Welcome to the North American Subaru Impreza Owners Club Wednesday May 6, 2015
Old 07-19-2006, 12:20 AM   #1
wrxsown
Member#: 110646
2004 WRX
aspen white
Default HELP....another hella supertone install question
so pretty much im stupid and cant quite figure out how to install these....
I read some other threads on it and still am not sure rather or not to use the supplied relay or not, seemed to be mixed opinions. But regardless, my main question is if the stock thing that says "buzzer" that is located right to the left of the horn, is actually a horn.
From another site....86) Stock horn wire (take one of the stock horn wires off, and put in a male connector, extend the wiring with the one you bought, and with a female connector, plug it on the relay, ok first one done.
my question is it says take ONE of the stock horn wires off....it seems as though there is only one stock horn and it has only one wire going into it for a positive, so how do i connect the new supertones together....
is the "buzzer" actually a horn and do i use those two wires going into it as well???
thanks all for help
wrxsown is offline   Reply With Quote
Old 07-19-2006, 12:42 AM   #2
wrxsown
Member#: 110646
2004 WRX
aspen white
so i figured out that that definately is not a horn, its the buzzer for when your door is open and you press the lock button...
so why does everyone say the wiring from your OE HORNS (plural)....there is only one horn with one positive wiring going to it correct?
Old 07-19-2006, 09:23 AM   #3
specialev
Member#: 90156
1986 Syncro Vanaru
07 SV650
What kinda car are you delaing with? Up date your profile so we know whatcha got.
When dealing with a WRX there are two horns and a third one by the RF shock tower if your car has the security system. When you wire your horns in, you use the wire for one of your stock horns to trip a relay to shunt power to your supertones. You can have it wired in such a fashion as to retain the stock horns in addition to your supertones.
specialev is offline   Reply With Quote
Old 07-19-2006, 04:01 PM   #4
jblaze5579
Member#: 83473
jblaze5579 is offline   Reply With Quote
Old 07-20-2006, 05:34 PM   #5
wrxsown
Member#: 110646
2004 WRX
aspen white
car is an 04 wrx....
see this is the wierd part to me that confused me so much when reading other threads...
i have only one horn, mounted on the center pillar the attaches to the radiator support as well as one for the alarm on the shock tower. why wouldnt i have two then?? ive seen other pics where the other stock one attaches to the drivers side pillar, but i dont have it? whats up with that?
thanks
Old 07-22-2006, 02:32 PM   #6
armand1
Member#: 10309
'02 OBS 2-tone!
'95 Montego Miata
If you bought it used or it's been in an accident, someone may have removed the horn (or someone installed aftermarket horns and the dealer reinstalled only one OEM horn), or something like that.
Old 07-25-2006, 01:44 AM   #7
GravelRash
Member#: 16318
2002 WRX Franknwagen
Grime over Sedona Red
...and it shouldn't matter anyway: just use the hot lead to the existing single horn to switch the relay. If you want to keep that horn then splice into that wire to run the relay.
Don't use anything smaller than 12ga wire to actually supply power (through the relay) and ground for the horns themselves.
Ref's:
http://forums.nasioc.com/forums/show...06#post4505606
http://forums.nasioc.com/forums/show...highlight=horn
GravelRash is offline   Reply With Quote
09 wrx hella supertones install question punjabi408 Newbies & FAQs 21 08-23-2010 01:28 PM
Another Hella 500 install question. OUScooby Electrical & Lighting 18 02-06-2010 01:32 AM
Hella Supertones install question thunder_lizard_1976 Electrical & Lighting 5 03-27-2008 11:52 PM
hella supertones install question krambte79 Electrical & Lighting 8 04-17-2007 11:30 AM
Hella Supertone Install Question USF97J4x4 Interior & Exterior Modification 9 12-31-2005 10:17 AM
