Old 07-13-2006, 04:16 PM   #1
benw
Member#: 103320
1998 swapped
Forester L
Default question regarding knock event on STi
Car is 05 STi, installed Invidia bellmouth DP and N1 catback and the car was flashed to AP stage 2. However I only make ~15 psi in 4th gear and barely 16 in 5th. Shouldn't I be at 17 or maybe a bit more?
Unrelated, I did a datalog and my knock correction was 5-6 until 4,000 when it went down to 1. Then around 4500 it climbed back up to 5-7. Is this a knock event I should be wary of?
benw is offline   Reply With Quote
Old 07-16-2006, 05:57 PM   #2
JOWEE
Member#: 103092
06 sti
steel grey
I have the same setup on my 06 and the car was detonating, the cure was a custom tune.when i was getting ready to leave another sti was having the same problem. I am still having a problem with hesitation between 2500 and 3000rpm at very lite throttle.As far as boost i run 18.5 psi and taper back to 15 by redline on 93, and on 100octane 21.5 psi.
JOWEE is offline   Reply With Quote
Old 07-16-2006, 06:09 PM   #3
06rexwagon
Member#: 114730
2006 WRX Limited Wag
[email protected]
If you're not seeing negative knock correction, you should be ok. The car is doing what it is supposed to do.
06rexwagon is offline   Reply With Quote
Question regarding newer tires on rear with less tread on front??? Nettalp Tire & Wheel 4 08-28-2009 10:57 AM
Question Regarding General Modification on O6 Impreza WRX TR faheyr12 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 18 10-24-2006 05:12 PM
Important question regarding current events. rogue Off-Topic 4 09-03-2005 11:01 AM
Questions regarding first mods on an 05 STI. zasy99 Newbies & FAQs 25 05-24-2005 12:52 AM
UTEC map question -regarding knocks and lean ndw1138 Engine Management & Tuning 4 02-25-2003 07:04 PM
