Old 07-15-2006, 01:12 AM   #1
ayobreezie
Member#: 117855
2003 O.O
AWP
Default Just did my first oil change/gear oil change since i got my car
Did my first oil change.. and also changed tranny and rear diff fluids... put mobil 1 in the rear 75w90 and Uncle Scotty's cocktail mix in the tranny. Put Mobil 1 in the car.. shifts pretty smooth, but still can't shift to 1st over 20 MPH.. got'a be around 15 or less.. but yeah, I like the shifting.. first and 2nd feel a little "rubbery," but was thinking it just needs a little time to mix in.. 'cause I poured LW Shockproof, then Synchromesh, then the Hypo C.. plan to do a coolant change and air filter and fuel filter change tomorrow, rotate my tires then, head out to North Carolina.. in San Antonio right now. How's that sound?
ayobreezie is offline   Reply With Quote
Old 07-15-2006, 01:36 AM   #2
83Rabbit
Member#: 5050
dont the synchros make it unable to shift into a lower gear at very high engine speeds? I know almost every car Ive owned has been unable to shift into a lower gear especially first at high engine speeds... all except my worked 83Rabbit which I shifted into second accidently instead of 4th on the highway and watched the tach come full circle lol thank god i had alot of head work
83Rabbit is offline   Reply With Quote
Old 07-15-2006, 01:46 AM   #3
AWD>FWD
Member#: 107027
2007 SWP WRX STi
w/MPS-built 2.34l
Yeah, I've never been able to access first gear until 15mph or less. The shifter just doesn't wanna go, it is the syncros.
AWD>FWD is offline   Reply With Quote
Old 07-15-2006, 06:35 AM   #4
ayobreezie
Member#: 117855
2003 O.O
AWP
Well, thanks for that piece of advice, then.. 'cause I just see people posting that they've been able to shift into 1st at 20+, thought I'd try it.. but I love the new fluids.. shifts so smooth.
Old 07-15-2006, 06:37 AM   #5
ControlFreak
Member#: 99200
I'm thinking of doing the cocktail as well, I have 10k coming up so I'll be doing some fun stuff to the rider.
Also, what possible reason would you want to be in first at 20 mph...
ControlFreak is offline   Reply With Quote
Old 07-15-2006, 07:25 AM   #6
ayobreezie
Member#: 117855
2003 O.O
AWP
Hahaha.. nah, no reason.. just seen people doing it past 20MPH, just thought it was normal, didn't want my car to be a bad egg.
Old 07-16-2006, 01:44 AM   #7
ghostfoot7
Member#: 61040
dead sexy blue!
I think in the newer WRX you can shift to first, since they changed something in the transmission, but in the older one, you can't.
I do a lot of double clutching to downshift.. seems to help... since I'm getting paranoid about grinding my gears trying to get into first.
ghostfoot7 is offline   Reply With Quote
Old 07-16-2006, 02:30 AM   #8
ThisizBrian
Member#: 106117
why do you want to go to 1st at 20+ mph? 1st is for starting froma stop.
ThisizBrian is offline   Reply With Quote
Old 07-16-2006, 12:40 PM   #9
hadboosttroy
Member#: 109560
2002 BMW M5
Goodbye STi :(
no crap, I don't get it. put it in second people, and avoid grinding and breaking stuff!
hadboosttroy is offline   Reply With Quote
Old 07-16-2006, 12:49 PM   #10
Anub1s
Member#: 81106
2014 Baby Mobile
Whitey White
Autocross calls for first gear at times to keep in boost.
Anub1s is offline   Reply With Quote
Old 07-16-2006, 12:52 PM   #11
wrxfactor
Member#: 49978
2002 WRX w/ JDM STi
6spd, EJ255, VF39 & EWG
Yup, and I can shift into first at any speed within its range; it's all a matter of double clutching, or sometimes not using the clutch
wrxfactor is offline   Reply With Quote
Old 07-16-2006, 03:02 PM   #12
CynicX
Member#: 48199
06 WRX
Nope...brand new its nearly impossible to get it into 1st above 15mph. You can revmatch it and work it in but its definately not worth the abuse and much easier to adjust driving style to accomidate for the synchros....
CynicX is offline   Reply With Quote
Old 07-19-2006, 08:29 AM   #13
bigstrusk
Member#: 118856
2000 GM6 STM
'07 S2K, '01 Ninja 250R
i just changed my fluids too for the first time (well ive only had the car for a few weeks...). i used a similar setup, mobil1 in the rear diff and a slightly modified cocktail in the tranny (1qt hypoC, 1qt syncromesh, 2qt mobil1) .. so far so good, with the cocktail. def smoother with no grinding.. i jus need to stiffen up the shifter now.. i got a bit of wobble 'n slop.
bigstrusk is offline   Reply With Quote
first ticket since i got my license kcook Mid Atlantic Impreza Club -- MAIC 14 10-09-2006 03:38 PM
First CEL since I got this car... e11ys Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 05-09-2005 04:53 PM
A question that stuck in my head since I got my Sti smootth Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 12 04-12-2004 10:12 PM
OT: My average speed since I got my WRX Kha0S New England Impreza Club Forum -- NESIC 26 12-13-2001 02:18 PM
('93-'01) Changing Gear Oil and Warranty phred's RS Impreza Forum 14 06-19-2001 03:57 PM
