Old 05-03-2001, 09:48 AM   #1
MY99 2.5GT
Member#: 5030
1999 Legacy 2.5GT
12 Legacy GT 13 Armada
Post Whats the largest sway bar that will fit a 99 Legacy GT?
I want upgrade my sway bar on the Legacy. It currently an 18mm. I want to stiffen the rear up to get a little bit more of a steer happy ride without messing with allignment and camber settings.
What is the largest bar that will fit a 99 Legacy GT? Brand? Price? Where to buy?
Thanks
Brad
MY99 2.5GT is offline   Reply With Quote
Old 05-03-2001, 10:54 AM   #2
Subie Gal
GC84Ever
Super Moderator
Member#: 301
1970 FF-1 & '70 Van
02 WRX/01 RS
Exclamation
check out my Legacy Tuning page on my site..
i know i have some info and links in the "suspension" section...
j. www.subiegal.com
Old 05-03-2001, 11:26 AM   #3
MY99 2.5GT
Member#: 5030
1999 Legacy 2.5GT
Post
Thanks SubieGal. I like the Cobb 19mm-21mm adjustable sway bar. I want to ge the Whiteline End Link Mounts also.
I have a question about something. I am looking at the Cusco Rear Bar. It says it stiffens rear crossmembers. What does this mean and will it help the Legacy to want to overstear a little?
Thanks
Brad
[This message has been edited by MY99 2.5GT (edited May 03, 2001).]
Old 05-03-2001, 01:44 PM   #4
Subie Gal
GC84Ever
Super Moderator
Member#: 301
1970 FF-1 & '70 Van
02 WRX/01 RS
Wink
it may help a wee bit...
but remember this... the wider base of the GT makes it harder to oversteer... harder to get it to turn in.. it wants to plow...
your almost better off w/NO sway bar if that's what you want1 <<laff>>
hehehehe
j. www.subiegal.com
Old 05-03-2001, 03:00 PM   #5
SYMS GT
Member#: 427
'91 SS Legacy EJ257
DOHC/18g/FMIC/V.8 6spd
Post
Subie Gal; don't you mean no front sway bar!! If you removed the rear you'd plow all day.
I've had great luck with SPO's rear sway bar kit. I got a pre-production kit that's just a 20mm. and it works great!! I believe it'sa adjustable up to either 22 or 24mm tho. This kit comes with everything too; bar, bushings, HD links and mounting system.
Now my car with all it's mods handles beautifully. With my alignment settings H&R/adjustable KONI setup. Balanced drifts on the track are performed easily/wonderfully.
Warning: Remember you muct be able to control the car in a drift/emergency situation!!
-Matt
SYMS GT is offline   Reply With Quote
Old 05-04-2001, 05:27 PM   #6
SYMS GT
Member#: 427
'91 SS Legacy EJ257
Post
Yes this was a couple years back.
-Matt
Old 05-05-2001, 12:29 AM   #7
MY99 2.5GT
Member#: 5030
1999 Legacy 2.5GT
Post
Drift control I'm fine with. I have a little experience with a rear wheel drive car in the rain and on a wet circle track. My worry is the stupid understeer. If I get into an emergency situation I'd rather be able to make an evasive move and work into a comfortable drift and hope to get out of the way rather than an uncorrectable understeer where I'm just plowing away. So the Spo kit came with links. Cool. I'll check that out. Yousaid it was preproduction? Are they in production now that I could buy it?
Thanks
Brad
Old 05-05-2001, 08:01 AM   #8
lucien2
Member#: 1519
1998 Volvo V70R
Post
here is a related question:
I am picking up a used 1999 Legacy GT sedan this week (can't find a 5MT wagon within 100 miles ). In the garage is the stock 18mm bar off my OB, which I replaced with a whiteline 18-22. No, I am not going to remove that- the OB is so sweetly set up right now, and my wife likes it a little tail happy.
SOOO- shall I put that stock 18mm bar on the GT (which comes with what, 15mm?) or spring for another whiteline? I won't be doing any suspension mods other than a front tower brace for a while.
lucien2 is offline   Reply With Quote
Old 05-05-2001, 09:28 AM   #9
SYMS GT
Member#: 427
'91 SS Legacy EJ257
Post
Do it!! It's cheap and easy. Yes the stock bar is only 15mm on the GT. If you'd actually want/need more for the rear you can simply sell the 18mm for an easy ~$60.
What could it take, 15min to install to see if it's benifical or not...
Old 05-06-2001, 06:15 PM   #10
lucien2
Member#: 1519
1998 Volvo V70R
Post
'kay. Should have the car this week. I'll slap that OB oem bar on there and see what happens...
Old 05-07-2001, 05:25 PM   #11
rrubel
Member#: 4643
2008 Legacy Outback
Atlantic Blue Pearl
Post
Actually, the stock GT bar is 16mm - it's a good replacement for an L or LS. I did exactly what you're contemplating - put the whiteline adjustable on the OB, put its 18mm on the GT, sold the GT's 16mm to an LS owner for about $35. The GT handles much better (but does tramline more) and isn't at all squirrely in the rain.
rrubel is offline   Reply With Quote
Old 05-07-2001, 08:51 PM   #12
Velocity
Member#: 2205
1998 Legacy L Wagon
Deep Sapphire Blue
Post
I'd be willing to buy someone's used rear swaybar. My '98 L wagon could always use it. Although I find the turn-in is actually *better* (perhaps because of the manual tranny & different torque split?) than that of my '97 GT Sedan.
Shipping it would be a waste of money though...
Velocity is offline   Reply With Quote
What is the newest center driveshaft that will fit 93-01 mt imprezas? 2slofouru Subaru Conversions 1 06-04-2009 08:21 AM
Whats the biggest size gauges that will fit in the OEM dash pod? mjd85la Electrical & Lighting 1 01-31-2006 08:34 PM
Will This Fit My 99 Legacy GT? Ykobayashi Legacy Forum 3 01-11-2004 07:13 PM
what is the 1/4 mile time for a stock 99 legacy gt zx2boy Legacy Forum 7 04-11-2001 12:27 AM
NE1 know if 215s will fit a stock Legacy GT rim? gtguy Brakes, Steering & Suspension 11 12-09-2000 06:52 AM
