Welcome to the North American Subaru Impreza Owners Club Sunday March 1, 2015
Old 10-21-2001, 01:47 AM   #1
Kreed
Member#: 10011
2002 PSM WRX
2013 AW 135i DCT
Default Oil lugnut rotation?
Unscrewing is what I want, maybe I have no muscles but I can't move it! Do you unscrew counterclockwise? thats what I'm doing but it wont budge...
Kreed is offline   Reply With Quote
Old 10-21-2001, 09:15 AM   #2
Rocky WRX
Member#: 9837
2002 White WRX Wagon
7800 ft
Looking at the bolt, counterclockwise unscrews it. Maybe you need a longer wrench for more torque.
I like 3/8" socket drivers myself, they can be had in a variety of lengths, some with joints.
Rocky WRX is offline   Reply With Quote
Old 10-21-2001, 01:15 PM   #3
Jon [in CT]
Member#: 2992
02 WRX Sedan
It sounds like you're doing the first oil change for your WRX. The oil drain plug is torqued at the factory unbelievably high, much higher than the 33 ft-lb torque recommended in the manual. You'll want to use a 6pt 17mm socket with a breaker bar and the plug unscrews in the normal fashion, counter-clockwise. Given that you've already tried with all your might to remove it, you might be interested in the replacement part if you've managed to round the faces of the plug. It's 807020070 - (PLUG-20X14).
You'll also find that the oil filter was also installed at the factory with excessive torque and you'll need to use a filter wrench with that breaker bar (or a screwdriver punched through the filter) to get it off.
Jon [in CT] is offline   Reply With Quote
Old 10-22-2001, 12:11 AM   #4
Kreed
Member#: 10011
2002 PSM WRX
2013 AW 135i DCT
Tanks guys, I held back before I stripped it too much so the 3/8" socket did it (And a bigger ratchet) and I bought a filter wrench, got a cut or two but finally managed to work it off.
Put a fujitomo valve but Im getting a little leaking so I dont know about that one :/
How do you do 33 ft-lb torque, guesstimate?
Thanks again!
Old 10-22-2001, 12:26 AM   #5
Hal
Member#: 6133
WR Blue
If the fujitomo valve didn't come with a crush washer and you didn't get a new crush washer from Subaru then this could be why it's leaking. Subaru recommends replacing the crush washer on each oil change (when using the OEM drain plug).
Hal
Hal is offline   Reply With Quote
Old 10-22-2001, 04:02 AM   #6
Kreed
Member#: 10011
2002 PSM WRX
2013 AW 135i DCT
Thanks Hal, it did come with the washer and I did use it. are you guys tightening it by hand?
Old 10-22-2001, 04:23 AM   #7
Richard L.
Member#: 8465
'00 2.5RS Coupe, AW
'93 GMC Typhoon AWD
When you said "fujitomo", did you mean "fumoto" oil drain valve? Just use the blue washer that came with the valve. Torque the valve down by hand, then use a 19-mm open wrench and nudge it down around 1/4 to 1/2 turn. It should not leak.
Richard
http://www.whitetyphoon.com/impreza/
Richard L. is offline   Reply With Quote
Old 10-22-2001, 07:29 PM   #8
Kreed
Member#: 10011
2002 PSM WRX
2013 AW 135i DCT
heh thank you Richard I had a brain fart. Fujitomo is a bank I used to make deposits at.
Thanks for the info, I will do as you say.
Old 10-22-2001, 10:32 PM   #9
Peaty
Techno Sapien
Member#: 449
2010 Legacy 3.6R Lim
Azurite Blue Pearl
I've installed 2 drain valves. One with the blue fiber washer supplied and the other with a new crush washer. Neither leaked. Details and pics here:
http://www.scoobymods.com/mods/impre...drainvalve.php
Peaty is offline   Reply With Quote
Old 10-24-2001, 01:51 AM   #10
Kreed
Member#: 10011
2002 PSM WRX
2013 AW 135i DCT
Doh! I cant find the crush washer so I am going to assume it was stuck to the oil pan when I put the valve on! (just as I assumed it was on the bolt) what is the crush washer made of? is it felt like the valves? if so maybe I can unscrew the valve a little and cut it off with an x-acto knife. I'd hate to waste the whole oil change.
Damn and I was so proud of doing the first oil change... :/
Old 10-24-2001, 02:18 AM   #11
Peaty
Techno Sapien
Member#: 449
Azurite Blue Pearl
I bet it's on the nut and not the oil pan. It looks like one of those washers that go on spark plugs (but flatter now) , but the first one on the car is painted black.
Old 10-24-2001, 01:00 PM   #12
Kreed
Member#: 10011
2002 PSM WRX
2013 AW 135i DCT
Not on the nut thats why I started looking for it.
Old 10-24-2001, 01:20 PM   #13
Peaty
Techno Sapien
Member#: 449
Azurite Blue Pearl
Well if it dosen't leak I say leave it alone.
If it ain't broke fix it till it is I say
Old 10-24-2001, 04:28 PM   #14
Kreed
Member#: 10011
2002 PSM WRX
2013 AW 135i DCT
Old 11-01-2004, 06:35 AM   #15
hey1
Member#: 72106
2002 Impreza WRXagon
Platinum Silver Metallic
bump!
hey1 is offline   Reply With Quote
Old 11-01-2004, 08:14 AM   #16
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Originally Posted by hey1
bump!
Why?
Old 11-01-2004, 08:50 AM   #17
Hondaslayer
think you
Member#: 4562
1995 Legacy LSi
1998 Forester, lifted.
Jon,
It's not that its overtorqued, its the fact that its torqued down then painted over.
Old 11-01-2004, 09:02 AM   #18
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
I think he's probably figured it out by now, this was originally posted in '01.
Old 11-04-2004, 01:42 AM   #19
imprezavness
Member#: 59563
2004 white WRX
confused
breaker bar and pb blaster worked for my first time
imprezavness is offline   Reply With Quote
Old 11-04-2004, 10:51 PM   #20
Boxologist
Member#: 21118
Lightbulb
hit the n00b with a tool warning point.
Boxologist is offline   Reply With Quote
Old 11-06-2004, 10:57 PM   #21
Silent23
Member#: 30766
2004 Impreza WRX
Java Black Pearl
bumping a three year old thread........priceless......
Silent23 is offline   Reply With Quote
FS : lugnuts, panel filter,etc.. scooby_wooby MAIC Private Classifieds 48 09-14-2010 03:38 PM
FS: brand new rotated Perrin gt3076r sgm_sti NWIC Private Classifieds 5 06-26-2010 07:03 PM
Feeler: Borg Warner Rotated kit ASU NWIC Private Classifieds 4 06-01-2010 09:51 PM
STi oil feed line for rotated GT setup suby_dude Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 5 01-17-2006 08:17 PM
rotating tires and changing oil SubaruImpreza_power Forester Forum 16 07-29-2004 08:25 PM
