Welcome to the North American Subaru Impreza Owners Club Tuesday April 21, 2015
Canada Region Club
Go Back   NASIOC > NASIOC Regional Areas > Canada Region Forum > Western Canada
Old 07-18-2006, 11:39 PM   #1
Glyn
Member#: 104597
2006 Forester XT
Garnet Red Pearl
Default A/F Meter?
Hello, all!
Would anyone in the area have an A/F meter that they'd be willing to use on my car? I'm trying to figure out why my mileage is so poor on my 06FXT, and checking the A/F ratios is high on my list, now that I've tried the other obvious stuff (tire pressure, oil change, driving style, etc.)
I can offer beer or reasonable compensation.
Glyn is offline   Reply With Quote
Old 07-19-2006, 02:01 AM   #2
Chp_Stix
Member#: 95195
1974 Rat Rod Bug
back and white
try ecu explorer, if you can download it to your laptop and plug in your AP cable to your diagi port and to your laptop you can pull logs with it...
Kris
Chp_Stix is offline   Reply With Quote
Old 07-19-2006, 02:19 AM   #3
Airboy
Member#: 72829
2006 WRX
2015 WRX
I don't think Glyn has the AccessPort. If the on-board O2 sensor readings are good enough, I am sure Glyn can stop by the Dyno meet this weekend to borrow a cable.
What if the O2 sensor is defective and giving the wrong reading, causing the ECU to use too much fuel? Would logging reveal anything then?
Airboy is offline   Reply With Quote
Old 07-19-2006, 10:45 AM   #4
STi_Drift
Member#: 25759
99 impreza
rally blue
borrow a wideband. If your mileage is THAT crappy you should see and smell the richness... maybe reset your ecu by unplugging the battery for a night.
STi_Drift is offline   Reply With Quote
Old 07-19-2006, 12:29 PM   #5
Wombat North
Member#: 21267
STI, EWG 8cm Green
UTEC/ECUtek/WI & SD tune
First off what's your mpg. I get 4 mpg at the track and happy
Second
Are you using husky 92/94? This will reduce your mileage
Subaru's run very rich stock, dipping below 10 to 1 sometimes in open loop.
Its a turbo car on crap Alberta fuel needing lots of fuel to counter detonation while in open loop.
The factory ECU is one funky piece of gear. One time full timing the next 8 degrees is gone if it sees any detonation. Yes it saves your engine but over reacts and you lose power and fuel economy.
Your cars under warranty, get the dealer to check.
Wombat North is offline   Reply With Quote
Old 07-20-2006, 09:12 PM   #6
Geoff
Warden of NASIOC Timeout
Super Moderator
Member#: 592
'08 '08 X3 6MT
'09 135i 6MT/'15 GTI 6MT
The dealership won't do anything if there's no CEL. Also, if he ran any program that gets the A/F from the O2 sensor, it doesn't let him verify if the O2 sensor itself is acting funky. What he needs is a wideband O2 sensor that goes into the bung or in the tailpipe, as in one on a 4 wheel dyno.
Are there any 4-wheel dynos in Edmonton?
Geoff is offline   Reply With Quote
So Cal: HKS 60mm Chrono DB meter package 5 meters gqzboy Interior/Dressup/Audio & Security 14 06-21-2007 12:56 AM
FS: Blitz Boost Controller, Blitz Power Meter, Blitz Mirror Meters D1GP_old Private 'For Sale' Classifieds 5 07-15-2006 12:56 PM
G-Meter accuacy? Post g-meter times... dsmperformance Proven Power Bragging 3 08-26-2003 03:17 PM
Anyone has a picture of Blitz Power Meter or Apex Rev Meter installed? WRXVII Member's Car Gallery 1 03-10-2003 10:24 AM
A/F meter or EGT meter ? el crichon wrx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 11 04-06-2002 04:50 PM
