Old 07-19-2006, 11:51 PM   #1
vicdeng
Member#: 53355
2002 02 WRX
WR Blue
Default How can u adjust the JDM projector headlight?
Like the title stated, do u guys use a screwdriver? i tried, and it doesn't help help much, are their pattern supposed to be \_ \_?
vicdeng is offline   Reply With Quote
Old 07-20-2006, 12:10 AM   #2
taerron
Member#: 75744
2k2 low boostin
evo3, for now....
yes, they are suppose to look like that. you can not make it look any different without opening them up and changing the cutoff
taerron is offline   Reply With Quote
Old 07-20-2006, 12:48 AM   #3
vicdeng
Member#: 53355
2002 02 WRX
WR Blue
Can i adjust the projector to raise or lower the beam position?
Old 07-20-2006, 12:55 AM   #4
Handsdown
Member#: 29355
yes but you have to add washers to the inside mounting points unless you want to aim your highbeams down as well, the adjusters move both.
and even then, you'll lose all roadsign illumination on the passenger side because of the cutoff being aimed so low.
Handsdown is offline   Reply With Quote
Old 07-20-2006, 03:20 AM   #5
taerron
Member#: 75744
2k2 low boostin
evo3, for now....
by lowering the beam you will lose your lighting distance. those lights are not the best idea for the car. they are not meant to be used here in the US. some people will argue this fact, but either a.) you lower them to avoid blinding oncoming traffic and reducing you light output or b.) you keep them up and piss off oncoming traffic. i've seen it first hand with another psm 02 wrx with those lights and i was kinda pissed too.
Old 07-20-2006, 01:59 PM   #6
chaddeus
Member#: 56624
2004 Subaru WRX STi
adjusting the xenon headlight is not as easy as you may think.
- Charles
chaddeus is offline   Reply With Quote
Old 07-20-2006, 06:04 PM   #7
taerron
Member#: 75744
2k2 low boostin
evo3, for now....
he wasn't talking about a xenon, he was talking about the stocker projector.
Old 07-20-2006, 06:38 PM   #8
daverup
Member#: 3708
2015 WRX Ltd Sedan
ISM
It doesn't really matter here.
JDM is RHD (Right Hand Drive) ONLY. If you wan't to fix them you'll have to take them apart. No adjustment will fix the beam pattern.
Many old threads around here that explain this.
Get rid of those things before you cause an accident. Either you can't see or the oncoming traffic can't see, Not Good!
daverup is offline   Reply With Quote
Old 07-20-2006, 07:06 PM   #9
taerron
Member#: 75744
2k2 low boostin
evo3, for now....
+1 save up cash for some edm's or do a retro like i will be doing in the next few weeks
How are you liking the BG projector headlights? linsavy Legacy Forum 7 08-13-2006 09:23 AM
how do i adjust the aim of headlight on a 2005 rs chanyeehon Electrical & Lighting 5 07-30-2006 05:12 PM
Where can I get 02 JDM Projector Headlights minx1225 Interior & Exterior Modification 15 07-21-2005 11:28 PM
How can you adjust the wastegate arm? waitandbleed92 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 02-19-2004 02:36 AM
Am I the first in Houston with the JDM projector headlights? -=Ph/\t WRX=- Texas Impreza Club Forum -- TXIC 23 05-23-2002 09:03 PM
