Old 07-14-2006, 11:50 PM   #1
JDM-STI
Member#: 101256
2005 STI
CGM
Default Anyone use an '04 STI ECU in an '05 STI???
I know that there are a few pins that are different. 5 to be exact. Switching those are easy. Main reason I'm considering this is because my car doesn't want to go into open loop when its supposed to. It goes too late. This has started to become a common problem on some '05+ with big turbos. Ecutek and Cobb hasnt been able to find a fix for it. All '04's hit open loop right when it should everytime. So I'm exploring my options. I wonder how our key chip would be affected using an '04 ECU (which doesnt require one). Any and all input will be appreciated.
JDM-STI is offline   Reply With Quote
Old 07-15-2006, 01:08 AM   #2
chuckdez
Member#: 120187
2005 STI
Obsidian Black Pearl
Wouldn't there be a immobilizer issue?
chuckdez is offline   Reply With Quote
Old 07-15-2006, 05:32 AM   #3
Brydon
Member#: 107569
1998 Forester S
SRP
You can't use it unless you rewire alot of stuff!
Brydon is offline   Reply With Quote
Old 07-15-2006, 08:39 AM   #4
JDM-STI
Member#: 101256
2005 STI
CGM
It would have an Ecutek tune for my big turbo/meth. Ecutek hasn't been abe to solve my current issues on the '05 ECU. Been waiting on a fix for 2 months or so now.
Yes, the immobilizer has been thought about. I'm have the understanding that the immobilizer in the key communicated with the ECU. If there is an '04 ECU in there, I would think the immobilzer would not be a factor. Thats just my thinking anyway...
Old 07-15-2006, 10:31 AM   #5
Cocoa Beach Bum
Member#: 17355
I say: "Go for it, JDM-STI." And please let us know the results.
Cocoa Beach Bum is offline   Reply With Quote
Old 07-15-2006, 11:47 PM   #6
JDM-STI
Member#: 101256
2005 STI
CGM
Easy for you to say...
Old 07-16-2006, 12:28 AM   #7
chuckdez
Member#: 120187
2005 STI
Is the 05 ECU stock or has it been reprogrammed via Cobb or EcuTek?
Old 07-16-2006, 04:14 AM   #8
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
...stop thinking
Old 07-16-2006, 03:01 PM   #9
chuckdez
Member#: 120187
2005 STI
Well there is a feature in the ECU programming called Closed Loop Delay. Possibly changed with a ECU reflash.
Old 07-16-2006, 03:21 PM   #10
Uncle Scotty
Member#: 16200
OK buy Nates beans
NON- issue with the STi
Old 07-16-2006, 06:49 PM   #11
JDM-STI
Member#: 101256
2005 STI
CGM
Originally Posted by Uncle Scotty
...stop thinking
Well...
What are your thoughts on this????
Old 07-16-2006, 06:50 PM   #12
JDM-STI
Member#: 101256
2005 STI
CGM
My tuner has tried everything under the sun without any success. Ecutek has no solutions either.
Old 07-16-2006, 08:10 PM   #13
JRSCCivic98
Member#: 67080
^^^ There are no fueling delays in the STI OEM tune. The STI is exempt from the EPA mandate that the WRX falls under. I'm going to verify this right now to make sure I'm not making stuff up, but I know this is absoutely true for the 04 STIs.
*Edit*
Yep, every single "Open Loop" setting in the 04 and 05 USDM STI ROMs are identical.
JRSCCivic98 is offline   Reply With Quote
Old 07-16-2006, 10:09 PM   #14
JDM-STI
Member#: 101256
2005 STI
CGM
*Edit*
I'm not on an OEM tune. I am running a FP Red/Meth with all the supporting mods. The car is supposed to go to open loop at 2.5 MAF volts. Mine wont go till 3 volts. This causing some serious negative correction in my long and short term fuel trims. This problem has only been seen so far on '05+ STI's with big MAF/big turbo set ups.
Old 07-16-2006, 10:28 PM   #15
JRSCCivic98
Member#: 67080
No kidding. You're more then likely on EcuTek and tuned Doug at TopSpeed. What I meant by OEM is that there's no delay in the OEM tune. With that said, your CL/OL settings cannot be stock if you have a BIG MAF. If you're running a BIG MAF you're more then likely running a scaled MAF map. So because of the scaled MAF map the switchover has inadvertantly been moved as well. There is a variable for OL switchover called Delayed Open Loop Load Threshold which by default is at 2.40g (which is roughly 1.13V on the OEM MAF scaling). So, if that scale has changed you need to also change that switchover from 2.40g to something that matches the newly scaled MAF map.
Old 07-16-2006, 10:40 PM   #16
JDM-STI
Member#: 101256
2005 STI
CGM
Scott Siegel at Subaru of Gwinnett. He has reworked every open/close loop table and MAF scaling table available. Nothing has helped. Ecutek has been looking at my datalogging and trying to find a fix for better than 2 months now.
Old 07-16-2006, 10:56 PM   #17
JRSCCivic98
Member#: 67080
Well, I was close.
Anyway, ask him if there's a table in there for the CL/OL delay I indicated above. It's possible that EcuTek doesn't have this in their software, but I'm not 100% sure. The table is definatly available in ecuEdit for 05 STI ROMs with the appropriate xml definition. Maybe he can download that software and play arround with it a little and see if the tables are the same between the two. There are a lot (more then the WRX) CL/OL transition tables in the STI ROMs... without knowing which EcuTek has made accessible or not I cannot tell you if he's truly exhausted all possible changeovers. It's definatly worth a look into at this point since he's exhausted every other avenue for a resolution of your problem.
USDM sti ECU in an 03 USDM wrx prometheum Engine Management & Tuning 0 02-23-2010 12:58 AM
can i use a 06 sti ecu in a 07 sti with np Crazy650 Newbies & FAQs 2 07-02-2008 07:53 PM
STI ECU in an 06 WRX Tokudai Engine Management & Tuning 4 06-27-2006 08:49 AM
'04 Sti clutch in an '05 slowscooby Transmission (AT/MT) & Driveline 3 12-11-2005 10:15 AM
WTT: CA - '04 STi Steering Wheel for '05 STi Steering Wheel... STIcky WRX AWD Private 'For Sale' Classifieds 5 12-03-2004 02:34 AM
