Welcome to the North American Subaru Impreza Owners Club Sunday February 14, 2016
Old 10-02-2000, 10:30 PM   #1
mwalko
Member#: 2549
Post advice
I have a '95 2.2 lit. legacy. What are the most worth while modifications that I should start out with? Increased handling and performance are what I am mostly looking for. Will replacing the intake do very much? any adice or suggestions would be of service. thanks.
mwalko is offline   Reply With Quote
Old 10-03-2000, 03:19 PM   #2
slide
Member#: 1130
2013 STI Hatch
Post
Me too...Get the rear strut brace, the front strut brace and a set of coil overs. At least on my 95 when you lower the suspension more than 1.25 you have camber probs. So camberplates are needed. at that point your in the same amount as coil overs. LIght wheels and sticky tires.
Try the metal master brake pads... they're great.
If you have any other questions, email me
subaru@goplay.com
slide is offline   Reply With Quote
Old 10-03-2000, 05:51 PM   #3
AWDBat
Member#: 1983
2008 STi
Dark Grey Metallic
Post
I've got the exact same car it seems. The biggest difference was the rear sway bar, best handling improvement for the money. Also suspension (KYB AGX shocks and Eibach springs) made a huge improvement for me as well and lowered the car about 1.25inches (no camber probs! ) But I think I need better tires - I have the Impreza '00 rims with RE92 tires - okay, but could be better. Also have the Syms front and rear strut tower bars on the way.
[This message has been edited by AWDBat (edited October 03, 2000).]
AWDBat is offline   Reply With Quote
Old 10-03-2000, 09:09 PM   #4
pleiades
Member#: 2491
06 Miata
81 Fiat Spider
Post
You may want to check the disscussion in the thread: "Attn: Mccaskl ! Eibach Question." There has been a lot of posts about suspension tunning.
pleiades is offline   Reply With Quote
Old 10-04-2000, 09:31 AM   #5
gumball
Member#: 1209
Post
Hey, silly question. What is the diff betw. the GT springs/shocks and the L springs/shocks. The GT is a sport-tuned suspension, but I'm wondering if its as substantial as the diff betw. the 2.5RS and an Impreza L ? Looking at most non-GT legacys, they're ride height is exactly the same as my GT.
gumball is offline   Reply With Quote
Old 10-05-2000, 01:53 AM   #6
BG5
Member#: 695
Post
There is a stock ride height difference between the L/LSi/Brighton and the GT of
something like a half inch. (GT higher) This is straight out of the service manual specs.
GT springs are stiffer to cope with the heavier engine/drivetrain (IIRC avg about 20%) but are somewhat longer unsprung. (thus the higher ride height)
The same soft struts are used for all Legacy's (except OB of course)
[This message has been edited by BG5 (edited October 04, 2000).]
BG5 is offline   Reply With Quote
Used GR STI buying advice mbehe87 General Community 10 06-02-2010 05:12 PM
Need EQ advice or tweeter advice snorekl Car Audio, Video & Security 14 10-14-2006 11:48 AM
I need advice. N00bie relationship advice. Pretty Waste Off-Topic 52 07-28-2006 02:13 PM
Advice on running Group N tops in front only/perrin vs helix advice esper Brakes, Steering & Suspension 14 02-10-2005 12:20 AM
Drag advice, gettin better, but looking for advice Davenow Proven Power Bragging 9 09-02-2003 10:12 PM
