Welcome to the North American Subaru Impreza Owners Club Saturday February 6, 2016
Old 10-22-2001, 01:45 AM   #1
kaos200
Member#: 2692
Arrow DAMN 2.5s sound mean at 7,000 RPM!
especially with 1st gear whine!
so whats the highest anyone has taken their 2.5 without blowing it?
8,000? higher?
I cant imagine what it would be like to have 8,000rpm with headwork and boost!
kaos200 is offline   Reply With Quote
Old 10-22-2001, 01:49 AM   #2
Eric SS
Sooby Guru
Member#: 1914
2000 2.5RS w/ EJ22T
swap and N20. gone. : (
Are you talking with stock valve springs? One of our fellow clubbers takes his (albeit a 2.2RS) to 7,600rpm's
Eric
Eric SS is offline   Reply With Quote
Old 10-22-2001, 01:55 AM   #3
kaos200
Member#: 2692
Eric
yeah what i meant by headwork, cams, springs, retainers, valves, port/polish etc..
who's 2.2 RS would that be?
but still, 2.5 all the way man! Torque is definitely sweet, and I can feel it almost the whole way (starts to taper, still working on the top end fueling and timing parameters)
Old 10-22-2001, 02:18 AM   #4
Eric SS
Sooby Guru
Member#: 1914
2000 2.5RS w/ EJ22T
Yes 8,000 is do-able. I would rather not mention his name for fear of incrimination
Eric
Old 10-22-2001, 04:06 AM   #5
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
Just get going about 60mph and drop it back into second. Now THAT would be an interesting sound.
Old 10-22-2001, 04:10 AM   #6
Andrew
Member#: 1170
2005 STi
kaboom.
Andrew is offline   Reply With Quote
Old 10-22-2001, 05:12 AM   #7
bsquare
Member#: 1911
2000 Impreza 2.5RS
Silverthorn Metallic
You are beyond the limits of the bottom end at that point. I wouldn't recommend it, especially not frequently or for an extended period. Your bearings will be very dead.
Ben
bsquare is offline   Reply With Quote
Old 10-22-2001, 11:25 AM   #8
kaos200
Member#: 2692
Ben
cough*Built up*cough*
Old 10-22-2001, 12:20 PM   #9
t.rod
Member#: 1447
2000 Impreza
2001 Dodge 2500
What have you done to get your 2.5 to 7k? Sounds interesting.
t.rod is offline   Reply With Quote
Old 10-22-2001, 02:12 PM   #10
kaos200
Member#: 2692
Ben
Wait a minute, why do you feel the bearings would be dead after running at 7,000rpm?
thats not alot, so this doesn't make sense to me, please explain
Old 10-22-2001, 03:09 PM   #11
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
'09 Concours 14 ABS Black
in a balanced and blue printed motor 7k isn't that high.
Jeremy
Old 10-22-2001, 03:32 PM   #12
mastervic27
Member#: 557
1999 Impreza 2.5RS
Vishnu Turbo
Thumbs up
EJ25 is stronger than we think.
mastervic27 is offline   Reply With Quote
Old 10-22-2001, 11:24 PM   #13
zaidallas
Member#: 4106
Wink
I'll be finding out what an ej25 on +20 psi and +7000 rpm sounds like very shortly
zaidoun
zaidallas is offline   Reply With Quote
Old 10-23-2001, 03:22 AM   #14
kaos200
Member#: 2692
zaidoun
sweet hopefully the same here
Old 10-23-2001, 03:37 AM   #15
scotty305
Member#: 8877
2000 Impreza 2.5RS
(sept '01-jan '04)
Kaos, could you post some sound clips please? I'm dying to hear what a EJ25 sounds like with turbo, and the 7K revving sounds like a lot of fun, too. If you need help with recording methods, and how to get your info on the 'net, just PM me...
-scott-
scotty305 is offline   Reply With Quote
Old 10-23-2001, 07:32 PM   #16
Fitz
Member#: 1426
'07 335xi, '07 ZX6R
SV650 Race Bike
EJ25 at 7000rpm and 20+psi?? What size fuel injectors are you running?
Thanks,
Fitz
Fitz is offline   Reply With Quote
Old 10-23-2001, 09:04 PM   #17
kaos200
Member#: 2692
guys I took the turbo off to break in the new motor, as soon as my front mount and new wastegate are in, Ill be ready to have some fun
Kian
Old 10-23-2001, 09:15 PM   #18
bsquare
Member#: 1911
2000 Impreza 2.5RS
Please see the LENGTHY thread on ScoobyNet about bearing failures in EJ engines. An evil combination of weaknesses in the motors often conspire to cause catastriphic failures after driving at high RPMs. Great care should be taken when risking these RPMs.
I plan to tune for power below the factory redline, even with built internals.
Ben
Old 10-23-2001, 09:28 PM   #19
kaos200
Member#: 2692
Ben
do they know if it is the dynamics of the motor, or the actual bearings themselves?
I have aftermarket bearings not Subaru so I hope it would be the later and that mine hold up
Old 10-23-2001, 10:25 PM   #20
zaidallas
Member#: 4106
Kaos200 : what kinda FMIC are you getting , and how built is the engine going to be , it sounds interesting . I've also been waiting for ever for my front mount to come in .
Actually I'll probably run high rpms only for testing and for the track but not on the street.
fitz; I got 8 injectors : four factory ones and four 550's which will be upgraded soon if the need comes up.
zaidoun
Old 10-24-2001, 02:53 AM   #21
kaos200
Member#: 2692
im getting a custom fmic, not a kit
the engine is built, just a little bit of work left to finish it off, but its running, and nicely at that
Old 10-24-2001, 03:34 AM   #22
bsquare
Member#: 1911
2000 Impreza 2.5RS
The problem is a combination of poor oil flow layout to some cylinders and detonation at high RPMs due to poor fuel rails or poor tuning. I don't believe afatermarket bearings (I didn't even know they existed for Subarus!) would help much with this. Extreme care in oil change procedure and proper tuning are the best defense if you simply have to rev that high.
Ben
Old 10-24-2001, 11:36 AM   #23
adeck
Member#: 6840
2001 2.5RS
Blue Ridge Pearl
Default 8350 rpms
8350 rpms I reached one day by an accident. Stock motor, I had a borken shifter and it was a pain in the ass to get into gear. At 80mph I went from 3rd-2nd by an accident, my safc recorded it at 8350 rpms.
adeck is offline   Reply With Quote
Old 10-24-2001, 04:46 PM   #24
kaos200
Member#: 2692
Default Re: 8350 rpms
still running strong I presume?
also thatd be a little different than throttling up at that rpm I think
Kian
Old 10-24-2001, 09:10 PM   #25
bsquare
Member#: 1911
2000 Impreza 2.5RS
There is a vast difference in load between accidentally blipping that high and going WOT to that high and staying there.
Ben
rattling at 3,000 rpm please help! madeguy Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 17 07-01-2006 03:46 AM
Tuning done...My NA RS redlines at 8,000 rpm! dcoty Normally Aspirated Powertrain 93 08-24-2005 08:38 PM
FS: AutoMeter 5340 Pill Shift Light. 7,000 rpm Pill included 2ndGearFling Private 'For Sale' Classifieds 5 04-03-2005 10:41 PM
sudden gain in power at 4,000 RPM? yamahito Normally Aspirated Powertrain 17 04-21-2003 06:11 PM
Dead spot at 4,000 RPM? The Wraith Normally Aspirated Powertrain 14 07-17-2001 11:38 PM
