Welcome to the North American Subaru Impreza Owners Club Monday February 8, 2016
Old 10-20-2001, 11:55 PM   #1
22B or not 22B
Member#: 8748
Default Turbo rpm
I am working on a little project and I was wondering what rpm range turbos run at when they reach full boost. I did a search and could not find anything about it . Sorry for my ignorance but any info or a good site to check out about this topic would be great.
Thanks for any info
Jeremy
22B or not 22B is offline   Reply With Quote
Old 10-20-2001, 11:58 PM   #2
kaos200
Member#: 2692
Default Re: Turbo rpm
Thanks for any info
Jeremy
I would imagine it varies depending on what your "full boost" level is?
What little project? hmm?
kaos200 is offline   Reply With Quote
Old 10-21-2001, 12:00 AM   #3
22B or not 22B
Member#: 8748
lets say I want 10-12psi
and it is a secret
Old 10-21-2001, 12:02 AM   #4
Eric SS
Sooby Guru
Member#: 1914
2000 2.5RS w/ EJ22T
swap and N20. gone. : (
Which turbo? that is the main thing that determins when you will hit full boost
Eric
Eric SS is offline   Reply With Quote
Old 10-21-2001, 12:20 AM   #5
22B or not 22B
Member#: 8748
lets say I want to go with a T3/T4
Old 10-21-2001, 12:39 AM   #6
Eric SS
Sooby Guru
Member#: 1914
2000 2.5RS w/ EJ22T
You should get full boost around 4,000rpm's I believe
Eric
Old 10-21-2001, 12:56 AM   #7
kaos200
Member#: 2692
ahh see the whole time I thought you meant the rpms of the turbine... lol
on my last turbo I got full spool (10psi) at somewhere around 3,200 to 3,500 IIRC.
Dunno what the new setup is just yet. Although I have an idea
Old 10-21-2001, 01:37 AM   #8
Andrew
Member#: 1170
2005 STi
was thinking the same thing.
Andrew is offline   Reply With Quote
Old 10-21-2001, 02:23 AM   #9
bsquare
Member#: 1911
2000 Impreza 2.5RS
Silverthorn Metallic
It depends on a LOT of factors: trim level of the turbo, vane counts and profiles, exhaust flow, intended power level of the engine (the metric is not psi, but cfm), etc. This is why turbo sizing is such a black art.
There was a lengthy article on the topic in a recent issue of SCC.
Ben
bsquare is offline   Reply With Quote
Old 10-21-2001, 03:30 PM   #10
22B or not 22B
Member#: 8748
I did mean turbine rpms. Sorry for being so nonspecific in the first post. I am just looking for an rpm range (do they spin faster than engine rpms?). I heard that you don't actually build boost until the car is moving (it has to have a load on it), is this correct? So if you launch from like 4000 engine rpms you are not getting extra power.
again sorry for my ignorance
Jeremy
Old 10-21-2001, 07:01 PM   #11
bsquare
Member#: 1911
2000 Impreza 2.5RS
The turbine itself can spin in excess of 100krpm, so it is going much faster then the engine rpm.
Ben
What should my RPMs be at 55mph? 1997OBS Newbies & FAQs 10 06-02-2010 12:14 PM
low RPM vibrations and BOV(?) noise ryguy02rex Newbies & FAQs 17 06-01-2010 05:52 PM
Hesitation at high rpms w/ turbo. Tim Prudence Technical Forum Archive 5 08-07-2000 05:19 PM
4k rpm hesititation with turbo Tim Prudence Technical Forum Archive 8 06-15-2000 10:15 PM
