Welcome to the North American Subaru Impreza Owners Club Monday August 29, 2016
Old 07-18-2006, 02:14 PM   #1
ryguy
Member#: 106407
2004 rex wagon
007 black
Default Shifter linkage tranny leak
Where the shift linkage goes into the tranny there some fluid comin out.
Has anyone else had this prob. How hard to fix. Is it an o ring or do i have to take that section of the tranny apart.
ryguy is offline   Reply With Quote
Old 07-18-2006, 02:16 PM   #2
Crazykev
Member#: 93667
'03 Build'n a 2.12L
331whp/331wtq
You sure the trans isn't over filled. Shift linkage goes through at a high point on the trans.
Crazykev is offline   Reply With Quote
Old 07-18-2006, 02:22 PM   #3
ryguy
Member#: 106407
2004 rex wagon
007 black
I'm pretty sure its not. That could be it,or I'm now thinking that parking on a hill like I do every night is the cause of this. Good call. Its torwards the rear of the car and I tend to park with the rear facing downhill. It is a pretty good slope 20 degrees I think.
Thanks for the help.
Old 07-18-2006, 02:30 PM   #4
Crazykev
Member#: 93667
'03 Build'n a 2.12L
331whp/331wtq
Parking on the hill will do it. There isn't a real seal at the linkage as far as I know and I've had them out a few times. It's on a roller type bearing and I alway grease the bearing which probably helps seal it a bit.
I wouldn't worry about it too much. If you back up, the trans has more area to disperse the oil befote it gets to the axle seals and at least they are an actual seal
Old 07-19-2006, 09:17 AM   #5
ryguy
Member#: 106407
2004 rex wagon
007 black
Thank you Crazy, I appreciate it. I"m gonna clean up the mess and not park on a hill for a while and see what happens. LOL.
I'm happy again knowing that it not a big deal.
Small tranny leak at shifter linkage PeterJ Transmission (AT/MT) & Driveline 18 11-16-2012 07:38 PM
FS: (NY) oem tranny mount and shifter linkage mikecsti Drivetrain 5 05-18-2010 11:35 AM
Tranny leaking where the shifter goes in? Tattoo! Transmission (AT/MT) & Driveline 0 05-31-2008 08:45 PM
Q: Is there a seal where the shifter linkage enters the tranny case? mpaone Transmission (AT/MT) & Driveline 2 01-15-2007 07:45 PM
RS shifter linkage on a FWD tranny? ^jynx^ Transmission (AT/MT) & Driveline 2 09-14-2003 07:05 AM
