Old 07-13-2006, 06:37 PM   #1
Subaru69
Member#: 117676
Default 02 WRX Car Sputtering Issue
Hello.
I have a 02 WRX 5sp. First off, no modification at all.
I am currently having an issue whenever im driving in any gear usually between 2k-3.5k when i am cruising I can keep hearin the blow off valve randomly sputtering. Its as if i was venting to atmosphere randomly. Keep in mind this is a stock bov. When i am accelerating it happens in a stronger force as it will give a kick back dropping 100rpms and you can feel the jolt back.
I was thinking at first spark plugs one not firing, but that cant be true due to the fact that i am hearing the bov vent randomly.
As for the sound. Itsa typical vent type sound as you would hear during a shfit with a bov venting to atmosphere. However it does this while im in a gear say 3rd gear at 2.5k it sporaticly blows off and jolts the car.
I just got this car, i have had it for a week. Any Help would be appreciated. Thanks guys.
Subaru69 is offline   Reply With Quote
Old 07-13-2006, 07:08 PM   #2
MarylandEcstasy
Member#: 103518
2011 Subaru WRX
Mmm.. have you checked all connections, all bolts on the BPV, T fitting?? Does it sound like a monkey dying in your engine bay when you raise rpm levels?
MarylandEcstasy is offline   Reply With Quote
Old 07-13-2006, 07:22 PM   #3
Subaru69
Member#: 117676
haha nope.
It sounds like im intentionally blow ing off. Yet im staying at the same rpms.
Old 07-13-2006, 07:32 PM   #4
MarylandEcstasy
Member#: 103518
2011 Subaru WRX
Ok, I'm going to say that I've had this before once, and it was because I accidentally unhooked a vaccuum line from the BPV to the intake manifold when I installed my boost gauge. Doing so caused the car to make uneven rpm levels and made flutters, like what you hear from wastegate flutter. Again, check your lines..all of them..it has to be a leak of some sort...................if not, then go to your Subaru dealership and get your fix. Are ya still under warranty?
Old 07-13-2006, 09:13 PM   #5
Subaru69
Member#: 117676
bought it last wednesday. Im under warranty for like 7 more weeks. Only BS is the fact they want a 100 dollar deductible.. even thought i bought it last week!
Old 07-13-2006, 09:19 PM   #6
AWD>FWD
Member#: 107027
2007 SWP WRX STi
w/MPS-built 2.34l
Well, go in there and tell them you bought a car last week and you want to have a working car!
AWD>FWD is offline   Reply With Quote
07 Sti Engine in 02 WRX cam sensor issue obrut Subaru Conversions 1 04-19-2009 12:06 AM
05 Cluster-02 WRX. LOTS of issues yankdanger Electrical & Lighting 5 02-19-2009 04:15 PM
02 WRX Clutch install issue Soulofdarkness Transmission (AT/MT) & Driveline 6 07-29-2008 05:24 PM
02 wrx alarm remote issues wrx=happy Car Audio, Video & Security 0 06-28-2007 09:35 PM
Need help with 02 WRX engine sputtering 95 avus blue Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 09-09-2005 09:51 AM
