Old 07-15-2006, 11:24 PM   #1
Flexx999
Member#: 36302
2006 Big 16G WRX
Addicted to Blue
Default USDM STI TMIC on 06 WRX- Install Question
I just tried fitting a USDM STI TMIC on my 06 WRX. Everything I have read says it fits right in with the STI piping. Im not finding this. The elbow on the bottom of the intercooler interferes with the throttle position sensor (TPS), and the metal rib will hit where the connector goes into the TPS. I didnt want to force it on and cram the elbow into the TPS before I asked on here what other people did. My buddy was helping (hes a subie mechanic) and he said it didnt look right either and didnt thing squishing it like that would be right.
We can pull the perrin hose of my stock intercooler and cut it and it would work better as it doesnt have the metal rib in it.
To the guys that have done this swap....did you have the same issue and what did you do?
Flexx999 is offline   Reply With Quote
Old 07-16-2006, 12:20 AM   #2
06BLUEREX
Member#: 120000
mine fit fine and didnt have any issues with it rubbing, i am using the stock ypipe/elbow/coupler that came with the sti tmic. i did this with my vf39 swap and 18g swap, even though the compressor side of the 18g was bigger it still fitted.
there shouldnt be any rub at all, something isnt right.
06BLUEREX is offline   Reply With Quote
Old 07-16-2006, 01:19 AM   #3
Flexx999
Member#: 36302
2006 Big 16G WRX
Addicted to Blue
on the stock intercooler the hose is right up against the TPS as well
Old 07-16-2006, 07:31 AM   #4
ControlFreak
Member#: 99200
Corrected.
ControlFreak is offline   Reply With Quote
Old 07-16-2006, 01:15 PM   #5
Flexx999
Member#: 36302
2006 Big 16G WRX
Addicted to Blue
Im not using the stock turbo....Im running a FP16G....so the length of the hose is fine.
Old 07-16-2006, 01:31 PM   #6
sleestak6326
Member#: 100040
2016 WRX
Ice Silver Metallic
Here is a pic of how mine fits with the VF39.
sleestak6326 is offline   Reply With Quote
Old 07-16-2006, 01:57 PM   #7
bcristea
Member#: 11343
2008 STi
FWIW,
Just put mine in yesterday with no issues. Mine is not even touching.
bcristea is offline   Reply With Quote
Old 07-16-2006, 03:27 PM   #8
Flexx999
Member#: 36302
2006 Big 16G WRX
Addicted to Blue
sleestak: thanks for the pic......is it bending the connector at all? I didnt bolt mine up just did a test fit and it looked like mine is a little closer then yours. What you show there looks like how the stock TMIC elbow sits. I might hat to just bolt it up and see what it does...maybe when I put it together it may fit better then the test fit looked.
Old 07-16-2006, 04:20 PM   #9
sleestak6326
Member#: 100040
2016 WRX
Ice Silver Metallic
No, its not bending the connector at all.
INSTALL QUESTION ABOUT STI TMIC on 06 wrx. Require tune? lordizzy626 Newbies & FAQs 13 10-20-2013 07:19 PM
STI TMIC ON 06 WRX Question lordizzy626 Newbies & FAQs 3 02-07-2010 11:20 AM
USDM STI tmic on 02 WRX wrxblk02 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 02-27-2008 09:46 PM
swapping USDM STI TMIC into 06 WRX TR 06wrxtr4me Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 8 02-27-2007 06:36 PM
USDM STI TMIC on a WRX (04) samagon Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 04-25-2005 12:21 PM
