Old 07-22-2006, 09:29 PM   #1
my name
Member#: 106794
2004 STi
Default need help with fuel leak
okay i gots this problem thats getting bigger. i gots a fuel leak out of the take of my 96 brighton. its leaking out of the spot that the top half and the bottom half of the tank are put togther and it has rusted there is now is leaking. i found out that its in the 350-400 range for a new tank. im not real shure if i feel like getting involved in changing the tank so there maybe labor also. i noticed that the impreza L tanks are cheeper than the brightons. Is there a reason for this? can i used a L tank in my car? my second thought is just installing a fuel cell into where the spare tire gos. has anyone done this before? i plan to make this car into a rally car so this would be one step closer. any one that has some input will help a lot.
my name is offline   Reply With Quote
Old 07-22-2006, 09:31 PM   #2
Texas25RS
Member#: 3148
2012 Mazdaspeed 3
Crystal White Pearl Mica
You should check with local laws first before using a fuel cell... if you are planning on running a rally car, a fuel tank should be easy to replace. Drain the fuel, disconnect the pump and wiring, drop the tank, replace...
Texas25RS is offline   Reply With Quote
Old 07-22-2006, 09:44 PM   #3
my name
Member#: 106794
2004 STi
i see the job of droping the tank being a pain because having to drop all parts in the rear end witch are mostly rust up and would rather not chance snaping them. i also see the the fuel cell being a cheeper easyer way out as long as it all can be hooked up with out any probs.
Old 07-23-2006, 09:09 AM   #4
solbey11
Member#: 89234
My fuel filler neck is rusted and leaking. I was thinking about welding it shut.
solbey11 is offline   Reply With Quote
Need help with air leak on 09 FXT ! nickfxt Factory 2.5L Turbo Powertrain 2 04-28-2009 12:31 PM
Need help with boost leak test Sausage Newbies & FAQs 7 12-05-2007 09:10 AM
need help with oil leak ? narrowed down to 3 spots phat pat Factory 2.0L Turbo Powertrain 1 08-06-2004 03:16 PM
Need help with boost leak MAD REX Factory 2.0L Turbo Powertrain 0 05-03-2004 01:53 AM
Need help! Perrin Fuel rails installed but I need help with Fuel Evap Line STR8OUT Factory 2.0L Turbo Powertrain 7 04-18-2003 12:11 PM
Message Board Statistics All times are GMT -4. The time now is 02:24 AM.
