Go Back   NASIOC > NASIOC Technical > Engine Management & Tuning > Other Engine Management
Old 07-18-2006, 12:34 PM   #1
jblaine
Member#: 8512
2002 WRX chassis...
stage-infinity.com
Default Hydra: 26MPG
Just a FYI:
On a recent trip to GA and back, I got 26MPG.
Details:
* I did not in ANY WAY drive "to get good mileage". I really couldn't care less what mileage I am getting as long as it's above 20 (below which I would care because I'd bet something was not functioning properly). This was a test for kicks. I think I last checked my mileage a year ago.
* Incredibly minimal AC use. Unless it is 88+ outside, I almost always drive with my windows down, even when doing 70 on an interstate.
* 2002 WRX with STI hood scoop. Aerodynamics? What's that?
* STI RA gear set (full). RPMs were almost constantly above 3200 while cruising on the interstate in 5th for hundreds of miles.
* Hydra was set to closed loop fueling with AFR Target Table as the 'sensor source'. RPM range was only 1900-3200. Long-term learning was enabled.
* My fuel map has nothing tricky in it. My AFR Target Table map doesn't either. Very standard setup.
jblaine is offline   Reply With Quote
Old 07-18-2006, 12:40 PM   #2
jblaine
Member#: 8512
2002 WRX chassis...
stage-infinity.com
2.0L
16G
TBE
158lb driver
80lbs extra in car
Old 07-18-2006, 04:07 PM   #3
rjrutzky
Member#: 30367
2005 Legacy GT
NASA SE PTB Champ
I also got around 25/26 mpg, driving from Maryland to Tennessee. Going mostly conservative, only busting on a couple high-winged hondas. Also, I have RA 5th gear. I was impressed. Phil made an excellent cruise tune. He specifically asked me what rpm/mph I cruise at and set it up accordingly.
EJ207
20G ewg
PE800
200lb driver
Wagon aerodynamics?
rjrutzky is offline   Reply With Quote
Old 07-18-2006, 04:21 PM   #4
InfamousDX
Member#: 25413
EJ207
20G ewg
PE800
200lb driver
Wagon aerodynamics?
wow that sounds pretty thorough. That would be helpful too.
Old 07-19-2006, 06:17 PM   #5
ejh25
Member#: 65267
The mpg is very encouraging. I am going hydra within the month! Can't wait to see some results.
ejh25 is offline   Reply With Quote
Old 07-19-2006, 06:33 PM   #6
PHATsuby
Member#: 13617
2001 Legacy GT back
to stock is a project too
This is good news, but I don't get why its surprising to get good gas mileage when you have closed loop on and its targeting 14.7(or whatever you have it set for), you should get good mileage regardless, because that is exactly what a stock car is doing too.
congrats though, that is good.
Ben
Old 07-20-2006, 09:59 AM   #7
jblaine
Member#: 8512
2002 WRX chassis...
stage-infinity.com
Not surprised, just pleased.
Old 07-24-2006, 09:22 AM   #8
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
jeff, was the target stoich?
Old 07-24-2006, 09:26 AM   #9
jblaine
Member#: 8512
2002 WRX chassis...
stage-infinity.com
Almost: 14.5:1 until 3psi
2011 Mustang GT: 5.0L V8: 412HP and 26mpg skywaffles Non-Subaru News & Rumors 863 07-26-2010 10:48 PM
FS/FT: 99 S10 ZQ8 - 26mpg - NY LenoChin Private Vehicle 'For Sale' Classifieds 9 04-04-2008 05:36 PM
Installed the Ultimate Racing GT35r kit with Hydra: feels absolutely amazing syoung0298 Off-Topic 47 07-31-2005 12:07 PM
Installed the Ultimate Racing GT35r kit with Hydra: feels absolutely amazing syoung0298 Off-Topic 27 07-29-2005 10:25 AM
hydra: 2 step. NeaD Other Engine Management 0 06-10-2005 12:40 AM
