Old 07-22-2006, 07:50 PM   #1
steelhead
Member#: 93576
Question Alky Problem
Okay, I am baffled
I am running an SMC alky kit and the pump will stop working complety after 30mins or more of constant driving. Every time for the last week that I go on a prolonged drive (usaually on the highway) the pump goes dead. I still have a green light on the controller, but I press the test button and no spray. I confirm by stopping and holding the rpms at about 3k and hitting the test button again to see if it will bog the engine, but nothing. It doesn't seem to matter what the ambient temp is. The only constant is the prolonged drive.
If I then stop for about 5 or 10 mins the pump will operate again. WTF
Does anyone have any idea what is going on or had anything similar happen?
Thanks
steelhead is offline   Reply With Quote
Old 07-22-2006, 08:26 PM   #2
hippy
Member#: 36528
2002 Impreza Wrx
Old 07-22-2006, 08:44 PM   #3
steelhead
Member#: 93576
Thanks but when it happens the pump is not even trying, it is dead like someone flipped a switch off.
Old 07-22-2006, 09:14 PM   #4
hotrod
Member#: 14141
2002 Impreza WRX
e85forum.net
It sounds like a thermal cut off safety in the pump (some pumps have them to prevent overheating).
Is the pump mounted where it gets very hot during a long drive?
Larry
hotrod is offline   Reply With Quote
Old 07-22-2006, 09:24 PM   #5
steelhead
Member#: 93576
^^^ Thats what Steve at SMC was thinking but now he is not sure as it is happening on cool days. It just started happening last week and I have had the kit for a year now and never had this problem before.
Edit: The pump is mounted on the washer bottle under the hood.
Old 07-22-2006, 10:20 PM   #6
hotrod
Member#: 14141
2002 Impreza WRX
e85forum.net
Is the circuit feeding the pump protected with a circuit breaker?
If you have a VOM (volt meter) try to test if there is voltage at the + terminal of the pump when it is supposed to be running but fails to run. If there is, than the pump is toast, if not then your circuit is going dead for some reason and you need to check for shorts or opens and bad switches fuses/circuit breakers for a start.
If you don't have a volt meter, simply wire a light bulb in parallel with the pump, if it comes on but the pump is dead then its a bad pump. If it fails to light, when the pump is coming on your not getting any current to pump and you have a wiring problem.
Larry
Old 07-23-2006, 12:36 AM   #7
STi Crazy
Member#: 90221
2005 Jag S-Type R
425HP Blown V8 :)
Originally Posted by steelhead
Okay, I am baffled
Thanks
Sorry to hear about your problems with the SMC kit. I have the same system but have the Spec C tank. Hopefully it won't have the same issues.
Thought you'd like to know the the ACPT is installed and it's perfect for track use (as I thought) - especially throttle response through the corners and keeping the revs up exiting. So while not a "power" mod in terms of adding HP, makes the car run "quicker" if you know what i mean! Plus, it's a great supporting mod later should I want more power!
Good luck with the alky! Can't wait to install mine and get retuned.
STi Crazy is offline   Reply With Quote
Old 07-23-2006, 07:29 AM   #8
TSUNAMI_STI
Member#: 102668
2005 STI
CRYSTAL GREY
i have the same kit and until now all is working great, i live in puerto rico which is hot 90% of the time and never had that problem. you can try using some sort of thermal shield to protect the pump or what i did was eliminate the rubber trimming from the hood and raise the hood using washers or spacers about 1/4 - 1/2'' at the hinges to eliminate lots of the engine heat.
my 2cents
TSUNAMI_STI is offline   Reply With Quote
Old 07-25-2006, 10:56 AM   #9
klattery
Member#: 48503
2004 STi ATP3071
The SMC kit has a spray light that showns when the pump is spraying at 30psi or more. If I read you correctly, the spray light comes on when you push the test button before your extended run, but no longer comes on after the extended runs?
If so that would seem to indicate some kind of short caused by the heat. So I'd look at what hotrod says to identify where the short occurs.
klattery is offline   Reply With Quote
Old 07-25-2006, 02:06 PM   #10
steelhead
Member#: 93576
[quote=klattery]The SMC kit has a spray light that showns when the pump is spraying at 30psi or more. If I read you correctly, the spray light comes on when you push the test button before your extended run, but no longer comes on after the extended runs?
QUOTE]
Correct. I am taking the pump out and sending it to SMC so they can test it, and then move forward from there before I pull any more hair out trying to figure it out.
Who here has had problems running water/meth/alky??? Lets hear from you... Gatchaman Water/Methanol Injection, Nitrous & Intercooler Cooling 5 03-18-2007 10:44 PM
Alki silver wrx with gauge on steering column RA North West Impreza Club Forum -- NWIC 0 08-06-2002 09:58 PM
98 Legacy GT sedan 4sale on alki AllWheelsDriven North West Impreza Club Forum -- NWIC 1 06-06-2002 11:36 PM
Sighting On ALKI at 3:30pm aprox Monday WOOTENVISION North West Impreza Club Forum -- NWIC 0 03-25-2002 10:37 PM
Alki on Sun RA North West Impreza Club Forum -- NWIC 6 03-06-2002 02:48 AM
Message Board Statistics All times are GMT -4. The time now is 04:46 AM.
