Canada Region Club
Go Back   NASIOC > NASIOC Regional Areas > Canada Region Forum > Western Canada
Old 07-16-2006, 08:42 PM   #1
Jeff25RSti
Member#: 83999
99 2.5rs
Default Just about finished engine swap
Hey Guys,
I am finishing up my 02 wrx into 99 rs engine swap and am trying to solve a major issue. The car will crank over but will not start. The fuel injectors are not injecting any fuel. The injectors themselves are working fine but the duty cycle signal from the ecu telling them to open is not there. I am leaning toward this being a problem with the ecu because I am also not getting any CEL codes. Even turing the car to the ON position the CEL will not light up. I am also not able to talk to it with a OBD II diagnostic tool. My question is would someone in the Edmonton area be willing to try this ecu in their wrx. I would like to prove for sure that this is the problem before I start trying to return this one or looking for a new one. Thanks for any help you guys can offer.
Jeff
Jeff25RSti is offline   Reply With Quote
Old 07-17-2006, 01:57 AM   #2
fragment
Member#: 8050
2004 FXTi - Stage 2
Goooooooolld
Twenty bucks says its a ground issue.
fragment is offline   Reply With Quote
Old 07-17-2006, 02:17 AM   #3
Member#: 47261
that or a plug somewhere isn't completely plugged in... not that I would know anything about that or anything...
soccer_freak_m@hotma is offline   Reply With Quote
Old 07-17-2006, 02:45 PM   #4
Jitenshakun
Member#: 61586
2005 STi
WI and all the goodies
You did include a WRX fuel pump controller as part of your install right?
-J
Jitenshakun is offline   Reply With Quote
Old 07-17-2006, 03:14 PM   #5
fragment
Member#: 8050
2004 FXTi - Stage 2
Goooooooolld
-J
Strictly speaking, you don't HAVE to use the WRX pump controller. Its just that the ECU expects one, and will throw a CEL if you don't use it.
The original post says that he doesn't even get a CEL light when turning the car on. I'm betting the ECU isn't getting all its voltages, and that could be several things, but the easiest thing to mess up is the grounds...
Old 07-17-2006, 11:32 PM   #6
Jeff25RSti
Member#: 83999
99 2.5rs
I have included the fuel pump controller and as far as I can tell that works fine. Fuel pump primes and I have fuel pressure in fuel rail. As far as a ground issue, it is very possible. I have gone over the wireing several times and it all seems in order but its easy to miss something with this much wiring. I am getting power at the pins going to the ecu which should have power and the ecu itself gets a little bit warm so I think it is trying to do some work. Sensor voltages are alittle bit harder to read as most of them are waveforms. Ive swaped out the cam and crank shaft sensors so I think I can rule them out. I am getting spark when I crank the engine over so that shouldnt be a issue either. I have hopefully found another ecu to try so I will let you guys know how that turns out.
Jeff
Question about my engine swap and a turbo LegacyEast Legacy Forum 4 08-11-2006 07:39 PM
Question about sti engine swap AntonioS Normally Aspirated with bolt-on Forced Induction Powertrain 1 02-09-2004 05:02 PM
? about VW engine swaps blue-sun Mid West Subaru Owners Club Forum -- MWSOC 3 09-05-2002 12:26 AM
Question about crazy engine swap... 5 Door Man General Forum Archive 11 02-20-2001 10:55 AM
? about wrx engine swap and exaust placement... Damon Normally Aspirated Powertrain 1 12-05-2000 09:55 PM
