Old 07-14-2006, 10:32 PM   #1
tcspeer
Member#: 113319
1997 Subaru Legacy
Green
Default soft brake pedal
I bought a used 98 legacy wagon and the brakes were shot on it. I have replaced shoes and pads, and also rear wheel cyclinders but the pedal is still soft even through the car stops pretty good. I thought a new master cyclinder would fix it so I replaced it but it did not change anything, any suggestions? I have bleed the master cyclinder and the brakes still have soft pedal.
tcspeer is offline   Reply With Quote
Old 07-14-2006, 10:56 PM   #2
nate49509
Member#: 22452
2016 WRX
With everything you've done they should be fine. Is this your first Subaru? You may not be used to the soft feel of most Subaru's brakes.
You could also try steel braided lines and the master cylinder brace.
nate49509 is offline   Reply With Quote
Old 07-14-2006, 11:21 PM   #3
MonsterRallySport
Member#: 104148
MRT Spur cut with
Rocket center Diff.
With the car off, pump the pedal 20 times. If you are able to pump the brakes the full 20 times without hardening, you probably still have air in the system.... If it gets hard after 5-8 times your fine.
MonsterRallySport is offline   Reply With Quote
Old 07-14-2006, 11:33 PM   #4
tcspeer
Member#: 113319
1997 Subaru Legacy
Green
No I also have a 97 Legacy wagon and the brakes are very firm and good on it. Both of these are right hand drive postal wagons and the brakes seem fine except when I change from one car to the other, it is then easy to know the brakes are not quite right on the 98.
Old 07-14-2006, 11:36 PM   #5
tcspeer
Member#: 113319
1997 Subaru Legacy
Green
I will check this, I was planning on taking them to Midas to have them pressure bleed them, but I dont think they have air in them.
Soft Brake Pedal YooperBaja Baja Forum 7 06-03-2007 02:41 PM
Soft brake pedal DiscoGsus Brakes, Steering & Suspension 3 10-19-2006 03:20 PM
soft brake pedal scuby Brakes, Steering & Suspension 3 10-26-2004 03:01 PM
soft brake pedal 4x4x4x5 Brakes, Steering & Suspension 7 01-10-2001 10:50 AM
Soft Brake Pedal Frey Brakes, Steering & Suspension 6 10-17-2000 09:51 AM
