Old 07-14-2006, 02:50 PM   #1
Krmnnghia01
Member#: 95080
Default Need assistance from the windows/PC gurus out there!
I am trying to find a simple program that can basically give me the following data but in a better format...
Dir /S /B /A-D > "X:\Path to Output File\File.txt"
This will povide me with the path and the file name but not the file size. Plus its in the most simplest form which excel hates. Anyone know of a program to simplify this? Possibly dump to Excel?
Thanks guys
Krmnnghia01 is offline   Reply With Quote
Old 07-14-2006, 11:41 PM   #2
Jessie James
Member#: 2072
You want something to give you a directory listing?
I googled up something like Directory Lister or the likes and found 22,000 matches. Sorry, no link right now, but it's out there.
Jessie James is offline   Reply With Quote
Old 07-15-2006, 12:33 AM   #3
mexicanpizza
Member#: 16779
2008 God's Gift to
Turbo Wagons (MS3)
Dir /S /N /A-D > "X:\Path to Output File\File.txt"
If you open from within excel, and import with Space delimited, that will give you the directories, filenames, and filesizes. With some excel formula's in a couple columns off to the right you can clean them up pretty easily.
mexicanpizza is offline   Reply With Quote
Old 07-15-2006, 02:16 AM   #4
JScoob
Member#: 48163
2003 wrx
No that won't work if folders and files have spaces in them, which most likely they do - "Documents and Settings" for example. Plus the filenames don't have their fullpath. I don't think you can do it with a DOS dir and but you can in *nix, ie linux:
find . -printf "%p\t%s\n"
If you're on windows, download cygwin from www.cygwin.com - this will give you a unix like environment on windows. Open a cygwin window and type
cd c:
or whereever you want to start your file listing from.
followed by the above "find" command. You will get recursive listing of every file from where you are, with the file size in bytes, delimited by tab.
JScoob is offline   Reply With Quote
Old 07-15-2006, 02:27 AM   #5
aod
Member#: 7121
Or if you wanted to do , delineated you could run this command in cygwin:
ls -alR |awk '{print $6 " " $7 " " $8 "," $5 "," $9}'
Output would be like:
Jun 28 2005,136480,suspic.wav
Jun 28 2005,214370,virfound.wav
Jun 28 2005,95496,vpsupd.wav
aod is offline   Reply With Quote
Old 07-15-2006, 03:03 AM   #6
bobturismo
Member#: 42145
6-4 jockin da bish-
es and slappin the hoes.
I type words, YEAH!!!
bobturismo is offline   Reply With Quote
Old 07-15-2006, 08:34 AM   #7
Krmnnghia01
Member#: 95080
Awesome guys thanks for the help!
Old 07-15-2006, 11:36 AM   #8
mexicanpizza
Member#: 16779
2008 God's Gift to
Turbo Wagons (MS3)
cd c:
Uh....the extra spaces are nothing that a =concatenate can't fix.
Need assistance from the NWIC group 06_Aspen_STI North West Impreza Club Forum -- NWIC 1 05-31-2008 07:38 PM
need help from the compression ratio gurus mellow65 Built Motor Discussion 1 10-26-2007 05:19 AM
Cobb Tuning needs to ask for some assistance from the locals... Christian. Rocky Mountains Impreza Club Forum -- RMIC 0 01-30-2006 05:57 PM
Need help from the computer geeks out there. DreamingOfBoost Off-Topic 9 10-18-2004 01:55 AM
Need some help with my car from all the tech Gurus out there JDM5LugHatch Mid Atlantic Impreza Club -- MAIC 0 07-01-2003 10:07 AM
