Welcome to the North American Subaru Impreza Owners Club Wednesday September 2, 2015
Old 07-20-2006, 04:04 PM   #1
WRXINTX
Member#: 96712
Default What oil pressure is excessive for a SUPER HIGH HP 2.5L?
hello all....
I have what I think is excessive oil pressure, but I am wondering if I should mess with it or just leave it alone.....
I run a mix of DELO 400 40W with 25% Lucas oil treatment added for extra protection..... and it is 105 degrees right now where I live in Texas.....
The car starts cold at 120psi of oil pressure... once fully warmed up, it idles at 85psi.... and when I am driving, it runs at 110psi at 3500rpm....
It has an ARC oil pan and I run a remote filter mount setup with a K&N oil filter that holds about one quart, so my system capacity is about 6.5 quarts total....
It never knocks or has any problems really associated with oil pressure.... but the gauge being pegged out kinda is different than what I am used to seeing....
I have heard that these engines like lots of oil pressure to keep them safe... I just don't know how much???
Thanks!
RYNO
WRXINTX is offline   Reply With Quote
Old 07-20-2006, 04:41 PM   #2
neversatisfied
Member#: 42631
03 Subaru WRX
Silver T67 equipped
Your oil pressure is quite a bit higher than I have seen mine. What kind of gauge are you using for oil pressure?
neversatisfied is offline   Reply With Quote
Old 07-20-2006, 04:45 PM   #3
WRXINTX
Member#: 96712
Nexxus autometer.....
It pegs the 100 psi scale most of the time....
I am probably going to put a mechanical oil pressure gauge on it to test the accuracy of the nexxus....
just to be sure.....
I dunno tho??
Old 07-20-2006, 05:03 PM   #4
SloRice
Member#: 44351
2004 Mitsubishi Evo
701whp 9.91@146
On cold start, I idle at 90psi. Once warmed up, I idle at 20psi. And cruising along, I vary between 60-75psi.
SloRice is offline   Reply With Quote
Old 07-20-2006, 05:26 PM   #5
kevinh211
Member#: 56297
2013 Focus ST
2004 STi MSPT Tuned
i have the nexus oil pressure gauge
when the car is warm my idle pressure is 20-30psi and crusing its at 80psi
kevinh211 is offline   Reply With Quote
Old 07-20-2006, 06:25 PM   #6
Token-Negro
Member#: 81659
2006 STI / 2010 FXT
Aspen White / Silver
Location of the Sensor?
Token-Negro is offline   Reply With Quote
Old 07-20-2006, 07:55 PM   #7
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
Hydra+HMist+PPG+35R=DEATH
ditch the lucas
i read a long thing showing it increases emulsion of air and oil by like 40%
Old 07-21-2006, 10:11 AM   #8
WRXINTX
Member#: 96712
front of the block right above the crank position sensor
Old 07-21-2006, 10:13 AM   #9
WRXINTX
Member#: 96712
Originally Posted by White 2.5rs
ditch the lucas
I will consider that next oil change in a few weeks probably...
I have had really great luck with Lucas products in the past on many of my race engines though... so I thought I would use it in my race suby....
Old 07-21-2006, 10:16 AM   #10
RedTRex
Member#: 18513
JMS Clan Guy #11
2005 Alpine White ZHP
that's pretty much normal.
RedTRex is offline   Reply With Quote
Old 07-21-2006, 11:24 AM   #11
jiml
Member#: 26479
I have a heavily modified 2.5, running a 22T oil pump....100-90 psi cold at idle; 60 psi hot at idle; 90 psi hot cruising; and 120-125psi hot under heavy load. Idle=1200 rpm. Hot=~190-220F oil.
jiml is offline   Reply With Quote
Old 07-21-2006, 11:53 AM   #12
WRXINTX
Member#: 96712
more like mine sounds like!!!!
cool....
thanks!!!!
Old 07-21-2006, 12:25 PM   #13
Master2192
RIP 10/12/83 to 02/10/08
Member#: 83254
98 2.5 RS
04 WRX
ditch the lucas
I agree, read this.
http://www.bobistheoilguy.com/images/lucas/lucas.htm
Old 07-21-2006, 12:41 PM   #14
TheMadScientist
Member#: 23717
2005 Big red
40W will increase the oil pressure. That could be the reason you are seeing higher pressure than what everyone has stated here. Is it 10W-40 or straight 40W?
TMS
TheMadScientist is offline   Reply With Quote
Old 07-21-2006, 04:07 PM   #15
WRXINTX
Member#: 96712
straight 40w...... which I realize is one way to make super high oil pressure....
I run a single viscosity oil to reduce viscosity break-down at high oil temps....
always run it in my race turbo engines of other brands with similar tolerances....
seems to slow oil usage too.....
Old 07-21-2006, 05:03 PM   #16
neversatisfied
Member#: 42631
03 Subaru WRX
Silver T67 equipped
Ditto. Right around there. A little higher once warmed up, but only like 5 psi more.
Old 07-24-2006, 05:51 AM   #17
STimo
Member#: 110273
450 whp 30R STI
11.3@123, 10's a commin'
^I run basically the same as stated above, give or take 5 psi.
STimo is offline   Reply With Quote
Old 07-24-2006, 06:39 AM   #18
TheMadScientist
Member#: 23717
2005 Big red
Not a lot of subie guys run that thick of oil. Never mind a single viscosity.
The 40W+upgraded pump is probably why you are seeing pressures higher than most people report. Next oil change try going down to a 30W and I bet your pressures will come closer to what is considered "normal".
TMS
Old 07-24-2006, 02:11 PM   #19
cdvma
Member#: 21980
2002 PSM WRX (Sold)
2009 BMW X5
TMS you still run 40w? I've been using 10w40 in the summers and 5w30 in winters. I see the same pressures more or less.
cdvma is offline   Reply With Quote
Old 07-24-2006, 02:28 PM   #20
drees
Member#: 25905
2003 Silver Wagon
Tuned with Enginuity
Keep in mind that if you are running thicker oil, you NEED increased oil pressure to maintain oil flow at the bearings, so the higher oil pressure is normal. Even with the higher oil pressure, actual oil flow rate is lower with a 40wt oil than a 30wt oil.
BTW, hot (212F) oil pressure will be the same whether you are running a 0w40, 5w40, 10w40 or a straight 40. But cold oil pressure will be MUCH higher with the single weight. I'm sure the OP already knows, but cold straight 40wt oil is very hard on the engine, it is even more important to keep revs and boost down until the oil is warmed up so the pump can move it through the engine.
Finally, oil pressure varies directly with RPM, engine load does not change oil pressure.
drees is offline   Reply With Quote
Old 07-24-2006, 03:10 PM   #21
TheMadScientist
Member#: 23717
2005 Big red
I use 10/40 in the winter and have switched to 20/50 for the summer all diino. I just don't like how thin a synth of the same weight is.
If I ge arround to putting in an oil cooler then I will go back to the 10/40 year round.
TMS
Old 07-24-2006, 06:01 PM   #22
flycaster
Member#: 60142
2011 WRX
Grey
Ditto, until the built motor gets about 5-6K on it - from then on it'll be 10w-40 and 15w-50, synthetic. 5w-30 looks and feels like colored water at this time of the year, and I live at 4,000'.
My pressure numbers are very similar to Slorice's numbers.
flycaster is offline   Reply With Quote
Old 07-25-2006, 12:09 PM   #23
2phless
Member#: 69343
1998 TransAm cnvrtbl
Unless you are trying the "ring-land delete mod" on a couple of pistons.
And to chime in my #s :
5w 30 winter/ 10w 30 summer. Not a rediculous power house but well over stock. My pressures also read like the lower numbers noted above. 90-95 cold/ 35 warm for idle. 85 cruising warm.
2phless is offline   Reply With Quote
any1 know what fabrication work is needed for older exuast to fit 2.5i? subiesurfer Normally Aspirated Powertrain 3 03-06-2008 08:47 AM
what spark plugs should I use for over 550+whp on 2.5L WRXINTX Built Motor Discussion 20 08-09-2006 12:45 PM
Oil pressure is high vf22-wrx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 16 05-06-2006 08:15 PM
2.5i VVL at what oil pressure? scottmcphee Normally Aspirated Powertrain 5 04-18-2006 10:47 PM
