Welcome to the North American Subaru Impreza Owners Club Wednesday October 26, 2016
Old 07-26-2000, 06:14 PM   #1
Member#: 1919
1994 Legacy Turbo
Post Canister Purge Control Solenoid
For the record, I've found the location of this device on the Legacy 2.2l Turbo engine (it's probably in the same place on the non-turbo). It's attached to the UNDERSIDE of the #1 cylinder intake manifold runner. If you look down between runners #1 and #3, you can see it. The bolt that attaches it to the runner is UNDERNEATH the solenoid. I was able to get a 12mm box wrench on the bolt and give it a turn, but that's as far as I went for now. I just wanted to see if I could find the solenoid and determine if it is possible to remove without removing the entire intake manifold! It looks like it is, so tomorrow I'm going to buy a new solenoid and install it this weekend. If I'm successful, I'll post instructions. If I'm not successful...
'73 Datsun 240Z
'94 Legacy Turbo
Nigel is offline   Reply With Quote
Old 07-26-2000, 07:02 PM   #2
Member#: 132
2006 GT Ltd 5spd sdn
'15 WRX 6spd CWP, '02 WRX
Told you it was a bitch
Shik is offline   Reply With Quote
WTB: Purge Control Solenoid Computergeek24 SCIC Private Classifieds 2 02-05-2008 09:30 PM
WTB: Purge Control Solenoid Computergeek24 Private 'Wanted' Classifieds 4 02-05-2008 07:01 PM
Purge Control Solenoid Valve?? abosworth Normally Aspirated Powertrain 3 07-21-2005 04:20 PM
Code 35 purge control solenoid valve troubles theascen Service & Maintenance 2 04-02-2004 04:36 AM
What does the purge control solenoid do? MadMax Normally Aspirated with bolt-on Forced Induction Powertrain 7 09-27-2001 09:26 PM
