Old 07-14-2006, 10:14 AM   #1
ScoobySnacker
Member#: 105303
2003 WRX
Default Tell me how to do a boost leak test? PLEASE!!
I have posted this about a week ago, with no good answers. How do i do a boost leak test? i have the home-made boost leak tester. I clamp it to the inlet of the turbo, plug the 4 ports on the inlet and try to pressurize it. IT WILL NOT WORK!! The system wont even get 1psi in it. What am i doing wrong? PLEASE HELP ME!
ScoobySnacker is offline   Reply With Quote
Old 07-14-2006, 10:19 AM   #2
benw
Member#: 103320
1998 swapped
Forester L
did you plug the lines coming off the turbo inlet?
benw is offline   Reply With Quote
Old 07-14-2006, 10:44 AM   #3
2ndGearFling
Member#: 64466
05, STI on green
Research....it takes quite a while for the system to pressurize. Just make sure you have everything plugged.
2ndGearFling is offline   Reply With Quote
Old 07-14-2006, 12:23 PM   #4
ScoobySnacker
Member#: 105303
2003 WRX
Yes, i have plugged them..There are 4, right? I have researched to no end..I thought that i had done something wrong, but i guess i need to put more pressure in it.
Old 07-14-2006, 12:45 PM   #5
Paulie V
Member#: 10260
2002 WRX Sedan
PSM- Knock, knock :-(
Like I said in your other post, start with a an air tank ALREADY PRESSURIZED (15-20 psi- don't over do it), discharge it directly into your intake tract and listen for leaks. It'll take forever to hook up a compressor and just run it. And if you do have a leak, it probably won't pressurize at all and the compressor will be too noisy to hear anything anyway.
And you don't need to disconnect and plug up the lines coming off the intake, as long as you don't put too much pressure in there.
Paulie V is offline   Reply With Quote
Old 07-14-2006, 01:16 PM   #6
ScoobySnacker
Member#: 105303
2003 WRX
I have been starting with a pressurized tank. I took it off the "AUTO" mode so it will not turn on while pressurizing. I pump about 30sec of air in it and still it did not put pressure in the system, and no sign of leaks. If i dont plug the lines on the inlet, wont i be pressurzing the crankcase? Thanks for the help.
Old 07-14-2006, 11:14 PM   #7
Paulie V
Member#: 10260
2002 WRX Sedan
I'm confused. Where are you reading the pressure that you're saying you're not pressurizing the system? What are you pressurizing your air tank up to? If you've got 15 psi or so in the tank, and you hook the discharge hose up to your valve stem in your leak tester, then you'll be pressurzing your intake system. Are you attaching it to the tester and immediately see your pressure gauge drop quickly? Are you sure your leak tester isn't leaking? At 15-20 psi, you should definately be able to hear any air leaks.
And 15-20 psi shouldn't hurt your crankcase, just don't go crazy. It would be safer to block off the ports, but you won't be seeing if you have any leaks in the pcv system. Are you trying to test an intake leak or a boost leak? If you just suspect a boost leak, you could eliminate the whole pre-turbo intake tract and just test after the turbo.
Old 07-14-2006, 11:51 PM   #8
big geek
Member#: 76732
Sea-Foam works well to look for an exhaust leak. Just found my uppipe leak after a little sea-foam.
big geek is offline   Reply With Quote
Old 07-15-2006, 12:00 AM   #9
Smoby
Member#: 97642
2002 Wrx Sedan
MBP
Post a pic of your leak tester and see if that is your problem.
Smoby is offline   Reply With Quote
PLEASE tell me how to spell absinenth captaind Off-Topic 84 11-28-2008 08:26 PM
wii friends setup, AKA tell me how to do this so i dont have to read the manual [27] Off-Topic 5 03-04-2007 04:51 PM
anybody tell me how to clear limp mode please? (on the car) JC_595 Mid West Subaru Owners Club Forum -- MWSOC 6 09-19-2006 05:20 PM
i love when non-programmers tell me how to do my job. kbcr3 Off-Topic 32 08-11-2005 04:07 PM
Can someone PLEASE tell me how to post pictures on here? JasonRan General Forum Archive 6 06-08-2000 08:36 AM
