Old 07-16-2006, 10:33 PM   #1
john_matrix
Member#: 54787
2005 Saab 9-2x
Satin Gray Metallic
Question Do I have too many bushings? First is tough to get into now
Hello everyone, I have a problem that I need help with.
Installed the Sti 5mt tranny mount yesterday, and now the stick "binds" going into first, and just now I got it into first, and it seemed stuck. I had to wrestle to get it into 2nd. It initially didn't feel that bad, but now that scared me. All other gears are firm and feel right.
Prior to the Sti mount, it shifted perfectly into first and didn't bind.
I have:
Kartboy SS
Front and rear bushings
Tranny crossmember bushing
Fluid is stock and up to the proper level.
Did we not torque the mount correctly or what? I mean it fit right in there, I don't think you can screw this install up. It was 100 degrees here today, does that have something to do with this?
Thanks
john_matrix is offline   Reply With Quote
Old 07-16-2006, 11:34 PM   #2
MonsterRallySport
Member#: 104148
MRT Spur cut with
Rocket center Diff.
Bent forks usually cause hard shifting in some gears but not others.. Not bushings...... I have never had any problems with any quality bushings. Today was 112 degrees here I drove my car all day..
MonsterRallySport is offline   Reply With Quote
Old 07-16-2006, 11:51 PM   #3
john_matrix
Member#: 54787
2005 Saab 9-2x
Satin Gray Metallic
See it just feels too damn stiff now that the sti mount is in. Like bad stiff.
I haven't shifted hard and never do, do you think I could have bent a fork on the install? Is that possible?
Old 07-17-2006, 12:10 AM   #4
DrD
Member#: 22412
2012 Legacy 2.5GT
Ice Silver Metallic
the grp-n mount just made things feel more solid for me - not stiff... does it feel like things are binding? check the washer with the hook/tab thing on it (which holds the front shift bushings in place) - the hook should go out away from the bushings - if it goes in, the linkage will bind on it. no idea if that's your problem, but it's something to check.
Old 07-17-2006, 12:25 AM   #5
MonsterRallySport
Member#: 104148
MRT Spur cut with
Rocket center Diff.
You usually only bend forks by missing, pounding gears...
Old 07-17-2006, 12:59 AM   #6
Member#: 67
1999 Outlasting
the competition.
Hello
check the washer on the shifter bushings. the front ones. chances are you have the washer on backwards. the "tang" goes towards the outside. if it goes inwards it will bind with the linkage.
Tom
Old 07-17-2006, 01:15 AM   #7
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
and/or overtorqued something
Old 07-17-2006, 10:06 AM   #8
eqlized_aero
Member#: 88699
2015 TS EFR7163 818S
V9 Spec C Type RA 92x
We also installed the sti pitch stop at the same time, so he has:
Sti group-n pitch stop
Kartboy SS
Kartboy front & rear bushings
Sti tranny crossmember brace
I'm wondering if the pitch stop got tightened at a weird angle. Otherwise it's probably the washer on the front bushings (even though it would have been that way for like 3 months since we didn't touch the washer on saturday)
eqlized_aero is offline   Reply With Quote
Old 07-17-2006, 10:42 AM   #9
subieworx
Member#: 47769
If you tighten the pivot point on the shifter too much it will be hard to get into gear. Also make sure your shifter shaft that meets the trans is not rubbing on the metal bracket inside the car that surrounds the shifter.
subieworx is offline   Reply With Quote
Do we have too many poles? HamFist Off-Topic 10 12-15-2006 09:14 AM
how hard is it to get into canuckistan? b_tapper Off-Topic 37 10-21-2004 06:22 PM
tough to get into 1st and 2nd raptor5 Warranty Issues & SOA Problems 1 01-18-2002 11:41 PM
Why the subaru transmission is hard to get into 1st. Midwayman Transmission (AT/MT) & Driveline 4 08-13-2001 12:05 AM
