Old 07-15-2006, 05:08 PM   #1
ErasureWRX
Member#: 106408
'14 Mystery Machine
01 Kat600
Default Blue connector?
Could someone please tell/host pics of where the **** the blue connector goes (2002 wrx). I lost the instructions, and dont want to hurt anything by making bad connections
thanks!
ErasureWRX is offline   Reply With Quote
Old 07-15-2006, 06:59 PM   #2
wrxdrvr
Member#: 79222
'09 STi 297.5 WHP
If you are talking about the cable to your PC ...it connects to the serial port on your PC and your AccessPort. you just take off the Diagport cable (with the red end) from AP and conect the blue end of cable there.
wrxdrvr is offline   Reply With Quote
Old 07-15-2006, 10:05 PM   #3
boundy3
Member#: 54598
2004 WRX Sedan
WR Blue Pearl #68 STX
Here's a link to the AP manual: http://www.accessecu.com/support/ap-usersguide-wrx.pdf
If your talking about the Blue Initilization Connector it attaches under the Steering Column. Should be near the green connectors that you also have to attach to flash a basemap / revert to stock. It will most likely only attach to one connector, I don't think you have to really worry about plugging it into the "wrong" one.
boundy3 is offline   Reply With Quote
Old 07-16-2006, 03:36 PM   #4
ErasureWRX
Member#: 106408
'14 Mystery Machine
01 Kat600
No, not that, the Init. connector.
A connector, like cable, or where the cable is attached?
Thanks
Old 07-16-2006, 06:15 PM   #5
boundy3
Member#: 54598
2004 WRX Sedan
I don't think you have to worry about plugging the Init. Connector in wrong. It should only connect in one place. It shouldn't be hard to find and it should be near the green connectors.
The worst that could happen is the AP won't let you flash a new map.
Old 07-16-2006, 06:16 PM   #6
wrxdrvr
Member#: 79222
'09 STi 297.5 WHP
There should be a wire by the two factory green test connectors with a semi-clear end on it you plug the blue initialization plug into it. And connect the two green test connectors together ... then you can change your base map.
Old 07-20-2006, 09:30 AM   #7
ErasureWRX
Member#: 106408
'14 Mystery Machine
01 Kat600
ok, so sounds like I have been trying wrong white-ended cable. It was kinda not close to the test connectors. And all this time I thought it was my battery
thanks for the help!
Need A Blue Initialization Connector! triplexcel Vancouver Impreza Club Forum -- VIC 6 09-09-2009 06:37 AM
The blue connector under the rear dash fizzak Car Audio, Video & Security 20 05-05-2005 05:44 PM
WTB Blue 02 AccessPort connector Lemon Herb Private 'Wanted' Classifieds 5 10-18-2004 09:58 PM
regarding the blue connector under the alternator spankaveli Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 08-07-2004 06:11 PM
A larger "T" connector lowers boost... What does a smaller "T" connector do? Cjchaps Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 12 04-29-2002 02:40 PM
