Old 07-18-2006, 11:05 AM   #1
-=C=-
Member#: 7719
99 F-150 crew cab
with illegals in bed
Default OT electrical gurus - school me on electricity
So what's the difference between amps/watts/volts?
I'm not completely stupid on the subject, but I definitely don't know much...
I do recall someone saying something like "it's not the voltage, it's the amperage that'll kill you!" but I'm not sure if I even have that right.
Just looking to get my learn on...and Google is too slow.
-=C=- is offline   Reply With Quote
Old 07-18-2006, 11:08 AM   #2
StiDreams
Member#: 26315
07 Outback
Silver/Silver
P (watts) = I (amps) * V (vlots)
V = I * R (ohms)
StiDreams is offline   Reply With Quote
Old 07-18-2006, 11:11 AM   #3
Grap
Member#: 6590
Search Ohms Law
I forget off the top of my head, but one is the 'speed' of the electricity, one is the 'amount' and I don't know the third one....
Grap is offline   Reply With Quote
Old 07-18-2006, 11:14 AM   #4
terboneon
Member#: 76193
I'm no expert, all I remember from ece class is amps (current) is how much electricity is flowing. And voltage (volts) is the potential difference. So even when the circuit is open, there's still voltage, but no current.
terboneon is offline   Reply With Quote
Old 07-18-2006, 11:18 AM   #5
rage557
Member#: 117441
2001 Impreza 2.5rs
Well for starters Watts = volts*amps. As for the basics of electricity its very hard to explain but i'll give it a shot.
Volts and amps are directly related. Each can be converted to the other. A good anology is HP and torque where Volts =HP and Amps = torque. And you are correct a very small amount of amps(less than one), provided it passes through the heart can kill you.
The amps going though the line can be considered the umph that the electricity has, that is why when you are welding you normally use anywhere from 120-200 amps. The number of amps going though a wire also designates the required wire size.
Voltage is a bit harder to explain I think somebody else will have to fill in that part
rage557 is offline   Reply With Quote
Old 07-18-2006, 11:19 AM   #6
KC
Member#: 442
13 Crosstrek XV
00 S2000
V = I * R (ohms)
KC likes Vlots!
KC is offline   Reply With Quote
Old 07-18-2006, 11:26 AM   #7
SVX WRX
Member#: 26358
2013 Chewbaccamobile
if you use the water analogy, current (amps) is the "water" flowing through a system and voltage is the "pressure". resistance can be thought of as pipes - higher resistance is a skinnier pipe.
current is the flow of electrons, and voltage is the potential difference.
SVX WRX is offline   Reply With Quote
Old 07-18-2006, 11:30 AM   #8
bobturismo
Member#: 42145
6-4 jockin da bish-
es and slappin the hoes.
Simplest explanation is think of it as ball bearings going through a pipe, maybe pushed by water. The bearings represent electrons, the more electrons you get to the other side, the more power you have.
Voltage is the amount force taht pushes the bearings through the pipe.
Amperage is the number of bearings in the pipes, that pass through.
You can have alot of water pushing the bearings though the pipe, but if you only have 2 bearings you're not gonna transfer alot of bearings, but at higher rate of speed you are getting the bearings there faster.
You can have 200 bearings and not alot of force behind them and still have alot of power, you have 200 bearings coming through slowly.
The total out put between the water and the bearings is the watts.
20 bearings x 1 volt = 20 watts
while
1 bearing x 20 volts = 20 watts
bobturismo is offline   Reply With Quote
Old 07-18-2006, 11:37 AM   #9
greenguy
Member#: 221
15 WRX CBS
2014 Crosstrek
When Current goes up, Voltage goes down.
and vise-versa.
greenguy is offline   Reply With Quote
Old 07-18-2006, 11:40 AM   #10
gte123v
Member#: 114481
2006 Sti
amps = electrical current, watts = electrical power, volts = electrical voltage.
The comment on that "it's the current that kills you and not the voltage" is a little miss leading. Like everyone pointed out, the equation governing everything are Volt=current*resistance, watt=volt*current. So, don't be fooled by only current can kill you, if you touch a 50KV transmission/distribution power line, you are gonna fry, and that's considered low voltage in the power industry.
gte123v is offline   Reply With Quote
Old 07-18-2006, 11:42 AM   #11
cRayZee
Member#: 6271
2001 2.5RSTi
2007 Legacy Spec B
I wouldn't think comparing Volts = HP and Amps = torque is a good idea. Horsepower and Watts are both units of power. Volts is a unit of potential energy. Amps is used to describe the current flow of electrons/electricity.
Current is measured from a higher potential energy to lower potential energy. But what's actually happening is the electrons are moving from the place with lower potential energy (more negative side side of the circuit) to the positive side.
cRayZee is offline   Reply With Quote
Old 07-18-2006, 11:55 AM   #12
daveB
Member#: 28488
2000 Pierce Saber
Fire Engine Red
when working on electrical wiring it's always a good idea to keep one hand behind your back so inadvertantly do not create a short with your body and close the circuit.
It's not the volts that kill you, but the amps. The body can withstand X amount of Volts but can only withstand Y amount of miliamps.
Basically your body can withstand a lot of volts at a low amperage but as you can see by this table the amout of amperge it takes to do damage isn't that high.
http://www.cdc.gov/elcosh/docs/d0500.../section2.html
daveB is offline   Reply With Quote
Old 07-18-2006, 11:59 AM   #13
beethoven
Member#: 6654
2006 Odyssey
2006 Prius
Static electricity is a good example of this. There is usually a very high voltage (difference in potential engergy) but the shock you receive is very low current (very few electrons jumping).
beethoven is offline   Reply With Quote
Old 07-18-2006, 12:02 PM   #14
StiDreams
Member#: 26315
07 Outback
Silver/Silver
Originally Posted by KC
KC likes Vlots!
Do you think Vlotaire would be offended?
Old 07-18-2006, 12:05 PM   #15
WRXGuyInUSA
Member#: 13967
Bye Bye STI!!!
You want to have some REAL fun??
Lets talk about "VARS" for a minute...
WRXGuyInUSA is offline   Reply With Quote
Old 07-18-2006, 12:07 PM   #16
RATyson
Member#: 34390
2002 WRX Wagon
while
Probably the best analogy to go by for the laymen.
<---RATyson is an electrical engineer
RATyson is offline   Reply With Quote
Old 07-18-2006, 12:22 PM   #17
WRXGuyInUSA
Member#: 13967
Bye Bye STI!!!
All the electrical "Guru's" back away slowly...
Old 07-18-2006, 12:30 PM   #18
RATyson
Member#: 34390
2002 WRX Wagon
Eh... VArs are just a phase... nyuk nyuk..
ok.. yeah, that was uber geeky
Old 07-18-2006, 01:45 PM   #19
Wires
Member#: 36677
2003 WRX Wagon
Sedona Red
I always used electricity to help me understand Torque and Horsepower.
Power is power (duh), Amps is like RPM, and voltage is like torque.
Horsepower is RPM*torque (and factors to make the units work out)
Power (watts) = volts * amps
So, a Honda is like a 5v power supply that is rated at 900 amperes - 4500 watts of power.
A truck engine is like a 500 volt power supply that is rated at 8 amperes.
A transmission would be like a transformer, but transmissions are more lossy and have physical constraints - that's why you can't put a Honda engine in a truck and use gearing to get the torque to be higher. The transmission would be too large and create too much loss.
This article is about transistors, but he's got some good introductory material about circuits, about half-way down or so.
Warning - lots of words here!
Wires is offline   Reply With Quote
Old 07-18-2006, 02:09 PM   #20
FD777
Member#: 84820
2005 WRX Sedan
Crystal Gray
I find this pdf helpful... I'm an EE and I forget the basics all the time
http://www.ddpp.com/DDPP3_pdf/elecCkts.pdf
It's an article suited for people who need a refresher on the basics. Hopefully, it'll still help.
FD777 is offline   Reply With Quote
Old 07-18-2006, 02:17 PM   #21
LastResort
Member#: 99289
I thought that looked familiar, it's an excerpt from the Digital design class.
LastResort is offline   Reply With Quote
Old 07-18-2006, 02:41 PM   #22
pigSTI04
Member#: 114793
Think of Amps as pressure of voltage...
How It Works
pigSTI04 is offline   Reply With Quote
Old 12-30-2014, 12:59 PM   #23
Cuddles
Member#: 161077
Can a run capacitor fail before a start relay?
Our fridge went to **** and a friend suggested replacing the run capacitor. However, I keep seeing these videos talking about the start relay and how it can fail due to heat. When I pulled our fridge out I saw that the fan under there was blocked and so I think something broke based on heat.
Symptoms: fridge turns on every 5-10 minutes for 30-60 seconds at a time. The light on the inside of the fridge goes really dim, like it is trying to pull a lot of power. Ice in the freezer started melting.
Cuddles is offline   Reply With Quote
Old 12-30-2014, 06:12 PM   #24
quazimoto
Member#: 70395
1.21 jiggywatts.......
quazimoto is offline   Reply With Quote
Old 12-30-2014, 06:18 PM   #25
Vart
Member#: 325031
2014 Forester XT
Does the fan ever start? If not I would check the fan motor first. Sounds like the compressor is short cycling because there is no air flow through the condenser.
Vart is offline   Reply With Quote
OT Mac gurus - school me on backup / raid / diaf Fuzz541 Off-Topic 7 11-26-2007 06:50 PM
Suspension gurus.. School me on swaybars Davenow Brakes, Steering & Suspension 7 07-13-2006 08:16 PM
computer gurus...school me on laptops... tool1128 Off-Topic 24 08-29-2005 06:31 PM
Ebay Motors, Gurus school me on buying cars rites Off-Topic 5 06-13-2005 09:56 AM
OT Fashion Guru's: School me on suits The Enemy Off-Topic 56 01-11-2005 08:28 PM
