Old 07-20-2006, 09:09 PM   #1
elwood-914
Member#: 120700
Default What year Engine? EJ22
Hi all,
I just bought a Subaru EJ22engine but the problem I don't know what year car it came out of. I was told it was an Impezza. I need to buy head gaskets and such but I am clueless as to what year.
Thanks
Tim
elwood-914 is offline   Reply With Quote
Old 07-20-2006, 09:40 PM   #2
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
an EJ22 is just that.....you can't order the wrong ones
Old 07-20-2006, 10:27 PM   #3
elwood-914
Member#: 120700
Thanks Uncle Scotty
Old 07-20-2006, 10:32 PM   #4
project_legacy
Member#: 114408
1999 Subaru Legacy L
30th AE Maroon
for head gaskets, i dont think there is a difference. but there are different ej22's floating around thru out the years. turbo one, single exhaust port ones, and the n/a dual port ones. just wanted to point that out.
project_legacy is offline   Reply With Quote
Old 07-21-2006, 07:53 AM   #5
RedTRex
Member#: 18513
JMS Clan Guy #11
2005 Alpine White ZHP
...good info, but that has to do with the heads.
RedTRex is offline   Reply With Quote
Old 07-21-2006, 08:08 AM   #6
Elwood
Member#: 8335
96 Impreza L 2.2t
99 Impreza L Wagon
I think they went to thinner head gaskets on the later 2.2s. not sure exactly when though. if you don't get the right ones, you'll change your compression ratio.
Elwood is offline   Reply With Quote
Old 07-21-2006, 08:38 AM   #7
RedTRex
Member#: 18513
JMS Clan Guy #11
yeah, by .01 %. ..... come on.
Old 07-21-2006, 08:39 AM   #8
Elwood
Member#: 8335
96 Impreza L 2.2t
99 Impreza L Wagon
check your math
Old 07-21-2006, 09:28 AM   #9
Subie Gal
GC84Ever
Super Moderator
Member#: 301
1970 FF-1 & '70 Van
02 WRX/01 RS
check your math
doesnt matter as the Uncle is right.
All 2.2 HG's supercede to one part, and one part number
you can't mess this one up
Jamie
Old 07-21-2006, 10:25 AM   #10
Elwood
Member#: 8335
96 Impreza L 2.2t
99 Impreza L Wagon
Is this a recent change? I wonder how I managed to buy (just this spring) 2 different sets of EJ22 head gaskets?
I first ordered a set for a 99 hoping they'd be nice multilayered steel gaskets. They were, but were noticebly thinner than the original ones my motor had. I then ordered another set for a 96, and got the crappy composite, but correct thickness gaskets.
The old gaskets were 1.52mm thick. I believe the new ones are probably the same thickness as the phase 2 EJ25, which are only 0.58 mm thick ( I can measure later and confirm). That equates to a volume difference of almost 7 cc's. Given that these motors have combustion chambers in the 40-50cc range, a 7 cc change would be significant. Depending on what you started with and what you went to, that could raise or lower the CR by 1 or so. That could even be desirable, depending on what you're going for, but I'd sure like to know about it beforehand, rather than just slapping it together and seeing what happens.
But hey, if SOA says it's ok, I must just be crazy...
Jim
Old 07-21-2006, 02:29 PM   #11
Subie Gal
GC84Ever
Super Moderator
Member#: 301
1970 FF-1 & '70 Van
02 WRX/01 RS
Jim is right!
I did some diggin and I have found a difference
1993-1998 = EJ22/EJ22EZ
1999-2001 = EJ22 but with a different head gasket part number
so yeah, there appears to be a difference - - oops!!
1993-1998= supercede to one part number
1999-2001 = are all the same part number, which differs from the older model
seems there is a slight difference based on early vs later production runs
are there any markings on the block?
maybe we can identify the model year.
Jamie
Old 07-21-2006, 03:17 PM   #12
Uncle Scotty
Member#: 16200
OK buy Nates beans
...what we NEED is an easy visual way to tell the EJ22 form the EJ22EZ.
...and the OP posted EJ22....not EJ22EZ
Old 07-21-2006, 03:41 PM   #13
Elwood
Member#: 8335
96 Impreza L 2.2t
99 Impreza L Wagon
I did some more reading and I believe what we are talking about here is the phase 1 to phase 2 change over, similar to what the EJ25 went through. I can’t recall seeing a phase 2 EJ22 in person, but it sounds like in 99 the EJ22 head got redesigned, and looks similar to the modern SOHC EJ25, with big, flat, rectangular valve covers, with the spark plug wires passing through them. This differs from the earlier EJ22s, which had narrower (top to bottom) valve covers, and the plugs and wires came out above the valve cover. So it should be pretty easy to tell them apart….
Old 07-21-2006, 04:46 PM   #14
Wiscon_Mark
Member#: 94945
2012 Impreza
Sport Limited DGM
Unless he's OBDII and he got an OBDI engine...or vice versa.
It would be a PITA to swap if it was the wrong emissions. Not that it's not doable.
However, the headgaskets would be the same through all years.
Wiscon_Mark is offline   Reply With Quote
Old 07-22-2006, 02:10 AM   #15
elwood-914
Member#: 120700
The sparkplug wires do not go through the valve covers, so I assume I have an earlier version. This is very interesting to me to learn about unfamiliar motors. I do appeciate everyones imput.
Old 07-22-2006, 11:33 AM   #16
Subie Gal
GC84Ever
Super Moderator
Member#: 301
1970 FF-1 & '70 Van
02 WRX/01 RS
I'll take a look (on monday) at the spark plug wires.
betcha there will be an obvious difference in shape as well based on the production date cut offs....
we can probably figure it out by studying the differences
Jamie
Old 07-22-2006, 07:30 PM   #17
DerFahrer
Member#: 30727
2000 Legacy B4 RSK
*Formerly subyluvr2212*
Yeah, the 90-98 EJ22 is the EJ22E, Phase I, appearing in the Legacy and Impreza. 90-96 went virtually unchanged, but in 97, it switched to solid lifters and upped its compression ratio, and thusly became interference. 99, the EJ22EZ came out, Phase II, and that engine had the relocated thrust bearing like the other Phase II's.
I would think the HGs would have changed in 97, with the upped CR and everything, but I guess not.
I can't recall when they switched to the plug wires going through the valve covers, but I know I've seen a 99 Legacy EJ22 with the wires through the valve covers.
If I can track down a 97 Legacy or Impreza at work, I'll try to look at it.
DerFahrer is offline   Reply With Quote
What Year Forester engine is the same as a 05 LGT? el_pincho Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 3 03-10-2010 02:54 PM
EJ22 ECU what years Eatoniashoprat Normally Aspirated Powertrain 2 05-06-2009 09:00 AM
What year USDM STi produces the most power on the stock turbo and engine? Red Rexx Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 46 05-13-2008 09:02 AM
Newbie - What year engine do i have? 00WRXstorino Subaru Conversions 8 02-24-2008 11:51 PM
How can I tell what year my engine is????? TurboCharged97L Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 14 02-18-2008 01:10 PM
