Welcome to the North American Subaru Impreza Owners Club Friday February 12, 2016
Old 07-20-2006, 01:00 PM   #1
njskatchmo
Member#: 94618
2002 Bugeye
Default Tire Size vs. Wheel Width
I searched and couldn't find a final answer.
I'm considering aftermarket rims. What effect will going wiht 7" wide rims ofver 7.5" wide rims have. Theoretically if i understand correctly i should be able to fit wider tires on wider rims but I understand its also limited by the fenders. So my question is. If I plan on lowering (probably prodrive springs) what will be my tire size options with 7" and what will be my tire size options with 7.5"
njskatchmo is offline   Reply With Quote
Old 07-20-2006, 01:14 PM   #2
Jon Bogert
Member#: 1133
09 GTR, 02 996 C4S
95 993 C4, 71 911, 04 STI
Assuming 17" wheels, 215/45-17 on 7" and 225/45-17 on 7.5" are the typical sizes. If you have a sedan, no reason not to go with the 225s on 7.5.
Jon Bogert is offline   Reply With Quote
Old 07-20-2006, 01:16 PM   #3
njskatchmo
Member#: 94618
2002 Bugeye
will the difference between 215 and 225 be noticeable? Im thinking about getting uk 17's to maintain the sotck look.
Old 07-20-2006, 03:10 PM   #4
fliz
Member#: 30342
I've talked to people who claimed they can notice a difference...but given the variance in tire size from mfr. to mfr, I'd doubt it.
FYI...on a WRX sedan you can run 17x8 and 235/40 w/o rubbing.
And in competition, you WILL notice a difference between a 215 and a 235.
fliz is offline   Reply With Quote
Old 07-20-2006, 03:37 PM   #5
waktasz
Member#: 86356
2015 s1000r
wheelie monster
No reason you can't run 225s on a 7" wheel. I'd still recommend getting an 8" wheel though. Leaves more options open for the future.
waktasz is offline   Reply With Quote
Old 07-20-2006, 06:20 PM   #6
njskatchmo
Member#: 94618
2002 Bugeye
what options are there past 235 wont they all rub if they are larger?
Old 07-20-2006, 07:43 PM   #7
waktasz
Member#: 86356
2015 s1000r
wheelie monster
You can fit 255s with minor fender rolling.
Old 07-21-2006, 10:26 AM   #8
subber
Member#: 63243
2004 WRX
I had 245/40/17 on 17x8 +48 wheels with no rubbing on my WRX. No rolling required either.
subber is offline   Reply With Quote
Old 07-21-2006, 01:04 PM   #9
fliz
Member#: 30342
Yep. Most people have that experience.
But there are some cases where rubbing happens. A little rolling and/or spacers fixes it.
Old 07-21-2006, 01:29 PM   #10
Wolfen42
Member#: 33060
2006 WRB WRX Wagon
I turbocharge campfires.
Keeping in mind the rules of whatever racing you might be participating in...
Wolfen42 is offline   Reply With Quote
Old 07-21-2006, 03:54 PM   #11
waktasz
Member#: 86356
2015 s1000r
wheelie monster
Are you lowered? I could probably justtttt clear, but I'll roll my fenders anyway.
Old 07-30-2006, 09:38 PM   #12
subber
Member#: 63243
2004 WRX
^^^ Yes I was lowered with Eibach springs at the time I was running that tire size.
Old 07-31-2006, 08:44 PM   #13
Hunt3r
Member#: 95484
Why overgear? I stuck with 215/45/17's on my 7.5" rota's so I would be slightly undergeared which = slightly better acceleration which = a bigger grin on my face. I can still hit almost 70mph in 2nd gear anyways...
Hunt3r is offline   Reply With Quote
Old 07-31-2006, 09:26 PM   #14
waktasz
Member#: 86356
2015 s1000r
wheelie monster
235/40 is shorter and wider than 215/45.
Old 07-31-2006, 10:36 PM   #15
Hunt3r
Member#: 95484
235/40's aren't recommended for 7.5" wheels, you need at least 8" wide wheels and most 235/40's are measured on 8.5" wheels.
Old 07-31-2006, 10:54 PM   #16
waktasz
Member#: 86356
2015 s1000r
wheelie monster
what ev.
tire size vs rim size 06STi Tire & Wheel 4 08-14-2007 10:56 PM
Tire width vs. Wheel width? yamahito Tire & Wheel 8 01-28-2007 06:21 PM
Wheel Weight Vs. Wheel Width ... What's more important ... makofoto Motorsports 19 09-13-2004 01:26 PM
Attn: Luke-Tire size to wheel width rules wawazat Tire & Wheel 2 04-15-2003 03:25 PM
Offset vs. Wheel width question bobafett Brakes, Steering & Suspension 5 10-08-2002 11:35 PM
