Old 07-17-2006, 11:38 AM   #1
Ziggyrama
Member#: 53665
2011 STI Stg2 w/EBCS
2012 Tribeca Ltd.
Default Ingalls camber bolts, which ones for the front?
Hey guys,
I just upgraded my suspension to JDM V8 struts and springs and now I need an alignment. Based on my previous alignment, I could only get -1.5 degrees of camber in the front with stock suspension so I assume this will be the same. I would like to go to -2.5 which should still be ok for daily driving.
After searching around, seems like Ingalls camber bolts are the ones I should get to get me to -2.5 camber in the front. Summit Racing has them but they offer 2 different bolts.
First one:
http://store.summitracing.com/partde...5&autoview=sku
Second one:
Which is right for the front?
Ziggyrama is offline   Reply With Quote
Old 07-17-2006, 12:01 PM   #2
thorongil
Member#: 58797
2011 Legacy 2.5i
Steel Silver
Either should work fine. The IEC-I-81260 kit comes with 2 bolts per box. The IEC-35420 kit comes with one bolt per box (so you would need to order two kits to replace the lower strut bolts). I recently bought and installed the IEC-I-81260 kit and the bolts work well.
thorongil is offline   Reply With Quote
Old 07-17-2006, 01:08 PM   #3
Ziggyrama
Member#: 53665
2012 Tribeca Ltd.
Cool.. That's the info I was looking for. Thanks a lot!
Old 07-17-2006, 01:20 PM   #4
Ziggyrama
Member#: 53665
2012 Tribeca Ltd.
Actually, I have another question. The bolts come with this washer that has an arm sticking out of it. The OEM bolts do not have this. What is that arm for?
Old 07-17-2006, 01:39 PM   #5
UkNuck
Member#: 21808
02 GroceryGettAr
Nonemore Black
That's the tab that determines the orientation of the cam lobe (and hence whether you get positive or negative adjustment). See here [Whiteline - pdf]
UkNuck is offline   Reply With Quote
FS: (CA) Whiteline STI Front Rear 27mm/24mm Sway Bars Endlinks & Ingall Camber Bolts Drag-On Suspension/Brakes/Handling 5 08-05-2009 12:17 PM
RCE front bump stops, Ingalls camber bolts ryansport22 Suspension/Brakes/Handling 5 05-08-2009 09:40 AM
Which amp for the front and rears? Rayman21287 Car Audio, Video & Security 5 11-21-2008 04:46 PM
Will Ingalls Camber Bolts work for my '06 WRX ??? Mr Nice Guy Brakes, Steering & Suspension 4 12-27-2007 12:00 PM
Which one is the front sway bar 2fast4uWRX Brakes, Steering & Suspension 2 02-18-2003 06:16 PM
