Old 07-21-2006, 12:07 PM   #1
intpostman23
Member#: 89185
2004 IMPREZA WRX STI
-Chargespeed V2- WRB
Default Just upgrade rotors/pads.. now wat brake fluid do i use?
hows it going... well after 24K miles on the stock pads/rotors the sti needed some new toys... i upgraded to hawk hps all around and powerslot rotors all around.. now, i know i need to bleed the system still and all that nonsense, but wat brake fluid do u recommend? i have SS lines im putting in also...
04 sti..
Hawk hps pads
PowerSlot rotors
SS brake lines
use a daily driver, with occasional spirtited driving
Here is a comperison i found
im not sure wat i accually need... any help is def appriciated!! thanks!!!
intpostman23 is offline   Reply With Quote
Old 07-21-2006, 12:08 PM   #2
GTWORX.com
Member#: 97303
2009 WRX and Boxster
Gray and Black
We have found that ATE Superblue is a great all around fluid and it's inexpensive too.
-Dan
GTWORX.com is offline   Reply With Quote
Old 07-21-2006, 12:10 PM   #3
intpostman23
Member#: 89185
-Dan
how much do u recommend buying to change everything and keep me alive, lol
Old 07-21-2006, 12:36 PM   #4
intpostman23
Member#: 89185
Bump... ok so i did alittle research and it seems ate goes for about $9.50 per liter.. how many liters are recommend for system flush?
Old 07-21-2006, 12:47 PM   #5
Samurai Jack
Member#: 21145
2002 Enemy of Aku
@ $10 to $12 a liter, ATE Super Blue seems expensive to me.
I, and many others, use Valvoline SynPower and you can get it for under $5 a quart, or roughly 1/2 the price of the ATE Super Blue.
http://www.valvoline.com/pages/produ...asp?product=51
Works great, no problems. You can probbaly have more than enough w/1 quart to bleed the entire system, but I would get 2 as a back-up. If for any reason you have trouble bleeding the brakes and go through more fluid than you expected, you won't have to go run out to get more in the middle of the job, which I always find to be a PITA.
Samurai Jack is offline   Reply With Quote
Old 07-21-2006, 12:53 PM   #6
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
Concur with Samurai Jack. The Valvoline Synpower stuff can be found at any auto parts place or Walmart, is significantly cheaper than ATE (or Motul or whatever else people recommend), and I've found it works as well as (if not better than) ATE Super Blue on track.
Pat Olsen
'97 Legacy 2.5GT sedan
Old 07-21-2006, 01:16 PM   #7
intpostman23
Member#: 89185
thanks for the input guys... i'll go check walmart out today
Old 07-21-2006, 04:21 PM   #8
en3d
Member#: 5238
GGA Black
I use Valvoline synpower too, like what was said, it's cheap and works well. I can bleed the fluid three times for the cost of more expensive stuff.
en3d is offline   Reply With Quote
Old 07-21-2006, 05:04 PM   #9
oldmansan
Member#: 17877
Midnight Pearl
I've used and cooked the Motul RBF600, heard good things about the Super Blue (Pat, Egmar recommended it), but I have been running the Castrol SRF for almost two years. Expensive stuff at $80-90 a liter, but you don't have to change it as often (my experience). Matter of fact, I'm going to flush and refill soon, but I'm still on the original liter I put in after cooking the Motul.
San
oldmansan is offline   Reply With Quote
Old 07-21-2006, 07:47 PM   #10
racekar
Member#: 107988
valvoline synpower or ate blue should be all you need
racekar is offline   Reply With Quote
Old 07-21-2006, 10:12 PM   #11
intpostman23
Member#: 89185
got my self 2 liters of valvoline synpower $10.00 total!!
Old 07-21-2006, 10:48 PM   #12
TCE
Member#: 100868
It all seems expensive too me.
If you don't boil some basic DOT3 or 4 such as Valvoline or other why are you wasting so much money? Your brakes aren't going to know the difference.
"if you don't boil what you're using, you don't need higher BP fluid"
TCE is offline   Reply With Quote
Endless Brake Sale - Vita Nuova/SS-S Brake Pads w. RF650 Brake Fluid DriveLineSales Suspension/Brakes/Handling 3 10-09-2009 09:07 PM
Brake pedal soft after upgraded rotors, pads, fluid Mar48 Brakes, Steering & Suspension 5 08-22-2007 02:05 PM
Subaru 4 Pots VS. Upgrading rotors/pads/brake lines WRXSIG Brakes, Steering & Suspension 13 11-02-2005 11:11 PM
just installed new rotors and pads. now parking brake needs adjustment? Wagon Joe Brakes, Steering & Suspension 8 04-19-2005 01:31 PM
What brake fluid do you use? SupaSizeFries Brakes, Steering & Suspension 8 12-18-2003 09:43 AM
