Canada Region Club
Go Back   NASIOC > NASIOC Regional Areas > Canada Region Forum > Western Canada
Old 07-14-2006, 04:26 AM   #1
Airboy
Member#: 72829
2006 WRX
2015 WRX
Default Cobb downpipe installation (some pics)
The package from Rally Subaru finally made it to Calgary ( had to pick it up at the depot because Jeremy wrote Ave instead of Street on the label). Took a few hours but got it done. The alignment of the downpipe is spot on.
Wrapped the whole thing in thermal wrap. Don't know how the bottom part will stand up to road debris but since I had a 50' roll...
The silicon sealant smokes pretty good and smells like...toast?
Now I just have to wait for the effect of AP Stage 2 to kick in
Airboy is online now   Reply With Quote
Old 07-14-2006, 08:12 AM   #2
future_GDB
Member#: 110135
2005 STi
looks good - thats the catted one correct?
You still with the stock catback? If so, how did the downpipe mate with it?
future_GDB is offline   Reply With Quote
Old 07-14-2006, 08:56 AM   #3
Flexx999
Member#: 36302
2006 Big 16G WRX
Addicted to Blue
Should have stopped at the bend with the wrap. Paul (ex- Rally mechanic) said he has seen a few done like that and it doesnt last long as the bottom gets so chewed up it just starts to peel all the way up the downpipe. He said to make sure you stop at the bend.
Looks good and hope it stands up for ya.
Flexx999 is offline   Reply With Quote
Old 07-14-2006, 09:25 AM   #4
easternwrx
Member#: 28588
2003 WRX Wagon
Yellow
I have a silly question : What is the purpose of the heat wrap on the down pipe? I can see why the up pipe would benifit from heat wrap.
easternwrx is offline   Reply With Quote
Old 07-14-2006, 10:29 AM   #5
Flexx999
Member#: 36302
2006 Big 16G WRX
Addicted to Blue
to keep the heat in plus to try and keep under hood temps down to......dont know if the benifit is huge but its a cheap easy thing to do before the install....so any benefit is easy to acheive.
Old 07-14-2006, 11:56 AM   #6
Airboy
Member#: 72829
2006 WRX
2015 WRX
Yes, it is the catted version...wanted to keep at least one cat. I have the stock cat-back. It mated up perfectly without any fuss, using the stock donut gasket.
Old 07-14-2006, 12:01 PM   #7
Airboy
Member#: 72829
2006 WRX
2015 WRX
Probably should have but I had that big roll of thermal wrap, I just couldn't help myself once I started Maybe I could add a couple of sections of metal heatshield and attach it with some hose clamps. Would galvanized sheet metal hold up?
If nothing else, I could add a couple of hose clamps to help keep it from unraveling.
Old 07-14-2006, 12:06 PM   #8
Airboy
Member#: 72829
2006 WRX
2015 WRX
Yeah, it was a now-or-never type situation. It should provide some sound insulation as well.
I'll trim the stock heatshield and put that back as well to keep the heat out of the engine bay.
Old 07-15-2006, 11:31 AM   #9
Flexx999
Member#: 36302
2006 Big 16G WRX
Addicted to Blue
Putting some extra clamps on it would probably really help if it starts to come apart. I dont know if I would try to rig the heat sheilds back on it again though. They will probably just rattle and annoy the hell outta ya.
If you dont want to cut the turbo heat sheild, cobb makes a really nice one that fits over the larger downpipes. Im putting mine on today
Old 07-15-2006, 12:36 PM   #10
pitwipe
Member#: 88738
2005 WRX
I cut the stock heat shield and put it back on. Had to cut a fair chunk off it though. Cutting instructions were in the downpipe installation guide.
pitwipe is offline   Reply With Quote
cobb downpipe install whistling noise? 17.5 psi on perrin stage 2 91 broncofangene AccessPort 17 07-27-2009 02:50 PM
Installed Cobb downpipe tonight.. jobber Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 20 01-24-2008 08:23 PM
Just finished installing an uppipe and race downpipe, got some questions dauss Newbies & FAQs 54 05-27-2007 03:58 PM
Might need some help with Cobb AP install (Portland Area) Dark Baal North West Impreza Club Forum -- NWIC 5 03-04-2005 11:47 AM
TXS Downpipe installed... getting some noises... rogue Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 13 01-28-2004 09:33 AM
