Welcome to the North American Subaru Impreza Owners Club Tuesday August 23, 2016
Go Back   NASIOC > NASIOC Classifieds > Vendor 'Group Buy' Classifieds
Closed Thread
Old 07-20-2006, 04:14 PM   #1
Caliente Auto
Vendor Sales Rating: (11)
Member#: 59051
2004 WRX Sedan
Default Cosworth, Yes Cosworth! as in Formula 1....
We are in the works with Cosworth to become a distributor of their products!
To start dealing with them directly we need to place a large order so to do that we are looking for preorders on anything Cosworth. Pricing will be determined on how many items we get on our initial order. I promise it will be worth it!
Cosworth celebrated its 45th year at the top of the world motorsport stage in 2003. During that time, Cosworth has established itself as the most successful engine manufacturer in Formula One as well as achieving numerous successes in CART, Indycars and the World Rally Championship.
Please check out some of these amazing items please PM for pricing.
Cosworth EJ25 (STI) short block
New Subaru EJ25 STI Engine Case
New Subaru STI Forged Crankshaft
Cosworth Forged Connecting Rods
Cosworth Forged Pistons
Cosworth High Performance Piston Rings
Cosworth Race Spec coated Tri- Metal Bearings
Balanced and Professionally assembled
Billet Crankshaft optional
Subaru CNC Ported Big Valve Cylinder heads
CNC Ported/machine finished ports - New OE Castings
Hand blended finish work
Intake 22% Increased Flow (max)
Exhaust 41% Increased Flow (max)
4-angle Inlet Valve job
3-angle & radiused Exhaust Valve job
Valves are lapped
Back-Cut Inlet Valves
Heads are Ultra Sonic cleaned prior to assembly
Heads are Serialized and sport a machined Cosworth logo
+1mm Stainless Steel Intake Valves (1800 degrees max.)
+1mm Inconel Exhaust Valves (2400 degrees max.)
Performance Valve Springs
Titanium Retainers
Hardened Steel Spring Platforms
Knife Edge port divider
Subaru EJ25 STI (2.5L) 79mm stroke billet crankshaft
Increased engine performance often means increased engine speed and load. Original factory crankshafts may not be able to withstand the added stress resulting in catastrophic failure. Cosworth billet crankshafts are machined from ultra strong EN40B steel and are engineered to endure the harshest conditions and have been tested to withstand over 1000HP! Features include superior lubrication, profiled counterweights and added strength.
Subaru EJ20/EJ25 High Performance Rod Bearing set
Engine bearings are one of the most vital components within an engine and are often overlooked when considering high performance upgrades. Performance engineered, multi-layer bearings generate less heat than normal bearings by reducing friction. Cosworth Race bearing sets feature a unique combination of design, metallurgy and engineering to deliver what drivers expect from high performance Tri-Metal engine bearings. Engineered with the following features: •High strength overlay plate with reduced thickness for better oil control and less friction •Hardened steel backing on all connecting rod bearings •Increased crush and elimination of flash plating •3/4 grooving on Main Bearings providing optimum oil supply •Tight consistent wall tolerances •Oversize chamfers where applicable •Tested to over 1000 horsepower!
Subaru EJ20/EJ25 Camshaft set
Cosworth has been engineering camshafts for nearly 50 years. That coupled with years of innovative multi valve cylinder head design ensures our camshaft designs or the most efficient in providing maximum usable power across the widest power band. Each cam is ground from a new chill cast billet and finished using the same procedures we use in our extreme level race engines. Cosworth camshafts are the perfect compliment to our CNC Ported Big Valve Cylinder heads. Our Subaru EJ25 cams are profiled to increase boost response thereby increasing engine torque and power and are fully compatible with the Subaru STI AVCS. Please download the technical document on the left for camshaft specifications.
Ground from new chill cast billets
Price is for complete set of four
Requires spring upgrade or high performance valve train
Works well with big turbo
Subaru EJ25/EJ20 Forged Piston Set
The piston is one of the most important components within an engine. It can be subjected to directional change up to 285 times every second and must withstand acceleration forces up to 8500g. Cosworth high performance forged pistons are designed and engineered to withstand this type of punishment and still perform. All Cosworth forged pistons are manufactured using the same methods as our Formula One pistons and feature friction reducing skirt coating, ultra strong pins, polished tops and patented anti-detonation bands. Additionally, each application uses a unique forging to minimize weight and ensure the strongest possible piston design. • Proprietary Cosworth alloy • Popular sizes • Unique forging • Skirt coating • Polished top • Anti-detonation bands • High strength pin
Subaru EJ20/EJ25 High Performance Cylinder head Stud Kit
Essential for high performance engine builds, heavy duty head studs reduce cylinder head movement in high boost engines optimizing cylinder head to block sealing. Ultra high performance fasteners are manufactured from high tensile strength steel and come complete with nuts and washers.
Subaru EJ20/EJ25 Billet Timing Belt guide
Replaces the factory sheet metal timing belt guide to help reduce the possibility of the timing belt skipping a tooth during high rpm use. Precision machined from aluminum with a hard anodized finish.
Subaru EJ20/25 Oil Pump
Designed to improve the oiling on modified engines. Each pump is disassembled and inspected. Oil galleys are then honed to ensure unobstructed flow. We then incorporate a modified pressure relief valve to maintain pressure stability throughout the rpm range. Note: Flow rate is unchanged. This is an essential item on any high performance engine.
Please call or PM for pricing!
~Jon
480 219 6652
Caliente Auto is offline
Old 07-25-2006, 11:42 AM   #2
Caliente Auto
Member#: 59051
2004 WRX Sedan
We also have Brian Crower Stroker kits, Cams, and Valvetrain components if Cosworth is out of your budget...
Old 07-25-2006, 04:48 PM   #3
whitson01
Member Sales Rating: (4)
Member#: 100776
2004 sti
white
can you pm me prices on crower stroker kit for the 2.5l and cams.. thanks
whitson01 is offline
Old 07-25-2006, 05:12 PM   #4
Caliente Auto
Member#: 59051
2004 WRX Sedan
Pmed you
Old 07-27-2006, 06:24 PM   #5
Caliente Auto
Member#: 59051
2004 WRX Sedan
Real deal power products!
Old 07-29-2006, 03:03 AM   #6
shemoves
Member Sales Rating: (27)
Member#: 80663
2005 STi
I've handled some of the Cosworth pieces in person...absolutely gorgeous.
shemoves is offline
Old 07-29-2006, 10:11 AM   #7
spdkillz
Member Sales Rating: (6)
Member#: 72235
2008 STi
can you pm me for the stroker kit for the 2.5 l also please!
spdkillz is offline
Old 07-29-2006, 02:51 PM   #8
mllrsti
Member#: 78214
04 STi
JBP
Pm sent
mllrsti is offline
Old 08-04-2006, 07:03 PM   #9
Caliente Auto
Member#: 59051
2004 WRX Sedan
Replied all
Old 08-07-2006, 02:06 PM   #10
linus011
Member#: 9132
2005 WRX STi
2009 Fit, 1972 Dart
How much are the cosworth pistons? Please Pm me! thanks!
Brian
linus011 is offline
Old 08-08-2006, 07:59 PM   #11
i2onin
Member Sales Rating: (3)
Member#: 94807
'98 impreza RS
RBP
price for a Cosworth EJ25 High Performance Rod Bearing set.
for a phase 1 ej25
i2onin is offline
Old 08-08-2006, 08:27 PM   #12
InfamousDX
Member Sales Rating: (184)
Member#: 25413
How much for hte Cosworth ej20 camshafts? And in what spec do they come? I'm looking for something around 272/264 or 272/272
InfamousDX is offline
Old 08-09-2006, 01:35 AM   #13
Growit
Member Sales Rating: (1)
Member#: 97764
96 Outback
Forest Green
Default Performance Rod Bearing set
for a phase 2 ej25
What do you have for an upreaded ring set?
Growit is offline
Old 08-09-2006, 04:20 AM   #14
STi*guy.kiev
Member#: 117854
2003 spec c
price for the block w/ billet crank and heads combo
STi*guy.kiev is offline
Old 08-12-2006, 04:29 PM   #15
midnightsti
Member#: 74095
2004 STI w/CP S2
Perrin GT30R .82 ;)
can i get a quote for the block one for the cams and one for the heads please
midnightsti is offline
Closed Thread
Blessing & KERS - The next big powertrain advance in Formula 1 revs to 64,500 rpm AVANTI R5 Non-Subaru News & Rumors 8 02-21-2008 02:48 AM
Go chargers! Yes, "chargers" with a lower-case 'c'. "chargers." As in "Find me some." Asinine Off-Topic 73 10-31-2007 05:25 PM
The Death of Formula 1 as we Know it? dsm_rally Off-Topic 53 05-18-2007 05:27 PM
Don't wait for custom headwork - Cosworth 10K RPM Heads IN STOCK PDXTuning Engine/Power/Exhaust 5 06-17-2005 02:20 PM
If the rods in a sti are the same as in a 1.8 will aftermarket rods fit? NewbyScooby Normally Aspirated with bolt-on Forced Induction Powertrain 2 06-04-2003 10:08 PM
