Welcome to the North American Subaru Impreza Owners Club Tuesday July 7, 2015
Old 05-04-2001, 04:18 PM   #1
Velocity
Member#: 2205
1998 Legacy L Wagon
Deep Sapphire Blue
Post Short-shifter comparison & turbo ?
I would like to know if there are any differences between the COBB short shifter and the Kartboy shifter. ie, build quality, shift throw, etc.
Also, this is a pretty stupid question, but what would it take to toss the turbo from an older 91-94 2.2 Turbo Legacy on my '98 Legacy L 2.2?
Velocity is offline   Reply With Quote
Old 05-04-2001, 06:54 PM   #2
Peaty
Techno Sapien
Member#: 449
2010 Legacy 3.6R Lim
Azurite Blue Pearl
Post
Can't help you with a Cobb comparison but I do have this:
http://www.azscooby.com/mods/AZScoob...artboy-sti.php
FWIW the Kartboy is top notch quality.
Peaty
Peaty is offline   Reply With Quote
Old 05-04-2001, 07:00 PM   #3
nuburu2
Member#: 2609
98 BK-GT White
'97 SVX Ebony Pearl
Post
Velo, I did try the Cobb shifter, and returned it after finding the noise and vibration objectionable. Trey was most kind in taking it back after I tried packing the bearing without success. The shift action was top-notch though, and I did keep the Cusco bushings, which made a real contribution toward more positive "feel".
<FONT face="Comic Sans MS">Glenn O</FONT f>
nuburu2 is offline   Reply With Quote
Old 05-06-2001, 12:26 AM   #4
MY99 2.5GT
Member#: 5030
1999 Legacy 2.5GT
12 Legacy GT 13 Armada
Post
Go for the Cobb. Nuburu2's experience is a unique one. I have the Cobb model on my 99 Legacy GT. I love it. I have driven an RS with the Kartboy. With the Cobb the shift is just the right length. Also th Kartboy is nice but I didn't like the bend it had in it. Let me put it this way. If you get the Kartboy here is a good way to measure how it would be. Put your stock shifter in 2nd, 4th, and reverse. Look at the current placement of the top of the shifter. Chop about 1.5-2 inches off the top and make believe there is a bend in the shifter which place the top knob about and inch or two furhter in the direction of your center console. Oh by the way the Cobb unit keeps the shifter at stock height but drastically reduces the shift. So you get a shifter thats in a comfortable place with a really short shift.
I vote Cobb.
MY99 2.5GT is offline   Reply With Quote
Old 05-06-2001, 09:14 PM   #5
snowone
Member#: 6035
05 92-X Saabaru
87 VW Westfalia
Post
I haven't tried the COBB... considered it when shopping, almost ordered, but talked to Trey re the install and any issues and decided I didn't want to grind anything to make it fit correctly. Apparently there's an issue with the sifter hitting a metal peice when going for first? I believe that's specific to the RS though... when I put in my KARTBOY shifter, I didn't see the piece he described to me. I still wouldn't mind trying a COBB w/ the bearing design...
The Kartboy shifter w/ busings is good. I tried just bushings w/ stock shifter first... great improvement. The short shifter took some getting used to it. Wasn't too sure about it at first, but now I don't think I could go back.
snowone is offline   Reply With Quote
Old 05-07-2001, 10:04 PM   #6
Velocity
Member#: 2205
1998 Legacy L Wagon
Deep Sapphire Blue
Post
Big bump for the turbo question... actually, I think I'll repost it seperately.
Thanks a bunch guys! Either way, I'll be putting in new bushings with the shifter.
Another question -- any difference between the Cusco bushings and the Kartboy ones?
I really like the shortness of the Kartboy, but that bend would probably not work out right for my long gangly arms, plus it was pointed out elsewhere that it angles a knob with a "grip" on it way too high to use properly. Furthermore, it seems to me that the further one sat forward, the *worse* the shift would be, almost to the point of reaching back -- just thinking of autocrossing or whatnot.
I'll probably reluctantly go with the COBB, as I too like the bearing design, although price is going to come into play since both aren't exactly what I want (more of a joystick -- reduced shift throw with reduced height), and I'm getting the bushings also (of course, I could just get the Kartboy bushings, but it'd be a waste of time and money not to order the shifter as well).
Thanks, Matt
[This message has been edited by Velocity (edited May 07, 2001).]
Old 05-07-2001, 10:09 PM   #7
snowone
Member#: 6035
05 92-X Saabaru
87 VW Westfalia
Post
Order the Kartboy setup... Tom is cool, has 'em in stock, and you could have it installed in about 45 minutes upone receipt. Try it, you'll like it. From what I read, it gives you less throw than the Cobb... and you won't have to worry about bearing noise.
The bushings are pretty much the same, Kartboy's are cheaper.
Old 05-07-2001, 10:17 PM   #8
Velocity
Member#: 2205
1998 Legacy L Wagon
Deep Sapphire Blue
Post
Well, a shifter is a shifter, so I don't think one would be much harder to install than the other. It's not a full linkage or anything.
According to their respective websites, the COBB shifter reduces throw by 50% whereas the Kartboy is 40%.
I really don't care much about a little bit of noise -- that's what I've got windows for!
Thanks!
Agency power short shifter and Kartboy bushings (Brand new in box) subadupa Interior/Dressup/Audio & Security 9 07-19-2010 09:18 AM
Kartboy Short Shifter mtnnsea19 Drivetrain 15 06-25-2010 01:40 PM
Kartboy Short Shifter/Front & Rear Bushing Combo Deal--Spec Clutch Clearance! Spun Autosports Drivetrain 228 02-27-2010 07:50 PM
short shifter for legacy turbo? inzomniac Legacy Forum 2 05-29-2002 12:59 PM
Short shifter for Legacy Turbo? tom@kartboy Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 04-04-2001 03:07 AM
