View Poll Results: What should iamrazor do about his timing belt?
DIY FTW! 11 52.38%
Stealership you lazy F 8 38.10%
put her into a tree and collect the ins. 2 9.52%
Voters: 21. You may not vote on this poll
Old 07-17-2006, 07:23 PM   #1
iamrazor
Member#: 52324
2011 WRX LTD (FS)
1990 T30 miata
Default SOHC EJ25 Timing Belt: DIY or Stealership?
Ok so I've crossed 110k mark and I know its time for a timing belt. I think the tensioner needs a-replacin' too (I hear this odd rattle when I let off to shift). I'm good with a wrench, but is it worth letting the dealer do it? The Phase II EJ25 is interface, correct?
So let's hear your opinions, experiences, usual nasioc banter
Disclaimer:
I don't plan on keep her much more than a year so I'm gonna skip water pump, seals... et all.
wait for the poll!
iamrazor is offline   Reply With Quote
Old 07-17-2006, 10:36 PM   #2
Rally_wgn
Member#: 62629
1996 OBS in Green
2.5 N/A w/ full exhaust
Spend the money and buy a new thermostat, a locked 'stat will shorten engine life... to about 15 minutes.
There is a recent thread with lots of advice here, so I would read that for everyones thoughts.
Rally_wgn is offline   Reply With Quote
Old 07-17-2006, 10:43 PM   #3
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
And don't forget to replace or at least check out the toothes idler pulley, too. --> http://forums.nasioc.com/forums/show....php?t=1046364
Old 07-18-2006, 01:04 AM   #4
Skidd
Member#: 1853
GC6 Supercharged
STM
I'm 1/2 way through a Delta Cam upgrade, and it's proving to be quite straight forward. Thanx to http://www.cobbtuning.com/instructions.html and this board.
Given these instructions, doing the timing belt should be a breeze. And while your in there, might as well do the crank and cam seals too.
Skidd is offline   Reply With Quote
Old 07-19-2006, 07:49 PM   #5
iamrazor
Member#: 52324
2011 WRX LTD (FS)
1990 T30 miata
well, i would, but I'm not really planning on keeping the car too much longer. In fact, I'd prefer it gone already. you know how it is..
Old 07-20-2006, 12:56 PM   #6
Hayes
Member#: 11808
I too can handle a wrench but, Im not a mechanic. It took me about 2 &1/2 hours to replace the timing belt, WP, new coolant hoses etc. Be informed that the crankshaft pulley is torqued to 125 foot/lbs so you need to have a good 6 point 22mm? socket & breaker bar AND be able to lock the flywheel. My AT provide a service hole just by the intake manifold on the left side when looking into the engine compartment. My dealer wants ~$375 and my TB OEM was ~$85 so I saved ~290 or about $110 per hour, tax free.
Hayes is offline   Reply With Quote
WTB: SOHC EJ25 Motor or WRX Motor Gomer_GSX NWIC Private Classifieds 0 04-20-2009 06:27 PM
Timing belt: DIY or shop bhall Legacy Forum 35 01-14-2007 04:36 PM
WTB: SOHC EJ25 or USDM EJ20t simpreza2 Private 'Wanted' Classifieds 3 10-30-2004 07:33 PM
Need advice: '02 Timing belt: 60k or 100k? strohausii New England Impreza Club Forum -- NESIC 9 10-17-2004 11:46 PM
SOHC ej25 motor - heads and/or block dyswtric27 Private 'Wanted' Classifieds 0 11-02-2003 04:51 AM
