Old 07-16-2006, 06:06 PM   #1
Skidd
Member#: 1853
GC6 Supercharged
STM
Default Oil Pump o-ring Location? and Cam Swap questions?
I'm 1/2 way through the a Delta Cams swap in my 00RS. The cams are in the mail as we speak. But.. I have a couple of questions related to the swap. I'm doing the timing belst and the seals, including crank, cam and the oil pump o-ring, etc.... My questsion are...
1. Where in the heck does the Oil Pump o-ring go? I found the water pump, and I believe the toothed cog to the left is the Oil Pump cog.. so.. where does the oring go? I have not yet tried removing anything to find it.
2. Is this stuff (LINK) fine for re-sealing the camshaft-cap to the head? I'm assuming it's fine.. but I thought I'd check with the experts.
3. Do I need to put anti-seieze on the threads of the bolts that hold the camshaft-cap to the head? I know they are not torqued high, but it's still steal into aluminum.
Thanx.
Skidd is offline   Reply With Quote
Old 07-16-2006, 07:55 PM   #2
Tim Sanderson
Member#: 6486
00 Impreza 2.5 RS
Blue Ridge Pearl
The oil pump o-ring is behind the oil pump.
That sealant is fine. Don't use too much.
No anti-seize necessary.
Pay attention to the oil pump bolts, three of them have a thread sealant on them. You should use thread sealant when re-installing them.
Tim Sanderson is offline   Reply With Quote
Old 07-16-2006, 08:04 PM   #3
Hawk296
Member#: 14555
1995 Impreza L
Baja
And the oil pump is in the center. The nose of the crankshaft goes through it. (the part the front crank seal is in)
Hawk296 is offline   Reply With Quote
Old 07-16-2006, 09:16 PM   #4
Skidd
Member#: 1853
GC6 Supercharged
STM
Woh.. at the crank.. I never would have figured the pump was there. I was looking around the area of the oil pan. Thanx Hawk. I assume if I pull the whole pump, I'll need a new gasket there also? Or did subaru use a liquid gasket (permatex) there also? And now that I look closer.. I think that little puppy is the culprit of my minor oil leak. There appears to be a small stream of oil running down the seam there.
Hey Tim, when you say Thread Sealant, your not talking about LocTite are you? But rather some sort of sealant for bolts?
Thanx guys.
Old 07-16-2006, 11:29 PM   #5
Hawk296
Member#: 14555
1995 Impreza L
Baja
If I recall correctly the oil pump has 3 seals which you should replace while you are in there. the O-ring on the backside, the front main seal, and the perimeter of the oil pump which is sealed with a liquid silicone RTV type stuff. Anyone of these can cause a pretty good leak if they go.
Old 07-17-2006, 07:05 PM   #6
Skidd
Member#: 1853
GC6 Supercharged
STM
Do you guys happen to know the proper torque spec for the oil pump bolts?
Old 07-17-2006, 08:16 PM   #7
Tim Sanderson
Member#: 6486
00 Impreza 2.5 RS
Blue Ridge Pearl
Thanx guys.
IT's made by permatex. Any sort of non hardening sealant should do the trick. You'll see what I mean when you remove them. I think it's called permatex #2 non hardening sealant.
Old 07-17-2006, 09:38 PM   #8
Skidd
Member#: 1853
GC6 Supercharged
STM
When I removed the oil pump, I found that 2 of the bolts had something on them. I assume the sealant your talking about. But not 3. Are you sure it wasn't just some gasket goop that got into the holes? Or does it specify somewhere in the subaru repair manual that 3 of them actually need sealant?
Old 07-18-2006, 03:32 PM   #9
Skidd
Member#: 1853
GC6 Supercharged
STM
Bump.. cuz I wanna put the pump back on tonight.
I'm still lookin' for the torque spec and the answer to my last post.
Thanx..
Old 07-19-2006, 03:37 PM   #10
Skidd
Member#: 1853
GC6 Supercharged
STM
Oil Pump O ring Drexer13 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 04-14-2010 09:46 PM
oil pump o-ring/reseal how to 98tredsvt Service & Maintenance 1 01-06-2010 09:25 PM
Oil pump plugs good location for Oil pressure sender? jsnuff1 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 10 06-26-2007 08:01 PM
Cam Swap Questions naTe02 Built Motor Discussion 8 04-09-2006 10:18 PM
Replaced front main seal and oil pump o-ring archer Normally Aspirated Powertrain 4 12-28-2001 03:28 AM
