Go Back   NASIOC > NASIOC Technical > Engine Management & Tuning > Other Engine Management
Old 07-19-2006, 05:40 AM   #1
SanMan
Member#: 120579
1995 STi V2 Wagon
Unhappy Can some help me decifer LINK ECU?
Hi All,
Being new to LINK ECU tuning I have no clue what is what when what... if you get what I mean?
I can send my map, please could someone help out with a few guidelines on how to program this LINK as there is no support for LINK in JHB, South Africa... nice hey Anyways even telephone numbers would be fine...
I need some guidelines and best practises... Programming these things aint rocket science I am sure... Please help?
Many thanks
SanMan
SanMan is offline   Reply With Quote
Old 07-19-2006, 12:33 PM   #2
Drac9
Member#: 9861
1999 2.35 RS-T w/NOS
Hybrid Rally Blue Pearl
To tune fuel on the link you use the master (should typically be close to 100 depending on the size of your injectors), then you tune by row and finally by cell. This is best done on a load bearing dyno with an accurate wideband afr monitor.
Timing is easy. Just use a laod bearing dyno. Most of the other settings you can leave alone. Idle can be a bit tricky- just have to play with it. Basically just read the manual fo the other features- it walks you through what the values mean, etc.
Drac9 is offline   Reply With Quote
Old 08-08-2006, 01:21 AM   #3
fc3swrx
Member#: 21009
2008 Sti
Blue w/ Gold BBS wheels
Default Link the absolute easiest to program..
Originally Posted by SanMan
Hi All,
Many thanks
SanMan
Not sure what experience you have, have you tuned any stand alone or piggy back systems before? if so which ones, it might help us to help you understand the comparisons.
If not, then get ready to learn, it's not so much the link you need to learn but stand alone engine management theory. Basically the fuel and ignition maps read the MAP sensor and adjust fuel to the specified value in the corresponding cell. On the left is 0 thru 300, 0 is vacum and 300 is 30psi, 14.7 psi is 200, 100 is well 0. The ignition is the specified value +10. so if it reads 12 then it's actually 22.
depending on where you got the link you might try to find out what size injectors it had configured previously. From experience I was able to start my car configured for stock 440cc injectors with 740cc injectors installed, it did run like crap but you could at least alter it while it was running... shoot me an e-mail, I'll help as much as I can, I personally love the link... there are a lot of haters, but I've been running mine going on 2 years and it's never let me down once.
fc3swrx is offline   Reply With Quote
Can Anyone Help Me Flash My ECU Back To Stock? NickBreton89 Southern California Impreza Club Forum -- SCIC 2 06-03-2008 05:59 PM
can anyone local help me reflash my ecu? jconaty07 Commercial ECU Reflashes 2 11-15-2007 01:48 PM
Can somebody help me with some basic aluminum machining? Red Rocket New England Impreza Club Forum -- NESIC 6 05-26-2003 06:49 PM
new alignment specs: help me decifer iloveturbos Brakes, Steering & Suspension 5 02-12-2003 08:07 AM
Can somone help me pull ECU code ac_gohan Bay Area Impreza Club Forum -- BAIC 4 01-18-2002 03:02 PM
