrain 13 02-09-2001 09:34 AM
more alarm problems.... soob2k Car Audio, Video & Security 4 01-05-2001 02:16 PM
