Welcome to the North American Subaru Impreza Owners Club Saturday February 28, 2015
Old 10-21-2001, 05:46 PM   #1
Audipwr1
Member#: 9895
2012 Audi S4
BLACK
Default Used RS-T
I have the option of buying a 98 RS that was turboed for 14k (with about 7-9PSI) and is now without a turbo. It still has the supra fuel pump. What should I do to see if the car is worth buying? What tests should be done to the motor to assure it is in good working condition?
I need some help here guys thanks
Audipwr1 is offline   Reply With Quote
Old 10-21-2001, 07:35 PM   #2
tulit
Member#: 338
09 STi
I think a leak down test would be most helpful. It will tell you a lot about the condition of the motor.
tulit is offline   Reply With Quote
Old 10-21-2001, 08:33 PM   #3
Audipwr1
Member#: 9895
2012 Audi S4
BLACK
What is the cost on that? Can any dealership do it? What exactly do they do?
What about the fuel pump? should i get a stock one or leave the supra one in?
Old 10-22-2001, 01:46 AM   #4
Poppa smurf
Member#: 8257
2004 STI
Silver\Silver
the supra pump is in there for a higher flow rate so leave it in.
Poppa smurf is offline   Reply With Quote
Old 10-23-2001, 10:23 PM   #5
Audipwr1
Member#: 9895
2012 Audi S4
BLACK
how do i control that high fuel rate though? does the bell fpr work like this, if so how do i work it?
Old 10-24-2001, 03:32 AM   #6
aussiebrydon
Member#: 10391
2008 Acura MDX
Sliver
Hey dude, how much was that car? My car has 32,000 miles on it, and I installed a new TEC and used ASR Stage II turbo from my friend Ian. I didn't set up up the TEC properly or something so I now have something like rod-knock. I'm going to have Subaru rebuild the engine for me, so are you interested in the car once I have it fixed? It'll be a MY00 2.5RSt with 0 miles after a factory rebuild, plus it'll have a TEC.
Just let me know,
Brydon
AussieBrydon@yahoo.com
aussiebrydon is offline   Reply With Quote
Old 10-24-2001, 10:31 AM   #7
RyanC
Member#: 2634
2011 135i
alpinweiss
A compression and leakdown are in order. My car has run for 3k miles post-turbo removal and has been fine, so if the car wasn't abused you might be ok. I ran up to 13psi for 22k miles and with the exception of a CE light for a poorly sealed fuel tank (didn't get the gasket right swapping the fuel pump) it's been normal. You should buy my car, it's 2 years newer... 13k!
RyanC is offline   Reply With Quote
Old 10-24-2001, 11:40 AM   #8
Audipwr1
Member#: 9895
2012 Audi S4
BLACK
someone here must have a supra fuel pump and a bell fpr and a SFAC that has run the car without a turbo and knows how to make it run properly i know it comon someone just tell me !!!!!!!!!!!!
Old 10-24-2001, 12:25 PM   #9
RyanC
Member#: 2634
2011 135i
alpinweiss
Relax skippy! I doubt many people would run a better fuel pump and up the fuel pressure when they are N/A... just a thought though.
Old 10-24-2001, 01:02 PM   #10
Audipwr1
Member#: 9895
2012 Audi S4
BLACK
someone has, though installed the pump and fpr and then had to wait a while to get the turbo on, anduring that time how did they drive the car?
Old 10-24-2001, 02:01 PM   #11
AaronB
Worst Mod Ever
Member#: 369
12 Vagon
06 WRX
I would assume that the car would run fine with the bigger fuel pump, you will just have high fuel pressures. RRFPRs won't do much for you since most of them only rise at positive manifold pressure (i.e. boost).
I would be surprised if you needed to anything to adjust for the high flow pump. You could swap the stock RS FPR for a SVX one if you wanted to get the fuel pressures back down to normal, but unless you were running really rich I wouldn't worry about it
Those are just my opinions, I am NOT a Subaru Master Mechanic so take them for what they are worth.
Aaron
AaronB is offline   Reply With Quote
Old 10-24-2001, 02:03 PM   #12
MattC
Member#: 158
2011 STi
PBP 1999 2.5RS RBP
Well, most bell units don't really become active until 1 or 2psi. So, its probably not doing much anyway. I would just take it out. The Supra fuel pump has a tendence to overload the stock FPR at idle. Pressure was bumped up on my car to ~43psi from something like ~36psi. Besides that, it will act exactly like the stocke pump. The AFC also does completely nothing. In fact I would probably take it all out and make a couple bucks.
Cheers,
MattC
MattC is offline   Reply With Quote
Old 10-24-2001, 03:15 PM   #13
Audipwr1
Member#: 9895
2012 Audi S4
BLACK
the AFC isnt great, but it does lean or rich the mixture, certainly better than nothing, and I cant just run the supra pump at idle and at accleration itll knock
Old 10-24-2001, 04:08 PM   #14
AaronB
Worst Mod Ever
Member#: 369
12 Vagon
06 WRX
It does?
If that is the case I would think all RS'es with upgraded pumps would have these problems when not in boost, since the RRFPR doesn't do anything until boost hits. Maybe I am just missing something...
I am running a high flow pump and a low compression engine on the stock ECU and the ECU can compensate enough to make the car driveable. I still get good mileage as well.
Aaron
Old 10-24-2001, 04:55 PM   #15
Audipwr1
Member#: 9895
2012 Audi S4
BLACK
ARRON THAT WAS EXACTLY WHAT I HAVE BEEN WAITING FOR!! AN ANSWER. thanks so much, Did it not have any problems when the turbo wasnt on too
Remember that this car wont hit boost cause it doesnt have any, so will this become a problem at higher revs???
to anyone w/a wrx swap into their rs using rs tranny and lightened flywheel: legacy2003 Subaru Conversions 1 11-01-2005 10:29 PM
Anyone selling used RS parts in Michigan? oldpreza Mid West Subaru Owners Club Forum -- MWSOC 6 05-17-2001 08:36 PM
Used RS brakes Narso Mid Atlantic Impreza Club -- MAIC 5 04-28-2001 05:41 AM
Looking for used RS or Legacy GT wheels. scooter2 North West Impreza Club Forum -- NWIC 2 04-21-2001 03:53 PM
used RS for sale at San Antonio car lot. suberstar 2.5 Texas Impreza Club Forum -- TXIC 0 12-13-2000 08:44 PM
