#1 |
Vendor Sales Rating: (65)
Member#: 23216
Vehicle:2006 949-457-1234 949-457-1234 |
Hey all,
We just landed a massive container with lots of JDM Motors on it. I expect these motors will sell very very quickly so if act now if you've been waiting for a good deal on a clean motor!!! 1. 2005 JDM Legacy GT 2.5 Turbo Engine (same as STI) -Less than 15km Miles -Leaked down and compression tested -Identical to USDM STI Engine except intake manifold -2.5 Liters of displacement, with STI crankshaft, block -JDM Legacy GT heads, valvetrain, etc. -No power steering, alternator, AC SOLD 2. USDM 2006+ WRX EJ25 Turbo Engine -Less than 20,000 miles -Leaked down and compression tested -Ready to drop in 2.5 liter displacement $2399 3. JDM 2005 WRX EJ20 AVCS Engine -Less than 15km miles -Leaked down and compression tested -JDM high-flow AVCS heads -Higher compression than USDM 2.0 engine -No A/C, alternator, power steering SOLD 4. USDM 2005 WRX EJ20 Engine -Less than 20,000 miles -Leaked down and compression tested -Great for stock motor replacements -No A/C, alternator, power steering SOLD 5. JDM EZ30R 6cyl Engine -Less than 10km miles -Leaked down and compression tested -Great for big power programs -Built motor pistons / rods avialable - call us for more info! $1999 6. 6-Speed STI Transmission with DCCD -Less than 5km miles -Tore down and inspected -We've done multiple passes (street driven also!) at over 600HP on these transmissions -Fits all model year Imprezas, Foresters, Legacy, etc. (requires DCCD controller) $3299 7. 6-Speed STI Transmission without DCCD -Less than 5km miles -Tore down and inspected -We've done multiple passes (street driven also!) at over 600HP on these transmissions -Fits all model year Imprezas, Foresters, Legacy, etc. $3499 8. 6-Speed STI Transmission without DCCD (06+) -Less than 5km miles -Tore down and inspected -Designed specifically for 2006+ Imprezas with ABS speedo sensor (does not have speedo in tranny) $2999 ![]() ![]() ![]() ![]() ----------------------------------------------------------------------- Built Shortblocks and Motors: Gruppe-S Stage 2 Super High Rev Motor $3499 + Shipping Our Gruppe-S Stage 2 High-Rev engine is the ultimate in high RPM performance. With its shorter stroke and lighter pistons, this 2.1 liter engine (due to oversize pistons) has an extremely rapid response making the engine great for road-race and other competition racing. This engine starts off life as the semi-closed JDM STI shortblock. We tear this engine down and install our nitrided crankshaft, Helix forged rods with ARP L19 rod bolts, custom Wiseco forged pistons, and coated race bearings. The crankshaft is then professional balanced to within +/- 1 gram, cylinder walls rehoned, and everything re-installed with tolerances carefully checked. With our stage engines you will not have any problems with excessive oil consumption or rocking pistons. The block is semi-closed and can safely support up to 30psi of boost pressure without cooling issues (as opposed to closed deck blocks). This engine is perfect for the enthusiast looking for an engine that can safely rev to 8500RPM* and hold over 550HP. -Gruppe-S / Wiseco Forged and Coated Pistons -Coated High Performance Rod & Crankshaft bearings -Forged and nitrided STi Crankshaft -Helix Forged H-beam Connecting Rods w/ ARP L19 bolts -Professionally balanced and assembled -Rehoned cylinder walls Bolt on some good heads and this motor should be an absolute monster capable of holding 600+ CHP. ![]() Gruppe-S 2.2L Stroker Kit for EJ20T - $1399 + Shipped These are all the parts needed to build a 2.0L turbocharged motor (WRX or JDM STi) into a serious power making 2.2L stroker motor. This motor should be capable of holding 550 crank HP while revving to 7500 RPM if properly balanced. It includes the following: -Custom spec Wiseco forged stroker pistons -STi forged connecting rods and bolts -STi forged crank shaft -Gruppe-S coated racing bearings Gruppe-S 2.5L Stage 1 Shortblock - $2599 + shipping Our Stage 1 shortblock replaces the components we feel are most likely to fail in the USDM STi shortblock. This is essentially a bulletproof USDM STi shortblock and will compliment a GT30R, SZ55, FP Red , FP Green, or TD06-20G sized turbo nicely on 100 octane. WRX owners can benefit from this shortblock also since their heads will bolt right onto it; however, combining their heads with something like the Helix cams and valvetrain and this shortblock would yield something with peak power output similar to the USDM STi. In comparison to other companies' Stage 1 shortblocks, our adds coated race bearings and balancing to within 1 gram (JDM STi motors are balanced to within 7 grams). Features: -Gruppe-S / Wiseco Forged Pistons -Gruppe-S Coated High Performance Rod & Crankshaft bearings -STi Forged Connecting Rods -STi Forged Crankshaft -ARP Headstuds (on long-block option) -Cometic Head Gaskets (on long-block option) -Professionally balanced rotating assembly (recommended 7500 RPM redline) -Rehoned cylinder walls -Capable of up to 535+ CHP Operation -Final Displacement 2.48L -Compression ~8.5 : 1 *Assembly time is generally 3-4 weeks. For the Long block option, we require a core charge for the heads which will be refunded if you heads are in good working order. Gruppe-S 2.5L Stage 2 Shortblock - $3599 + Shipping We are pleased to announce the release of our second generation Stage 2 2.5L Short Block. The GS650 exemplifies all of our experience building and tuning high horsepower race and street engines. The GS650 has been installed on daily-driven cars that make over 600HP on the street, safely and reliably. These are the same cars that drive to the track, run sub-11 second times and are driven home. This block is capable of maxing out the GT35R turbo (ask MARKGSTI ).The GS650 starts life as a regular STI shortblock. First we replace the weak hyper-cast stock pistons with custom spec forged units (coated). Not only are the pistons significantly stronger than the stock units the pistons are substantially lighter too. We then address the connecting rods. The rods are replaced with Helix forged H-beam rods held together with ARP L-19 bolts. The super-strong forged rods coupled with the best rod bolts available on the market allow for high RPM operation. The crankshaft is then modified with our proprietary techniques creating a crankshaft similar to the $2000 STI race crankshaft used on the WRC cars. The bearings are swapped out in favor of Gruppe-S coated race bearings. This addresses all the common main failure points of the stock STI 2.5 engine – spun bearings, cracked pistons, and damaged rods. The entire assembly is then balanced. Piston walls are bored and honed, all tolerances are triple checked, and the assembly is professionally assembled. The end result is a big power engine that is capable of 8500 RPM operation* and holding 650 crank HP. That’s right, 165 HP PER A CYLINDER. The GS650 is purposely built to tight tolerances for street operation. You will not experience excessive oil consumption and you will not have a rocking issue with our pistons. Recommended Limits: -7500RPM redline** -30psi boost limit -650HP reliable horsepower limit *”Looser” race engines (not recommended for street use) are available – simply let us know if that is what you are looking for. **8500 RPM requires substantial modifications to the head, oiling system, and other components. We have experience building high revving engines, please contact us for additional details. ![]() Features: -Gruppe-S / Wiseco Forged and Coated Pistons -Coated High Performance Rod & Crankshaft bearings -Reworked Forged STi Crankshaft -Helix Forged H-beam Connecting Rods w/ ARP L19 bolts -Professionally balanced and assembled (recommended 7500 RPM redline) -Rehoned cylinder walls -Capable of up to 650 CHP Operation -Final Displacement 2.48L -Compression ~8.5 : 1 Gruppe Buy Price: $3299 Price with 2.5L block trade in (must be functional and in good shape) - $2699 Thanks, Mark Phone: (510) 783-5300 We Accept Paypal! Paypal: sales@gruppe-s.com When ordering w/ paypal, please include the following: product name: XXXX sales rep: Mark Price including shipping: $XXXX Shipping address. ![]()
#2 |
Member#: 23216
We are pleased to announce the Helix V3 Downpipes just arrived in port and will be delivered shortly. To kick off the launch we are offering an 7-day introductory sale at insane prices!!
Helix V3 Downpipe Uncatted -includes external WG port -Lighter and more efficient flowing castbellmouth -SS304 construction -Fully TIG Welded, Mandrel bent $185 Shipped!!! Helix V3 Catted Downpipe -Lighter and more efficient flowing castbellmouth -SS304 construction -Fully TIG Welded, Mandrel bent -200 Cell Metal Substrate Catalyst $329 Shipped!!! ![]() This day is a 7-day sale only. The sale ends 7/25/06. All downpipes will ship after the sale ends. Please call or paypal to order now!! Thanks, Mark Phone: (510) 783-5300 We Accept Paypal! Paypal: sales@gruppe-s.com When ordering w/ paypal, please include the following: product name: XXXX sales rep: Mark Price including shipping: $XXXX Shipping address. ![]() |
#3 | |
Member Sales Rating: (9)
Member#: 90221
SWIC
Vehicle:2005 Jag S-Type R 425HP Blown V8 :) |
I posted on the other thread that's now closed. I was asking about the pick up price for a NON-catted DP since I wil be in Oakland from 7-26 through 7-31. Geoff said it would be $329 picked which seems like the price for a catted DP. So would it be $189 for the non-catted DP? And why is it the same price for shipped vs/ picked up? Are your sales taxes that high?? The other question was that flange on the uncatted DP. Is that for the external WG to dump back to the DP instead of being an open pipe and thus reduce noise? If it isn't, why do you say that it includes "external WG port'? Thanks. |
#5 | ||
Member#: 23216
Thanks, Geoff |
#10 |
Member Sales Rating: (1)
Member#: 93479
NWIC
Vehicle:2005 STi White |
is there clearance on the external wastegate part on the v3 helix downpipe?? to me it looks like it may be really close to the ac drip line or maybe even hit part of the firewall/ crossbrace
#12 |
Member#: 5961
South East
Vehicle:2005 STi CGM |
Are all Helix DPs going to have the EWG port on them now? I have no plans of going EWG, and don't want the clearance issues, leak possibilities, and flow disruption this would provide...
VV |
#14 |
Member Sales Rating: (2)
Member#: 111185
South East
Vehicle:06 WRX TR OBP |
Mark, i tried to call you today and left a message with another sales rep for you...wanting to place an order for the Helix uncatted dp but i have a few questions. i'm going to try and PM you as well, hope to hear back from you before the sale is over. thanks,
Nic |
#15 | |||||||
Member#: 23216
I'm make sure Mark gets in contact with you. Thanks, Geoff Last edited by Gruppe-S; 07-24-2006 at 09:02 PM. |
#17 |
Member#: 59097
SCIC
Vehicle:04 WRX Java Black |
placed my order yesterday. These are awesome prices, Especially the catted which i got, $329.00 is insane.
Geoff, I ordered from Mark yesterday and It seemed like he wasn't sure about an EWG on the catted V3's. Do the v3's catted come with EWG as well? |
#18 | |
Member#: 111185
South East
#19 | ||
Member#: 23216
Thanks, Geoff |
#21 |
Member Sales Rating: (28)
Member#: 102157
Vehicle:What you lookin at willis? |
I didnt see this thread till now....I'd be interested in the v3 downpipe...pm me if I can still get the sale price if i order tmrw. I will give you a call tomorrow as well- Dave
#22 |
Member Sales Rating: (10)
Member#: 18914
South East
Vehicle:2006 WRX Black with some stuff |
Gruppe-S,
Do you guys have any other engines besides the ones in this thread? I am looking any engine that would be a direct bolt in for my 2005 Saab 9-2X. Carlito |
#24 | |||
Member#: 23216
Thanks, Geoff |
#25 | |
Member Sales Rating: (26)
Member#: 120
AKIC
Vehicle:1997 Legacy 2.5GT QuickSilver Metallic |
Thanks, Pat Olsen '97 Legacy 2.5GT sedan |
| Thread Tools | |
| Display Modes | |
| invidia downpipe vs helix v3 downpipe | philly15 | Newbies & FAQs | 3 | 05-08-2010 12:45 AM |
| USED: Helix Catted Downpipe ($199), Helix V3 Downpipe ($99) | Gruppe-S | Engine/Power/Exhaust | 15 | 04-17-2007 08:29 PM |
| Helix V3 Downpipes Catted and Uncatted just arrived in port!! (7-day sale!!) | Gruppe-S | Engine/Power/Exhaust | 13 | 07-20-2006 07:38 PM |
| FS: Helix V3 downpipe | joopworks | Private 'For Sale' Classifieds | 5 | 01-27-2005 08:00 AM |
| Helix V3 Downpipe - Now with WB02 bung! | Gruppe-S | Engine/Power/Exhaust | 16 | 04-26-2004 11:06 AM |
