Old 07-19-2006, 06:43 PM   #1
fenix281
Member#: 98481
2001 Impreza L
Green
Default RS Heads
I've heard that the rs heads from the 2001 2.5l will bolt on to the 2.2l. What I'm wondering is if its true and where I can find used heads for cheap. Any info would be appreciated.
fenix281 is offline   Reply With Quote
Old 07-19-2006, 10:52 PM   #2
Rally_wgn
Member#: 62629
1996 OBS in Green
2.5 N/A w/ full exhaust
They will but compression is significantly lower so less power. If your looking to turbo this would be a good thing on the surface but I dont think either the block or the heads are capable of holding much boost.
Rally_wgn is offline   Reply With Quote
Old 07-21-2006, 12:38 AM   #3
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
By my calculations the CR would only be about 0.4 lower, which would impact power, but I'm not sure I'd call that "significantly lower". That's using numbers for a '97 EJ22, though, so I don't know how much different an '01 EJ22 may be (as far as head volume and piston volume goes). Using numbers from here - http://wac.addr.com/auto/obs/turbo/ejcalcs.html - I get 9.35:1 compression, compared to 9.7:1 stock for the '97 EJ22.
AFAIK the EJ25 heads flow way better than the EJ22 heads, so that should more than make up for the lower CR (I think).
Pat Olsen
'97 Legacy 2.5GT sedan
Old 07-21-2006, 12:41 AM   #4
Rally_wgn
Member#: 62629
1996 OBS in Green
My response was based on answers to similar questions posted here, admittedly I never ran the number so...
Thanks for the more knowledgable information Patrick.
Old 07-21-2006, 02:02 PM   #5
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
To get it right, one needs to be very specific about which Ej25 heads and which Ej22 heads they are using. Also, whether it is a phase I Ej22 or phase II Ej22 will matter as it will impact deck height. I think the mid 8's number that is so often thrown around is confusing as that is for SOHC Ej25 heads on a phase I Ej22 block. I am not going to bother to re-run the numbers as I trust Pat's math and tend to agree with his assessment of the impact. Though, with a stock cam, I think the gains will be marginal at best...
2004 WRX head unit and 98 RS head unit with pocket Turbo_Twinky NWIC Private Classifieds 0 03-05-2010 08:26 PM
WTB: 00' RS Heads/Head - NY Trademark Private 'Wanted' Classifieds 0 07-03-2006 05:24 PM
22T running PII SOHC RS heads on stock RS ECU idea “what do you think” amorton Built Motor Discussion 21 06-05-2006 06:56 PM
RS Heads vs. WRX heads JDM_Scobaru Subaru Conversions 39 01-10-2005 03:36 AM
2004 WRX Heads vs. Phase II SOHC RS heads... latinskllz Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 06-28-2004 01:28 PM
